1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. njcycleguy
    njcycleguy Formula Junior
    475
    East Coast
    Been considering a lift for my garage for some time. I already went thru the hassle of installing all new high lift garage doors and jack shaft operators - but for some reason I can't seem to pull the trigger on a lift.
    I first thought I wanted a single arm lift for aesthetic purposes, but I'm now considering a simple 4 post - problem is I don't want to overpay - or underpay for that matter. Example - I don't mind spending a few extra bucks for something that I consider critical but I also don't want to spend unnecessarily as the vehicle that sits on top will only be used sparingly.
    Some say Bendpak is the best - then others say you are overpaying for the name - some say don't buy the made in China lifts - still others say they are all made in China, even the Bendpak. Prices seem to be about $500-$1000 difference for Bendpak vs the other "Auto-lifts" and other brands.
    Any insight (and references for good installers in the Northern NJ/NY area) would be helpful!
  2. Dave rocks
    Dave rocks F1 World Champ
    Sponsor Owner
    Nov 23, 2012
    10,753
    Orchard Park, NY
    Dave Lelonek
    I'm not one to usually say "search" but in this case, yes, do a search. Probably 100+ threads on lifts you will find here :)
  3. njcycleguy
    475
    East Coast
    I've read thru past threads. I'm asking for current recommendations and thoughts - as well as installers in the NJ/NY region hence why I posted in this section.
  4. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    2,936
    Bay Shore, NY
    Andy
    I too am struggling with a similar decision. Storage is my objective as well. Without trying to sound snooty, the price differential for a Bendpak is justifiable because of the build quality and a better chance at support five or ten years from now. A Ferrari owner trying to save a thousand dollars on a lift is a little incongruent. I have heard horror stories on the cheaper lifts and since safety is more important to me than testing out my insurance carrier, I am leaning toward Bendpak. My struggle is which one - the 9ST (narrow) or the more full width model. JCM is a nationwide company with warehouses around the country and there is one on Long Island and I suspect in NJ as well. I am not sure though how affiliated they are with BendPak. In other words are they factory authorized to do BendPak installations, warranty and out of warranty repairs, etc. or do they just buy the lifts from BP and resell them? That's my next step - to clear that up.
  5. Cgk360
    Cgk360 Rookie
    41
    NJ
    Chris
    Njcycleguy,
    I have a Bendpack HD9 four post lift and love it. It performs flawlessly. I have my '63 Austin Healey on the lift and park my Scud under it. The optional drip trays come in handy as the Healy leaks oil from the rear crank seal, the tranny and the differential. As they saying goes, you know when to change the oil in a British car when it stops leaking. Buy the optional aluminum ramps too. Lightweight and easy to remove if needed. Consider buying the optional roller jacks if you want to be able to do wheel-off work while it's on the lift. If that is something you plan to do often, a two post lift might be better. Before buying anything, make sure you have enough ceiling height and concrete floor thickness. I also ran a 220V line and outlet to the ceiling to plug the lift's electric into. You will need an air compressor if you don't already have one.
    I purchased my lift through Garage Equipment Supply and they recommended a local installer. It was assembled and installed within a few hours.
    PM me if you want to discuss further.
  6. Cgk360
    Cgk360 Rookie
    41
    NJ
    Chris
  7. Tired of seeing this ad? Upgrade now
  8. sasso1977
    sasso1977 Karting
    218
    nyc
    cesar
    got two lifts installed in my garage. paid 7500 for both. challenger is the brand . 7000lb capacity.so far ,so good.
    ace equipment in farmingdale.
  9. njcycleguy
    475
    East Coast
    Seems like Bendpak is the way to go.
    I spoke with a guy named Peter Imbibo (sp?) who came recommended to me and is local in NNJ. He has no affiliation with any lift manufacturer but explained in detail the differences between the Bendpaks vs the other brands. So based on his recommendation, I'm going with the Bendpak - it's a few bucks more but apparently well worth it. Will post pics once installed.
    I have a TR so I want to ensure I have the width I need so I'm going with the standard HD-9.
    The only negative to the Bendpak (which is actually a positive according to those I spoke with for safety reasons) is the pressure-based locks that require an air compressor to disengage. Fine by me, the $100 for a small compressor isn't a deal breaker.
    And I'm told now the Bendpak color is gray - matching my garage much better. Will post pics once installed.
  10. tuttebenne
    Mar 26, 2003
    2,936
    Bay Shore, NY
    Andy
    The lock release on the BendPak doesn't require much pressure. (under 20psi IIRC). Looking forward to hearing more as you go forward.
