Yet another CTEK Battery tender question | FerrariChat
Discussion in '360/430' started by AlgaeHater, Dec 16, 2014.
  1. AlgaeHater
    AlgaeHater Formula Junior
    Sep 22, 2004
    321
    Bellevue, WA
    #1 AlgaeHater, Dec 16, 2014
    I recently replaced the battery in my scud with a new Optima 34R. When I hook up my factory battery tender to it, the "half battery" or "full battery" charging indication LEDs do not turn on, even after days of being plugged in. Only the amber/red on LED remains lit.
    I noticed this was also the case prior to swapping out my battery. Is my tender dead?
  2. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  3. AlgaeHater
    Sep 22, 2004
    321
    Bellevue, WA
    I read somewhere that the OEM rebadged CTEK 3300 has a hard time charging Optima AGM batteries - this is unusual considering my '08 scud came with the Optima 34R from the factory. I'm reluctant to go with another tender because I won't be able to use the factory charging receptacle under the dash. My new 34R cannot be nearing it's life - I just changed it yesterday :)
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    That's what I mean...its a simple system, there's the battery, and the tender.
    So if the battery is new, then the only other part in play is the Tender.
    Dan
  5. AlgaeHater
    Sep 22, 2004
    321
    Bellevue, WA
    Just measured my new battery with a voltmeter - measuring 11.9V with the engine off. In other words, the battery is fine. I also noticed no change in voltage when I plug/unplug the battery tender.
    At this point, I think the tender needs to be replaced. Just wondering if anyone with the exact same OEM tender has experienced extended periods with no charging LEDs lit.
  6. sunir
    sunir Formula Junior
    Oct 30, 2014
    758
    MD
    Sunir
    For optima or odyssey batteries you have to put it into the snowflake mode the ctek 3300 has that. The Ferrari charger looks to be a ctek 3300 with just one mode. On the factory battery you'd use the car mode, so I'm guessing the default only single mode is on the Ferrari charger is the car mode. The ctek 3300 has 3 modes - motorcycle, car, and snowflake.
  7. Jonsav
    Jonsav Formula Junior
    Sep 26, 2014
    338
    Canada
    Same deal with mine. I just ordered a new tender.
  8. timba
    timba Formula Junior
    Aug 20, 2012
    258
    Nor Cal
    Tim
    I'm no expert, but hey, it's the internet so I feel qualified to chime in:
    I believe 11.9 is low for a resting voltage and does indicate a less than 1/2 charged battery, so I'm not surprised the 1/2 or Full LEDs are not on. The Ferrari badged charger is a rebranded Ctek 800 which is truly a trickle charger with a charging current of 0.8 Amps. The Ctek 3300 has additional modes including one for AGM batteries and a charging current of up to 3.3 Amps. For your AGM Optima battery, it seems that a Ctek 3300 would be a better charger for you. The connector used on the Ferrari charger is not proprietary. I purchased one from Newark.com.
  9. yronZFF
    yronZFF Formula Junior
    Dec 21, 2009
    749
    FIVE-O
    Ron
    I've been using a CTEK 3300 for the past 5 years on my 430 (and previously my 355) and just recently (2 weeks ago) bought a new CTEK MUS 4.3 from an Fchatter that has a bunch of new ones for sale at a great price ... $58 shipped. I intend to use the 4.3 for my 430 and the 3300 for my boat battery. I believe he still has a lot more for sale.
    Here's his ad. Go to the bottom of this thread and you can see that he's still selling the 4.3.
    http://www.ferrarichat.com/forum/other-parts-collectibles/438686-ctek-battery-chargers-discounted-prices.html
  10. AlgaeHater
    Sep 22, 2004
    321
    Bellevue, WA
    Thanks everyone for your responses.
    I assumed that the new Optima came charged. I guess what's needed is a long drive to charge up the battery. I'll then try and put the tender on it again.
