x-pipe addition | FerrariChat
x-pipe addition
Discussion in 'FF/Lusso' started by f12tm, Dec 23, 2016.
  1. f12tm
    f12tm Karting
    Nov 26, 2014
    94
    North Carolina
    I see various vendors that show the x-pipe exhaust product for the F12... if one tries to see or hear what the product does for the sound or performance on it's own, it's not shown... it always seems to be combined with other components in sound bites ... so if anyone can help me understand what you get for a couple of grand (other than a real pretty pipe) I sure would appreciate an explanation...Tks
  2. rockitman
    rockitman F1 Veteran
    May 31, 2015
    5,982
    Upstate, NY
    Christian
    Me too. I want to know if the x-pipe does anything meaningful with the rest of the exhaust stock.
  3. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    I had it on my FF with stock exhaust. Extenuates the higher end and softer and idle. However I've since added Capristo rear boxes and it's a must!
  4. not4one
    not4one Formula Junior
    May 23, 2010
    887
    CT, FL
    Count me in on wanting to understand more about the options. The stock is fine for my ears above 2500 rpm, but it has an annoying dull drone at lower revs and at idle that is not dignified in anyway, more like a farm animal giving birth. It's enough to make me turn the car off at a 3-4 minute red light.
    Dealer offered to open the flaps for me at delivery...I deferred, but have a feeling it would have actually made the interior of the car quieter...or maybe an x-pipe would get rid of the drone? On the other hand, not eager to lose torque at low speed by not having enough back pressure.
  5. not4one
    May 23, 2010
    887
    CT, FL
    Could you add further to your comment about "softer and idle"?
  6. AutobahnAndTrack
    AutobahnAndTrack Formula Junior
    Dec 31, 2014
    307
    Frankfurt, Germany
    Stefan G
    #6 AutobahnAndTrack, Dec 23, 2016
    I have stock mufflers on the F12 and added the capristo x-pipe and remote control for the flaps after a couple of month driving around stock.
    Will record a video sound clip in January.
    Difference is not huge but noticeable. Sometimes I like the new sound better, other times not. Not sure about the low rpm drone being reduced, at least a bit I think.
    What I don't understand is aftermarket mufflers sounding better then stock mufflers with open flap. When flap is open it is like a straight through pipe, so no reason for the aftermarket to be louder or sound different as long as cats are stock.
  7. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    More quiet "with flaps closed"...I'm no physics expert but something happens with the sound when the pipes cross (x-pipe) as opposed to coming straight down (stock H piece) and out on each respective side of the engine banks....and I still don't understand why they are louder and "crisper" than stock exhaust with valves open, doesn't make sense as it's open all the way through when valves open.
  8. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    X-pipe definitely reduces (not completely remove) the drone, no doubt
  9. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,837
    East Yorkshire
    Justin Kenyon
    #9 kenyon, Dec 26, 2016
    The only way is decat and have the valves open all the time.
    Sounds like a F1 car -FXX, no droning in the cabin, but screams at 130 db at full rpm. Pure F1 noise all the way through rev range and gears.
    No CEL as installed the novitec box of tricks which is a plug and play onto the OB socket under the steering.
    The car spits flames, pops and bangs on overrun.
    I have had all the light weight V8 ferraris which have all been decatted on their standard exhaust and its the only for that F1 noise.
    Buying after market exhaust systems is in my mind a waste of money and adds very little.
    Novitec decats and the box of tricks is all you need. The decats are expensive but pure qaulity with the insulation on them too. Engine temp has dropped around 7 degrees and more response, power increase and weight saving too.
  10. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Amazing, and very tempting! Hoever I Don't think I would pass emmisions or sound test let alone the police who don't love loud exhausts
  11. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,837
    East Yorkshire
    Justin Kenyon
    #11 kenyon, Dec 26, 2016
  12. ttforcefed
    ttforcefed F1 World Champ
    18,872
    I have the novitec x pipe on my ff. I also have novi hi flow cats and exhaust. when flaps ae closed it sounds stock, you have no idea the car has a full exhaust on it.
  13. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Even with the NR sport cats ? My F12 is very loud with that setup, hence my resistance to the sport cat upgrade on FF
  14. ttforcefed
    18,872
    yep the car is just like oem when flaps are closed. I have BT conversations all the time. I had novitec program the ecu so that in sport the valves are open full time and it comfort and lower they only open at a percentage of throttle like oem
  15. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    I have NR ECU upgrade on both FF and F12 and I am most certain they are always programmed as you state above....impossible to have a BT convo in my F12
  16. ttforcefed
    18,872
    that's odd - is an f12 much louder than an FF if both are oem?
  17. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    For sure a difference, big one. My FF with x- pipe and capristo boxes is much quieter than my F12 was before sport cats were added
  18. ttforcefed
    18,872
    ah OK. makes sense given the roles of each model in the line up
  19. AutobahnAndTrack
    Dec 31, 2014
    307
    Frankfurt, Germany
    Stefan G
    Anyone comment on difference the NR ECU upgrade makes?
  20. ttforcefed
    18,872
    maximize fuel curves, increase air flow from exhaust etc. I did it more because I wanted the manetino to have specific settings for the exhaust flaps
  21. boostorbust
    boostorbust Karting
    Jan 27, 2013
    71
    I have Novitec catless downpipes and a Capristo with X-Pipe. As previous posters have said it's the most glorious sound you ever heard.
    One problem though.... the car stinks everything up and cruising around with the windows open you can get scents of the exhaust fumes, gets on your clothes and sticks to them
  22. ttforcefed
    18,872
    why not use the hi flow cats then?
  23. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    That's is a good solution for the smell issue. I'm always surprised when the exhaust modification threads comes up. So may say "Go catless", but few remembers to mention that the car will stink like an old rust bucket. And yes, as previously said, that smell will contaminate not only ones clothes, but also the cabin over time - and it's not a pleasant smell.
  24. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    #24 F12KID, Dec 29, 2016
    You mean like 100 or 200 cel "sport cats"?
  25. DK308
    DK308 F1 Rookie
    Aug 13, 2013
    2,738
    Europe, way north.
    AB
    Yes. 100 or 200 cell cats.