  11. andrew911
    andrew911 F1 Rookie
    2,804
    Northern NJ
    I have a superior lift- I just pulled my file on this for some info for you. I bought it around 2005 (model "SR-7H- not sure if they are still in business?). When shopping around, I found several manufacturers, all with the same products which made be think there was one main supplier just rebranded from company to company, then there were a couple of other brands- bendpack and back yard buddy I think?- which may have been slightly different, but very similar in design/specs (even similar model names!) Back then what I was finding was there were 4 basic 4-post lifts to choose from (I only wanted a 4 post)- there were regular height, SUV height, US or "foreign" steel. I bought the "SUV" height, made in USA/USA steel. I bought the lift from Superior only because that was the brand a local guy here on Fchat had (Todd Geiger- had/has a beautiful light blue 355 fiorano).
    My lift does not require air pressure- you push the button to make the lift go up and inch or so and pull a lever to release the safety locks and can then let the car lower. I did get the optional aluminum ramps. The lift came with 3 drip trays and asked if they would throw in 3 more which they did, so I have 6- they are just plastic trays, but sometimes I have rear, mid or front engine cars parked on it (but 98% of the time a rear motor car- VW bug) so I figured I'd cover the hole area. I also bought a center support if you want to use a bottle jack- I've never used it though. I bought the lift for storage- the only light work that's been done with my lift is me changing the VW oil, and my brother in law changing the exhaust in his mustang (and my buddy changed the oil in his M3 once).
    I did not wire my garage for 220V- just use a regular 110 outlet. The advantage of the 220 is the motor lifts faster- the disadvantage is you need to get an electrician to run a 220V line...
    Superior had a local person come out to do the installation- in my notes it says Don Novak from Pro Automotive Equipment. I did have to have the piston changed a year or so ago-it was leaking a little. A guy who works locally to us in north NJ did it for me and was reasonably priced for the repair- he was recommended here on fchat- Peter Imbimbo- the same guy you were sent to!
    -Andrew
  12. Vito
    Vito Formula Junior
    317
    Dutchess County, NY
    Mark
    I've had a Backyard Buddy lift since 2006 & it has been perfect. A friend has one too and has had his longer without an issue. These are made in Ohio and are easily assembled, three of us did it in an afternoon. The Backyard Buddy has a secure locking system, square legs and is available in a 110V system so there's no need for a 220 line if you don't have one in your garage already.
  13. titanium430isback
    titanium430isback Formula Junior
    Oct 12, 2010
    387
  14. Tired of seeing this ad? Upgrade now
  15. Dai Baracca
    Dai Baracca Karting
    Mar 4, 2007
    175
    Westchester NY
    SB
    subscribed....lost my storage area and now need to turn my 2 car into a 4 car:p
    appreciate all the info
  16. RPM217
    RPM217 Formula Junior
    Feb 6, 2007
    339
    Rye Brook, NY
    Roger
    I have a 20x20 garage, with 4 cars in it. I have a double wide BendPak. It has four posts, and room for 2 cars, with a 9,000lb capacity. The wider tracks are on the right side, and I have to put the GT on that side. In order to get in and out of the car, if I have the NSX on the other side, I have to get in the passenger side, and climb over to the driver's side, as there's only about 6" between the 2 cars. My 2 cars are very low, and I use RaceRamps to lead to the ramps to get the car on. Definitely get the aluminum ramps, I'm sorry I didn't, those stock ramps weigh a ton!!!
  17. Horsin'around
    Horsin'around Rookie
    Jun 14, 2017
    12
    I am about to build a garage and plan on getting single arm lifts.
    These look wonderful!
    Any special considerations that need to be make when constructing the garage?
    Any downside at all? 1 post vs 4 post
  18. Alcav5
    Alcav5 Formula Junior
    948
    Scarsdale, NY
    Al
    I have chain hung custom lifts. Park Plus for residential. More costly than 4 post.
  19. njcycleguy
    475
    East Coast
    My original idea was to go with a single post - I preferred the smaller foot print and much better looks. As a matter of fact, I did all the work in my garage planning for 2 of them - but the single post requires bolting to the ground and I may need this lift to be mobile to move from my current garage to another. I also can move it with the caster kit within my current garage which can be helpful.
  20. mello
    mello Formula 3
    1,082
    California
    Steve
    The "only a few bucks more..." comments cracks me up. It's like the poster want to tell or repeat himself its "only a few bucks more" just to soften the blow on the wallet. :)