  11. sunir
    Oct 30, 2014
    758
    MD
    Sunir
    ^^^ new batteries do come charged. Including Optima. I've used a Red Top on my race car and have a smaller dry cell Odyssey lightweight battery in my GT2 which also came charged, the AGM are the same way. All of them come charged and respond well to ctek charges. for the ones I just mentioned use Snowflake mode on the Ctek 3300 or 4.3 and for factory/stock batteries use the 'Car' mode on the 3300/4.3 chargers. These will maintain your battery indefinitely and charge it when low, you can even charge a dead battery with these...and you never run the risk of over charging with these smarter chargers!
  12. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You are absolutely correct. All batteries now come precharged especially AGM batteries.
    Drive your car for an hour to the grocery store and it will be fully charged.
    I am anal so when my Optima AGM battery arrived I hooked it up to my battery charger before I installed it to my 360 and in 1 hour charger said its fully charged and I measured 14.7 volts.
    Optima = excellent battery. I highly recommend.
    Dan
  13. AlgaeHater
    Sep 22, 2004
    321
    Bellevue, WA
    I ordered the NOCO 3500. Thanks for the suggestion, Dan.
  14. Caeruleus11
    Caeruleus11 F1 World Champ
    11,410
    Looks to me the OEM tender here is the 800 version of the Ctek (0.8 amps). That cannot do AGM batteries. I don't think the factory Scud battery was AGM. The 3300 can output up to 3.3A. And it has the snowflake mode which is appropriate for the AGM battery. The 7002 model is a better choice still as it has better conditioning modes. It can also output up to 7A. Not sure about the other tender but if it works for you then that's a good move.
  15. AlgaeHater
    Sep 22, 2004
    321
    Bellevue, WA
    You are correct it is a rebadged Ctek 800 which I'm learning struggles with AGM. However, my scud did come from the factory with an Optima 34R. Strange that Ferrari would pair these two together. Italian engineering for the win.
  16. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    See this post: http://www.ferrarichat.com/forum/141102598-post12.html for where to order the connector and how to connect it to a standard c-tek battery tender, so that it maintains the no-start with tender connected feature (using the stock tender socket on the car)! Read further posts in the thread by the poster for additional details. I just ordered and received the parts from Mouser, about $15: stock connector onto a c-tek tender for use on the stock tender socket on my 612. Do it at your own risk, etc.
  17. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You are most welcome.
    I think you did the right thing. Just order the NOCO battery tender that we know works great with the Optima and be done with it. Issue solved. Your time is worth a lot more trying to figure things out.......
    Let me know if I can help.
    Dan
  18. Caeruleus11
    11,410
    Very nice information here. I guess they went with the light weight option for the Scud battery. Fascinating stuff. And great information on the battery tenders.
  19. AlgaeHater
    Sep 22, 2004
    321
    Bellevue, WA
    Just received my NOCO charger and wired it up to the leads behind the driver seat. Plugged it in and voila!, charger works. Thanks again for the recommendation.
  20. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    You are most welcome! Glad We can help.
    Merry Christmas to you and your entire family.
    Dan.
  21. Wisky
    Wisky Formula Junior
    Nov 13, 2006
    272
    Fort Lee NJ
    David
    My ctek battery charger has a button to cycle between Motorcycle, Car, and Winter mode... without pressing the button the amber light stays on and it does not charge the battery. FWIW, I have never had a problem with my unit and it was only like $40 on ebay.
  22. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for the info David.
    Which CTEK battery charger model do you have?
    Dan
  23. Wisky
    Nov 13, 2006
    272
    Fort Lee NJ
    David
  24. scudF1
    scudF1 F1 Rookie
    2,913
    Long Island, NY
    Billy
    To find the charger is the easy part. What about the male plug that goes into the car socket?
  25. timba
    Aug 20, 2012
    258
    Nor Cal
    Tim
    #25 timba, Dec 27, 2014
