Sold - 71 Triumph TR6 | FerrariChat
Sold 71 Triumph TR6
Discussion in 'Other Cars' started by ktr6, Aug 4, 2017.
Thread Status:
Not open for further replies.
  1. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    #1 ktr6, Aug 4, 2017
    1971 Triumph TR6
    This car has undergone a complete nut and bolt restoration over the past two years. The goal during restoration was to create a fast, reliable, excellent handling TR6 that maintained the purpose and aura of the original car. If you are a purist read no further as this car is far from original, if you are someone that appreciates purposeful upgrades to maximize a platform please read on. No expense was spared on this car, it has been well sorted and is ready for the next owner to enjoy. In this situation my loss if truly your gain.
    The restoration began at a shop called Hot Rods 101 located in Upstate, SC. The body was separated from the from the frame and both were media blasted to bare metal. The frame was in excellent shape and checked for symmetry/crash damage and checked out very nicely. The mounting pins for the differential were replaced and reinforced and the frame painted black. The body was also in excellent shape other than a fender that had been body worked, a rusty rear valence, and floors that had seen better days. The aforementioned body parts were all replaced with new metal, gaps aligned (better than factory) and the car was primed/painted using PPG base/clear coat. Final assembly of the car was completed and then sent to Flying Circus Motors in Durham, NC for sorting. Below is the build list for the restoration.
    Car is currently located in Anderson, SC. Please feel free to contact with any questions. Price is 29k.
    Exterior:
    -Jaguar Racing Green Paint
    -PPG Sapphire Base/Clear Coat on bare metal respray
    -Stainless steel bumpers
    -New Windshield
    -New convertible top with zip out rear window
    -All rubber seals replaced
    Engine:
    -All machine work performed by Clements Race Engines in Spartanburg,SC
    -JE forged pistons with an 8.25:1 compression ratio (20 over)
    -Block line bored and Cam Shaft bearings installed
    -Wishbone Classics Supercharger Camshaft, tappets, valve springs
    -Bronzed valve guides
    -Moss Motors Supercharger kit with high compression pulley
    -Custom cold air intake system with Richard Good air filter relocation kit
    -New oil pump
    -Case modifications for increased oiling
    -All rotating mass balanced
    -PRI light weight flywheel
    -123Ignition electronic distributor with dyno tuned curve
    -Alloy valve cover
    -Goodparts 1.55:1 Roller rockers
    -ARP head studs/flywheel bolts
    -Head oil feed line
    -Crank case vent with catch can
    -Goodparts PCV Valve with catch tank
    -New motor mounts
    Exhaust:
    -Wishbone Classics stainless header
    -Custom stainless exhaust
    -Dual mufflers
    Transmission/Differential/Axles
    -HVDA 5 speed transmission conversion
    -Modified driveshaft with new U Joints
    -Stainless clutch hydraulic line
    -Nissan R200 limited slip differential with 3.69:1 ratio
    -Goodparts CV Joint Axles (major improvement)
    Fuel System:
    -All new 3/8 fuel lines
    -Holley electric fuel pump
    -Aluminum fuel tank
    Cooling:
    -Wizard Cooling radiator
    -Electric fan (thermostatically controlled with override switch)
    -Richard Good polished aluminum radiator shroud
    -Custom radiator catch can
    Wheels/Tires:
    -Minilite replica 15x5 wheels
    -New Kumho Tires size on all 4 corners
    Electrical:
    -Advanced Auto Wire wiring kit
    -Inertia cut off switch
    -123 Electronic Distributor with custom dyno tuned ignition curve
    -Lucas Sport Coil
    -Bosch Spark Plug WIres
    -NGK Plugs
    -Autometer Sport Comp Gauges
    -Calibrated fuel sending unit
    -Gauges-Speedo/tach/fuel/water temp/vac-boost/voltage/oil pressure/wide band Air:Fuel
    -High torque mini starter
    -GM alternator Conversion
    Interior:
    -Victoria British biscuit interior kit
    -New wooden dash
    -New dash cover
    -New under dash cover
    -New center console cover
    -Mountney Leather steering wheel
    -Custom metal transmission tunnel cover to reduce chassis flex
    Brakes:
    -Rebuilt front calipers
    -Stainless steel brake lines
    -Brembo front rotors
    -New shoes/pads etc
    -Rebuilt brake master/booster
    -New hard brake lines
    -New shoes
    Front Suspension:
    -All pieces powder coated
    -GAZ adjustable shocks
    -Moss Blue performance springs
    -Goodparts 7/8 sway bar
    -New bearings etc
    -Nylatron bushings
    -Aluminum steering rack mounts
    Rear Suspension:
    -Goodparts adjustable trailing arm mounts
    -Revington TR 5/8" adjustable rear sway bar with spherical bearings
    -Revington TR rear shock conversion kit (shock in spring) with adjustable shocks
    -Nylatron Bushings
    Also included:
    -Bentley Manual
    -Haynes Manual
    -Indoor car cover
    Vendors:
    goodparts.com
    roadster factory
    moss motors
    Revington TR (UK) revingtontr.com
    Wishbone classics
    Advanced Auto Wire
    123Ignition.com
  2. dm_n_stuff
    Wow!! Did you dyno it after the conversion was finished? That must be a blast to drive. I had a buddy who raced vintage Brit cars hot rod a TR6 for me back in the day and it was a scary thrill to drive.
    Good luck with the sale!!
    D
  3. dwhite
    dwhite F1 Rookie
    Beautiful car. Does it have AC? I've been toying with the idea of having something like this (an updated British classic) in FL.
    A buddy is doing one and he transplanted a ford 2.3 liter turbo 220 hp. I just finished helping him put in a new interior.
