fix it, sell it or part it out | Page 2 | FerrariChat
Discussion in 'Mondial' started by Greg W, Aug 13, 2017.
  1. Scaledetails
    Scaledetails F1 Rookie
    Nov 19, 2003
    4,208
    Daytona Beach, FL
    Stephane
    +1. That's exactly what Manos will do, he won't even wash it. So if he is offering $15K, I think there is some value there, my gut feeling says get the shop to get it running and enjoy it. Most likely it will hold its value if not appreciate over some time. Your $22K+ may be a good investment in the end plus you get to enjoy the car for a while.
  2. davem
    davem F1 Veteran
    8,247
    Stepford, Connecticut
    dave m
    What did the shop do to come up with $3700. Did they complete most of the major before they realized the issue? Your costs incurred thus far regardless are behind you. But they quoted you 5 to 6k for the major. Parts alone can be $1200....
    You can certainly put a used engine for way less than 22k. Would not spend 22k on an engine rebuild if the car was free with that many miles tbh. Who knows what else it needs.
    Best of luck
  3. steve_400i
    steve_400i Rookie
    Aug 15, 2017
    24
    Once a Mondial Cab is sorted and running well, one kind of forgets the bills and labor for a while. It is a wonderful experience! The sound of the QV with the top down is one of the finer things in life. Then then next issue comes up. Repeat.
    If you love the car and there are reasons that can be interpreted as valid to keep and maintain, then just budget accordingly. There is no financial sense in owning and maintaining a Ferrari. There must, however, be an allocation of resources sufficient to support the passion.
  4. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Ah I see, I get it now. is the 22K he quote you *include* the $3,700? or is it on top? (so 25,700 total?)
    what does the 22K include? Is it just the engine rebuild? You'll no doubt encounter the (while I was in there) stuff too.
    Best wishes!!!
  5. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    #30 166&456, Aug 16, 2017
    Suspicious indeed. I never trust shops that come with such bad diagnoses.
    First how long did it sit do you know?
    Then, pistons don't rust. Liners do, piston rings a little less so. Yet liners are pretty well protected by oil film against corrosion and bearings are a bigger risk with the diagnosis you were given. It needs to be pretty badly leaking and been standing for quite a long time for it to do serious damage that cannot be cleaned up. Even then it is probably limited to one cylinder. Still a lot of work but a $5-7k job not $20k+.
    Did the engine turnover when cranked or did you never try?
    I would see if you can find a good trustworthy mechanic and send him to the shop for a second opinion.
    Interesting gift �� for sure. :)
  6. dfranzen
    dfranzen Formula 3
    Aug 31, 2013
    1,577
    Ponte Vedra Beach , FL
    Don Franzen
    Greg W
    Please post a few more times in this thread so your private message will work
    I have info for you
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    One thing that stuck out in the original post/description was the use of the word "water" in the oil. The car previously living in NY would not (should not) have straight water in the cooling system. It should have a coolant mix. If the shop only detected water it could be condensation from long term storage. Just a thought, but just from the info posted on this this shop IMO get a second opinion
  8. alexion
    alexion Formula 3
    1,313
    New York
    I'm still perplexed as to the $3700 cost for the shop to tell you that you need an engine rebuild. What exactly was done for $3700? A PPI-like inspection should have revealed the issues mentioned, one would think.
  9. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    #34 thorn, Aug 17, 2017
    Bingo. They're not really doing you a favor offering $15K. For them it's a straight-up profitable flip opportunity. (We'll use the term "flip" loosely here, as a flip implies the car would be improved before resale.) If you choose to sell as-is, you can take some average pics yourself and list it for $35K just as BHCC will. The same buyers will be looking at it.
    That's my first question, too.
    OP said "they were going to do X, Y, Z, but then drained the oil and saw water."
    Ok, so they drained the oil. I'll do that for free, takes about 5 mins. Where's the $3700 been billed?
  10. Greg W
    Greg W Rookie
    Aug 13, 2017
    11
    Carlsbad, CA
    First off, You guys are awesome and I love this site. I have taken your advice to heart and used it. I am looking for a crashed QV to take the motor and use any parts that need replacing getting mine back on the road. Also when the car first arrived, I replaced the battery, pulled the plugs and added a dash of oil to each cylinder and spun the motor. I put the plugs back and it would fire (with a spray of starting fluid) but it wouldn't start. I had a fuel problem, gummed up lines, filter or pump (No fuel pressure). I didn't spend much time on it knowing it was going in for a complete service. A lot of people asked if I was able to turn a wrench and I can, but basics only. I built a Ford 351 motr 20 years ago and I used to build VW motors in high school. I will say the italian motor intimidates me I am planning in getting a shop manual if I get it going ans I will work on getting to the point that I can do the 5 year belt changes.
