Zinc coating for brake rotors... | FerrariChat
Discussion in 'Technical Q&A' started by The Outcast, Nov 19, 2011.
  1. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    I want to take my existing rotors (which have maybe 8K miles on them) and do two things:
    1) Have any corrosion removed, preferably by a "dip" process.
    2) Have them black Zinc coated.
    Anybody know anything?
  2. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Seems like the coating would eventually just wear off... wouldn't it?
    (By the way, I know absolutely NOTHING about zinc coatings).
  3. m5guy
    m5guy Formula 3
    Aug 17, 2008
    1,627
    Ventura, CA.
    Greg
    When you send the rotors out to have them Zinc plated, the first step for the plater is to clean them (normally in a soapy water bath, then rinse), followed by a chemical dip (not sure if it is acetone based) that preps the object for the actual electroplating. No need to send them somewhere in advance for corrosion removal unless the rotors are so bad that red rust has formed inside the vanes and metal is flaking off. If the rotor is that extreme, you will want to have them media blasted, but the braking surfaces need to be masked off prior to blasting.
    Black Zinc is not as common as clear Zinc or gold Zinc in my experience. I believe the actual color is obtained in the last dip tank which is the chromate tank.
  4. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    I replaced my discs about six months ago - all nice an shiny. Anyway three weeks later the non wearing surfaces started to rust up like the old ones I'd taken off. I got a couple of rattle cans of high temp black matt paint, masked off the wearing surfaces and give the rest of them a right good number of coats. Five months on, including 600 miles on track and the paint is holding up 100%.
    Might be an easier/cheaper option.
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,632
    Why?
    Rotors are meant to have brake pads asserted with great force and in the consequence wear. Any surface you put on the otors will ONLY retard the abity of the rotors to retard the speed of the car.
  6. The Outcast
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    The coating on the contact surface is eliminated with about 30 minutes of brake use. All other surfaces retain the coating and are resistant to corrosion. That's why I want to do this.
  7. The Outcast
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    I'm going to check into this. Thanks buddy!!
  8. darkkaangel
    darkkaangel Formula 3
    May 20, 2007
    1,265
    North Texas
    Jeff
    #8 darkkaangel, Nov 19, 2011
  9. m5guy
    m5guy Formula 3
    Aug 17, 2008
    1,627
    Ventura, CA.
    Greg
    Wow, that looks good Jeff! Looking forward to seeing your car on TV.
  10. tajaro
    tajaro Formula Junior
    Mar 22, 2009
    685
    Gulfport Florida
    Erik V
    Great job. Another process I use is to wire brush the non contact surfaces to a nice shiny polished look and spray with a high temp clear coat. Especially two piece rotors with rivets- this process looks awesome too.
    I hate dirty or corroded looking rotors and this is such an easy fix!
  11. mwr4440
    57,708
    Bavaria, The 'Other' Germany
    Mark W.R.
    I DO NOT KNOW FOR A FACT.
    However, smarter guys than I have reported to BE VERY CAREFUL with ANY plating process as most of the quick-n-easy and not so quick-n-easy plate processes used today can embrittle the plated part thus rendering things like brake calipers useless or at least suspect.
  12. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,301
    +1 on this.
    I would not comtemplate plating brake discs/rotors. Theoretically you can plate & then de-embrittle by heating the parts for an hour or so in an oven, but i just wouldn't risk it with brake disks. Paint is the way to do it.
  13. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Chrome plated rotors are common place on motorcycles (and not just show bikes). So while I'm not an expert on rotors becoming brittle because of a plating process, it's obviously done in other road going applications.
    I'f I were to do it, I'd go with the POR15 paints/process. I've had many good experiences with using their products.
  14. mwr4440
    57,708
    Mark W.R.
    Either they are using the correct TIME and MATERIAL CONSUMING process or ......... :eek:
    I'd like to belive they are using the right process as embrittelment is a well known situation in the serious side of the business.
    So I have been told.
  15. The Outcast
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    Zinc plating process is nowhere NEAR deep enough to alter the metallurgy of the rotor...it's a "wash and dip" process, not a diffusion or sublimation process. This process is becoming quite popular, and several vendors sell brand new zinc-plated rotors...the difference here is that I was looking for a shop that could plate my existing rotors. The rotors were shipped off to be plated on Wednesday. I'll post photos when I get 'em back.
  16. 350HPMondial
    350HPMondial F1 Veteran
    5,281
    Edwardo
    #16 350HPMondial, Nov 28, 2011
  17. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,316
    Palos Verdes
    Vince V
    Ooh, cad plating, urrrrll, drool drool....
  18. BDCVG
    BDCVG Formula Junior
    Apr 9, 2007
    262
    Cincyish
    Brad
    Above post looks not good ^^^^^^
  19. 350HPMondial
    5,281
    Edwardo
    Yes, grease needs cleaned off.. but, they Are CAD plated inside the cooling vents also.
    Let's see your rear rotors...?
    Edwardo
  20. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    #20 chrismorse, Dec 14, 2011
    One of the things Martin, (at Girodisc) suggested, while we were developing the big brakes for my 308, was to turn the old front rotors and have them zinc washed. They were new looking when i got them back, just like the new rear 360 discs.
    The on edge shot shows the old disc and the turned, zinc washed used F-50 disc. The upside down disc is a new 330x24 360 rear disc on a custom hat.
    The 4 disc shot is new/old.
    The rotor working surface is quickly worn to the base metal, but the edges and vane interiors remain rust free.
    I do not recall the cost for having it done, but if you are interested, i would suggest you contact Martin at Girodisc - great guy to work with.
    HTH,
    chris
  21. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    My guess is that rust scale inhibits the heat transfer and so, zinc plating/washing will help maintain maximum heat dissipation. Doesn't look too bad either :)
    I recall from my air cooled days that a black body, (thin finish) is more efficient than polished or silver colored. I forgot how much, but it was significant, so, if there is a black zinc, or a durable thin high heat paint that can be applied to the interior of the rotor, that would be the best possible heat transfer.
    chris
