Every one has a different name for it but this is what I am after http://www.ferrarichat.com/forum/technical-q/120979-3x8-window-felt-scrub-pix.html Mine has fallen apart and unfortunately caught the window tint scratching it. I cant seem to find it on anyone's websites. I guess I need approx. 6 feet or 2 meters. Can anyone point me in the right direction In a nutshell it is riveted on and is about an 1 inch and 1/8 wide and is attached to the upper door trim. The thread name Rutlands but I cannot find it there. I have emailed them Peter
Superformance ferrari dino ferrari v6 ferrari v12 specialists 308 246 206 fiat dino 355 328 Image Unavailable, Please Login
Welcome Peter, I had the same problem when I got my car and replaced the original type (which I believe are nor longer available) with the Superformance ones. They work perfectly fine.
Its the little things that annoy me when I look at the car, especially with the big scrape in the window tint now. Hopefully the new part will arrive quickly and I can finish the job. One of those satisfaction jobs . Peter
Superformance usually ships fast You need to remove the little triangular finisher at the rear view mirror and the door panel insert first (1 screw at the rear door opening, then pull horizontally backward. When refitting, make sure the center hook is grabbing) Remove the flat headed bolts behind the insert and the single front screw opposite the dashboard inside the cutlin from them top door finisher and pull it up vertically.
I wish you had posted this response yesterday as I surfed/trawled for hours trying to find the right thread for removal