    I met a wonerful old guy named Bill, who used to have the only certified Ferrari shop in Santa Monica CA. he know the 3.0 qv better than I know my kids. He recommended doing a compression test on the cylinders, and then pressure testing the cooling system. He said it could narrow down the top end or bottom. He bet it was a head gasket since it was running fine when it was parked and that the cylinder o-rings dry out and get hard, but rarely fail.
    Next he said if the cylinder pressures don't tell you what is wrong, refill the oil and get it runing.
    If it leaks coolant into the oil he said when you drain it if it smell like combustion vapors are detected its the top end, pop off the heads and replace the gaskets. If it's the o-rings then it gets expensive.
    Nice old guy, He said "I can tell you are already a Ferrari Guy, they love their cars". he said the sound of the qv is pure Ferrari, it's not a powerhouse, but it's pure! I tried to direct message but couldn't get it to go. I will post my e-mail if anyone wants to contact me directly. If anyone hears of a donor let me know.
    Thanks for all the advice.
    [email protected]
    (760) 685-0576
    paulchua likes this.
  11. Mechanical Dad
    Mechanical Dad Formula Junior
    Aug 30, 2016
    381
    East Aurora NY
    Josh
    I looked for one that needed work. Best way to learn about your car. I've been a mechanic now for over 25 years and my mondial has been my most rewarding project to date. The guy I bought it from had offers from dismantlers, but chose to sell it to me because I was going to save it. Mine suffered a lot of "neglected maintenance". It now live the sweet life it always deserved.
    Sent from my SM-G930V using Tapatalk
  12. MalcQV
    MalcQV F1 Rookie
    Oct 11, 2004
    3,292
    Manchester, UK
    Malc Holden
    :) Nice to hear.
  13. beng
    beng Formula Junior
    626
    RSF, California
    Benjamin Galdston
    Greg, I have a rebuilt quattrovalvolve Mondial engine I can sell. I'm local. Let me know if you are interested in it. [email protected]
  14. Greg W
    Greg W Rookie
    Aug 13, 2017
    11
    Carlsbad, CA
    Update, I have had great support and input from this community, and it's a group I have chosen to join. I am going to look at the motor from beng, swap motors and get the 85 on the road. Another f-chatter has agreed to help me rebuild the original motor. I'ii decide later whether to swap, keep or sell the extra motor.
    MalcQV and paulchua like this.
  15. Greg W
    Greg W Rookie
    Aug 13, 2017
    11
    Carlsbad, CA
    latest update. Great input and support from fchatters. beng offerd his extra qv motor for sale but recommended his mechanic look at my motor first to get a solid quote. he called his mechanic and sent me his mechanics info. I called him last week and he put me on the list. I will post an update when I have one. Now I need to start looking for new set of tires and wheels to replace the old metrics. Image Unavailable, Please Login
  16. srephwed
    srephwed F1 Veteran
    6,471
    street,md
    fred brown
    Certainly is a nice 20 footer. I wish you luck. You will enjoy the car in the end. I put 360 modulars on mine. I think they look pretty cool Image Unavailable, Please Login
    Greg W likes this.
  17. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    car looks great! hope everything works out for the best for you!
  18. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    29,552
    E ' ' '/ F
    Trailer Swift
    348 wheels are usually cheap, take modern rubber, and actually look pretty good on Mondials
  19. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    Car probably has a seized fuel pump. Pull the air filter housing off, turn the key to the run position, then press down on the air vane. You should feel some good pressure there, and hear the fuel pump start buzzing when you press down.
    Early Mondials are easy to work on yourself. The Cab has an access panel for the motor from the interior behind the rear seats. How cool is that ?
  20. mx5mike
    mx5mike Rookie
    Oct 4, 2009
    8
    Couldn't the moisture in the crank case be from sitting? I have bought a few cars that sat for a few years that had milky oil in them, and after a full service; a couple oil changes and some miles they were fine.
  21. Greg W
    Greg W Rookie
    Aug 13, 2017
    11
    Carlsbad, CA
    Well It's official. I tapped out and sold the car as is. I have waited for the shop in Hillcrest to have it's access road finished and they still couldn't get the car in. I started to realize that just finding the right shop was going to be a challenge. Time to look for another project, this time one that's running. I have about 6k in parts to get rid so I will post that on the other thread.
    Greg
