Windows wont work when the top is down | FerrariChat
Discussion in '348/355' started by PBRacer, Sep 7, 2019.
  1. PBRacer
    PBRacer Karting
    Nov 3, 2003
    154
    Virginia
    Stan
    My windows wont work when the top is in the down position. Work fine when the top is up. Is there a position detector switch for the down position somewhere. I had the top worked on a few months back. Is there something they forgot to reconnect?
  2. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    I don't have a Spider but h=this may help others, 348 or 355, Profile says 355 so this is a 355 Spider?
  3. PBRacer
    PBRacer Karting
    Nov 3, 2003
    154
    Virginia
    Stan
    355 Spider, Sorry about that
  4. Qavion
    Qavion F1 World Champ
    11,533
    Ian Riddell
    Yes, the switch is at the bottom of the main left hand hydraulic ram (track)
    Check to see if the plug is still on the microswitch or that the arm isn't bent.
  5. Qavion
    11,533
    Ian Riddell
    Challenge and Ga68_ like this.
  6. Qavion
    11,533
    Ian Riddell
    If you want to check it with an ohmmeter, the switch should open when it is pushed.
    I just realised that if the plug had fallen off, the windows should work.
  7. Qavion
    11,533
    Ian Riddell
    Any luck?
    That is to say, if you remove the microswitch plug with the top unlatched, your window function should be restored. Removed plug = open circuit.
  8. PBRacer
    PBRacer Karting
    Nov 3, 2003
    154
    Virginia
    Stan
  9. Qavion
    11,533
    Ian Riddell
    So my suggestion didn't work?
    You may need a small flat screwdriver to unclip the plug on the microswitch.
  10. PBRacer
    PBRacer Karting
    Nov 3, 2003
    154
    Virginia
    Stan
    I finally got around to fixing this. Switch is working but the little roller arm was bent back so the top mechanism wasn't pushing it. All fixed and working good for now
    Qavion likes this.
  11. Qavion
    11,533
    Ian Riddell
    Excellent. Thanks for the feedback.
