Window Switch part number | FerrariChat
Discussion in 'Mondial' started by Mfoncerrada, Mar 15, 2019.
  1. Mfoncerrada
    Mfoncerrada Formula Junior
    Dec 20, 2009
    419
    Monterey, CA
    Miguel Foncerrada
    Another thread about windows... I've searched and searched and can't figure out what part to buy to replace my window switches. I have two that have broken spring so probably not repairable.
    Car 1984 Mondial QV
    I think the PN is 64880400 (Superseding 61047700, however on ebay I see other switches described as fitting but with PN 114633 or 30073407/A. Will appreciate any light that can be shed.
    Questions:
    1. What's the correct PN for the window switch (front driver and passenger
    2. Has anyone identified the manufacturer or other cars it was used on? (i.e. alternative sources)
    3. Has anyone replaced with another switch that fits?
    4. Anyone used these imitation switches from ebay?:
    https://www.ebay.com/itm/Ferrari-308Gts-Mondial-365-Window-Switch-Pair-30073407-A-114633/273380195010?epid=1452092485&hash=item3fa6babac2:g:x4AAAOSwCGVX9b9t
    5. What about this one:
    https://www.ebay.com/itm/Ferrari-348-Mondial-LH-Door-Window-Switch-144797/132849133036?epid=14025670404&hash=item1eee6ce5ec:g:edEAAOSwYCRb5Nxy
    6. anyone tried a universal replacement that fit? e.g.
    https://www.ebay.com/itm/Universal-Auto-Car-Power-Window-Switch-5pin-DC-12V-20A-ON-OFF-SPST-Rocker/321655283172?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20131003132420%26meid%3Dd25e7bcfafa54add97cd91995aa7e89c%26pid%3D100005%26rk%3D1%26rkt%3D12%26sd%3D253935836301%26itm%3D321655283172&_trksid=p2047675.c100005.m1851
    Thanks in advance
  2. Ricambi America
    Sponsor Owner
    30073407 will work, but obviously it is not concours correct/original style. 30073407 is matte black with the white infill arrows versus the original gloss/plain switches from the last century.
  3. Mfoncerrada
    Dec 20, 2009
    419
    Monterey, CA
    Miguel Foncerrada
    Thank you for the info. I assume 30073407 will also work for the rear windows (PN 61319100 & 61319200)
    Appreciate the info.
  4. srephwed
    srephwed F1 Veteran
    7,151
    street,md
    fred brown
    I think antenna is the same switch.
  5. Mfoncerrada
    Dec 20, 2009
    419
    Monterey, CA
    Miguel Foncerrada
    does anyone know the difference between the switches with these similar part numbers?
    30073407 and 30073407/A
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,021
    Isle of man- uk
    They use them on BMWs, not sure of the model through.
  7. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,739
    South East
    Jimmie
    /A often means Alternative ie original NLA and the current offer is not quite correct as described in post 2
    Mfoncerrada likes this.
  8. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    I have one of each of these in stock. However, the right is broken (spring issue). I bet someone savy can fix it. The trim is aluminum and it's formed over the plastic body so that would not be the easiest to pull apart. However, there is a slit that a dental pick could get in and possible correct the spring
    Send me an email if you wish to discuss: dave.lelonek@**********.com
