Window glitch | FerrariChat
Window glitch
Discussion in 'Mondial' started by greatscott73, Nov 20, 2019.
  1. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    Here's one for you electrical whizzes. The passenger door power window in my 87 cab is a bit slow, but tolerable. However, when I push the switch in either direction for up or down, the only way anything moves is if I give the door panel a smack with the palm of my hand in the general area of where the motor bolts to the door frame. I went in and cleaned all the terminals, including the 3-wire bundle that is grounded to the frame, but it doesn't seem to make a difference. I'm wondering if it may be an internal fault in the motor itself. Any educated guesses?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,025
    Isle of man- uk
    Connect a voltmeter and measure when it is operating, if the voltage drops too much then nothing will happen, i can let you have the wiring diagram if needed
  3. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    Thank you for the generous offer. Actually, the voltage seems OK since it looks like someone hooked one of Birdman's accelerators previously. After taking the entire mech apart, the track and cable were pretty gummed up, so I'm amazed it works at all. Since these original Bosch motors seem to be hard to come by, I wonder if anyone has come up with a different or later motor that will bolt up.
  4. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,780
    Argent/Brasil
    Guido
    I did change my QV doors with 3.2 doors...other mecanisme. So problem solved...
    Guido
    greatscott73 likes this.
  5. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    I have the 3.2 mechanism, thank heavens, but the motor seems awfully tired. I detached it from the track and wired it directly to 12 volts and it turns, but slowly. I fear the end is nigh....
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,025
    Isle of man- uk
    If the motor is still working then it is fix able, probably just needs new bearings and cleaning. Diy or find a local repair shop.
  7. jkstevens2
    jkstevens2 Formula Junior
    Aug 25, 2015
    283
    Winter Park, FL
    JK Stevens
    They call that trick of hitting the door panel......."the fonz"
  8. 88MONDIAL
    88MONDIAL Formula 3
    Apr 13, 2005
    1,052
    Racine, Wisconsin
    Jim Smith
    When I start my car my tach doesn't work at all, just sits at 0. I have to tap the binnacle right above it lightly, one time. It's Italian charm. It's "normal" Haha. Seriously hope you can get it figured out.
  9. jgoodman
    jgoodman F1 Rookie
    3,273
    Central PA
    Jay Goodman
    Like Mike said, it’s likely not an electrical problem. It’s a thick caked grease problem. If you get to it and regrease the entire mechanism especially the motor, it should improve.
  10. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    Even after extreme de-caking, the motor barely moves, so I'm in the process of trying to source another.
    The track itself was gummed up so badly it is a wonder anything moved at all. That has been rectified.
    The long term plan is to try and find someone locally who will freshen up the old motor, but so far not having any success on that front.
  11. Steve Magnusson
    27,023
    This is a sign of corrosion/oxidation between the brushes and the commutator segments inside the motor. These type of motors need to be run occasionally to keep this interface clean and in good electrical contact -- very common for often disused rear window motors on any marque car to have this issue.
  12. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,025
    Isle of man- uk
    Just take it to bits and stick new bearings in it, give it a good clean with electrical cleaner and see what happens.
  13. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    Any idea where to source those bearings? It feels like it needs some, since it is rather "lumpy" when turned in the housing.
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,025
    Isle of man- uk
    Bearing are bearings- just get the old ones out and read the numbers off the sides. Any local bearing and seal supplier will stock them. Motors are probably Bosch and they dont make bearings, but use stock ones
  15. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    To keep everyone up to date: I tried every suggestion and every other thing I could think of to get my window motor working to no avail. Finally gave up and bought a used motor off of ebay for a VERY reasonable price. Bolted it in and now everything works as designed. Window goes up and down at normal speed, and door panel rapping isn't required for operation, lol. Thanks to everyone that spent their time responding and offering expertise. It is always appreciated.
  16. alexion
    alexion Formula 3
    May 20, 2013
    1,379
    New York
    You're welcome! It cost me $1200 for a new motor and track from Ferrari.
  17. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    I found this rather odd wear damage on the armature after taking everything apart, so I think the thing was on its way out anyway. Only seems to be in the one spot, which I thought was weird. Anyway, alls well that ends well, for about a grand total of $75
  18. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,025
    Isle of man- uk
    The bearing are probably worn and it rubbing due to its balance, it is a wound rotor so it will not have damaged the wire. Were the bearings tight or damaged
  19. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    Here's an updated piece of info with tired motors in the doors of your later mechanism Mondials or 328s. I found a motor from a company called A1 Electric in California that is selling these NEW for the princely sum of $95. It even has the Bosch 070 part number on the case for the right side door. Considering the used price seems to be considerably more on sights such as ebay, I thought it was quite a find. Always nice to replace with new as opposed to 30 year old used. It appears to have sat on a shelf for a considerable time, but They assure me it has never been used.
  20. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    FYI, these motors are listed strictly as a Bosch replacement motor on their site. Ferrari is never mentioned. When I told the guy on the phone what it was going in, he laughed at me and warned me there would be no returning it if it didn't fit.
  21. alexion
    alexion Formula 3
    May 20, 2013
    1,379
    New York
    There's still 30 year old grease inside
  22. greatscott73
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    True, but after having a couple of these apart at this point, Bosch seems to have used a better quality lube than Ferrari did on the track. I have seen no evidence of the solidified glop inside the motors that was so prevalent on the mechanism. I suppose the heat generated by a running motor may also affect that situation.
