Wing Window Latch Adhesive | FerrariChat
Discussion in '206/246' started by RMRClub, Nov 8, 2018.
  1. RMRClub
    RMRClub Rookie
    Mar 7, 2008
    44
    Colorado
    While playing racket ball in the Dino, accidentally hit the wing window latch. Any advice on the best adhesive to remount Image Unavailable, Please Login ? Thank you
    UroTrash likes this.
  2. pshoejberg
    pshoejberg Formula 3
    1,694
    Denmark
    Peter H
    It looks like it has been repaired before and modified with a larger square base. I recommend to lightly sand the glass and base with a dremel grinder stone and use a two komponent epoxy glue.
    Best Peter
  3. HMB-Dino
    HMB-Dino Formula 3
    2,167
    Pebble Beach, CA
    RonG
    I have found that Loctite 233841 Super Glass Glue works just fine.
  4. RMRClub
    RMRClub Rookie
    Mar 7, 2008
    44
    Colorado
    Thank you, I'll give it check.
    have a great day
  5. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,149
    Iain
    Loctitie 326 in conjunction with Loctite 7649 activator works extremely well. All of the quarterlight window catches in my Dinos are mounted using that and only one has fallen off in the last 6 years. A bit of cleaning and then re-fitting using these products has seen it stay firmly in place for the past 2.5 years. Mounting the catch using a small shim has also helped reduce the pressure on them.
    dudlow likes this.
  6. RMRClub
    RMRClub Rookie
    Mar 7, 2008
    44
    Colorado
    Thanks all. Got some Locktite epoxy. Now, I just have to wait for the Colorado snow to let up and the temp to get a little warmer before I apply. Thanks again for all of your help. Have a great holiday season.
  7. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    I reduced the sealing pressure by hot knife trimming the black plastic striker.
    When you close the latch there is too much rise to the jamb point leading to breaking forces. Reduce those forces, trim the back side of the black plastic jamb to retain visible profile. A little tricky as it is double rivetted in blind.
    This is best done as the frame is out of the car
    Apologies for shameless use of Dino Compendium for background photo
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #8 synchro, Dec 2, 2018
    The new adhesives are far better than 1960's technology but that focus seems rather narrow.
    The systematic problem is that there is too much pressure at the latch (my adhesive held, the glass broke a dish shaped chunk off, see photo). Focusing on adhesives is the brute force solution but can we reduce the pressure overall to mitigate the use of super adhesives?
    Found a better way to reduce sealing pressure with a side bonus of access to fully clean the chrome; remove the black striker pad and grind the back down so sealing is at a lower height.
    Use a pick, remove the cover then drill out the rivets. Grind down the back side to reduce sealing pressure on the latch, rivet back in and insert cover.
    I also took the chance to add an angle to the take up ramp, polish the black plastic and clean the chrome underneath the pad
    Jon Hansen likes this.
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    Scott, what an elegant solution! It looks completely original, yet solve the issue of too much pressure on the window latch/glass. I too have re-glued the latch to the glass, only to have the pressure on the latch pop a dished sliver of glass off of the wing window. I never thought of thinning the backside of the striker pad to reduce the force. Great idea!
  10. racerboy9
    racerboy9 Formula 3
    2,499
    How did you grind the back side of the plastic piece?
  11. er72
    er72 Formula Junior
    Aug 16, 2008
    316
    Roslyn Harbor, NY
    Eugene
    Another solution is to glue the latch to a metal washer of the same diameter and then glue the washer to the glass. This will lift the latch 1 mm away from the strike plate, so there is never any tension on the latch.
    Eugene
    PS I have a few extra reproduction strike plates (3D printed). They're available on eBay or PM me here if anyone is interested.
  12. Sergio Tavares
    Sergio Tavares Formula Junior
    Nov 15, 2018
    841
    Sergio Tavares
    Can Concours judges see this as different?