  4. dm_n_stuff
    Most often they do not. And I can tell you from personal experience, this is not a car you want to drive in 80 degree weather, much less 90+ FL weather, unless you can guarantee that you'll keep moving at 40 MPH or better.
    At least in my case the car had the hottest cockpit I've ever ridden in. I'm sure there may be ways to mitigate it, but damn, it was hot in there.
    Retrofit isn't impossible if you find the right car.
    http://nostalgicac.com/complete-ac-kits/british-ac-complete-kits-accessories/triumph-complete-kits/complete-triumph-tr6-a-c-system.html
    D
  5. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    Sorry no AC in this one, although it would be nice! Yes we dyno tuned the car as we set the ignition curve, Ill see if I can find and will post it. The supercharger really made the car come alive but allowed me to keep it somewhat British.
  6. rdefabri
    rdefabri Three Time F1 World Champ
    Jun 4, 2008
    33,571
    NJ
    Rich
    I'd be interested too - a Nissan R200 is a fairly robust rear end, so I'm guessing it's putting out something decent?
  7. BoxerCrazy
    BoxerCrazy Formula Junior
    Nov 7, 2002
    355
    Charleston WV
    Douglas A Hunt
    very nice, one of my younger brothers high school buddies has one, though its not nearly as nice as this, re: no supercharger etc !!!!!
  8. daviday
    daviday Formula 3
    1,623
    New York
    Davide
    Beautiful little car. I was playing with one last weekend. It needed A LOT of work to get to near where you are with this one so your price seems very realistic IMO. Just have to find the right buyer.
    I was actually a bit embarrassed to be honest, it took me a solid 10mins to find reverse. Cool little car. Good luck with the sale.
  9. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    #9 ktr6, Aug 4, 2017
    Thank you everyone for the compliments, its a very unique 6 and hopefully can find someone that will take care of it the way I have. Here is an image from the last chassis dyno run we made. Air fuel ratios were good, we tuned ignition timing very conservatively to keep things safe. These cars made 104hp/142tq at the flywheel from the factory and with the changes we made we made 177hp/185tq at the wheels. If you follow the 15% rule we made roughly 203hp/212tg at the flywheel. Definitely not a rocket ship but tons of fun
  10. Texas Forever
    Texas Forever Seven Time F1 World Champ
    76,213
    Texas!
    There's no insulation on the fire wall.
  11. KM1959
    KM1959 Formula Junior
    Nov 12, 2014
    984
    Kevin
    But can be very easily remedied for $10 and 2 hours time.
  12. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    LOVE it. Basically exactly what I'd want to do with a TR6. Only thing I'd change would be to go back to the original gauges, even though I know they don't work as well. Good luck on the sale! I gotta say it's tempting....
  13. UroTrash
    UroTrash Three Time F1 World Champ
    Jan 20, 2004
    38,989
    Purgatory
    Clifford Gunboat
    Tempting....and close....resist....
  14. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    It would make great company for your bugeye!
  15. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    Looking at this car brings tears to my eyes --- in a wonderful way.
    My first car, at age 17, was a '71 TR6 that belonged to my Father and which we restored together as a Father-Son project.
    Identical to this one here except ours had black interior, and no mods.
    Looks like this one could actually be driven farther than you would want to walk though...... without fear of breaking down all the time ! :)
  16. JG333SP
    JG333SP Formula 3
    Mar 24, 2010
    1,871
    N Shore, MA
    Jim G
    A buddy of mine had 2 of these he was restoring a couple of yrs ago and probably would have just bought this if it was around then. I'm not sure if he still has them or moved on to other cars-the dude's owned just about everything.
    Wow that's a bunch of power in one of these
  17. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,814
    Tinton Falls, NJ
    Bob Ferraris
    #17 drbob101, Aug 7, 2017
  18. cmparrenzo
    cmparrenzo F1 Rookie
    Mar 3, 2002
    2,686
    Kansas
    Chris Parr
    Firewall is insulated on the inside, not on the engine side.
  19. RedlineG60
    RedlineG60 Formula 3
    Dec 25, 2003
    1,133
    Simpsonville, SC
    Andy Thomason
    Keith is a top notch gentleman and I have seen this car in person. It is a very cool example of an already unique car!
  20. GBTR6
    GBTR6 Formula Junior
    Dec 29, 2011
    452
    Titletown, USA
    Perry Rondou
    If you call a felt/horsehair underpad insulation. I have a 74, and it doesn't help much. And I'm in Wisconsin.
    Perry
  21. cmparrenzo
    Mar 3, 2002
    2,686
    Kansas
    Chris Parr
    I agree, I would use Hushmat on the firewall and floors and this car may have it, just hidden, it would greatly reduce the heat.
    The trans hump really gets hot, again more Hush mat! ceramic coating on the exhaust system would also help, I can remember thinking my shoes were going to melt!
    I had a green '71 with a black interior, my 2nd car, I would love to have another one.
  22. eyeman1234
    eyeman1234 Formula 3
    Dec 25, 2006
    1,881
    Boca Raton, FL
    Whoa looks like fun! GLWS
    Had a 66 TR4A
    Both raw and old school!
  23. ktr6
    ktr6 Formula Junior
    Mar 25, 2011
    947
    Knoxville, TN
    Keith
    Thank you everyone for the positive comments, open to offers and possible trades.
  24. pearsonhaus
    pearsonhaus Formula 3
    Jul 2, 2008
    1,464
    Really nice car!
  25. scudF1
    scudF1 F1 Rookie
    2,866
    Long Island, NY
    Billy
    Nice! GLWS
