Hi Can anyone help please? I am selling these 812 Wheels and have been asked if they will fit an FF? I know they will fit the F12 but not sure if they fit an FF as well. The size of the wheels are Part number 324158 fronts 10J x20" and part number 324159 11.5J x20" Thanks Grant Image Unavailable, Please Login Image Unavailable, Please Login
Can't confirm if they will fit but stock FF wheel sizes are FR 8.5J x 20 ET 46.5MM RR 10.5J x 20 ET 53.4MM
They will fit an FF but they aren’t rated for the axle load of the FF so whoever is buying them shouldn’t … However, plenty of FF owners are running F12, 812 and in some cases, 458 wheels and nobody seems to have bent one yet. In fact, the only forum member regularly bending wheels is ttforcefed and he is actually using the approved FF and Lusso wheels The manufacture and/or fitting of non-standard wheels is totally unregulated in the US but I’d be concerned about fitting under-rated wheels in the U.K. or Europe.
I’ve been told they may be too aggressive for FF, but will fit a Lusso without spacers Sent from my iPhone using FerrariChat
Sure, if you drive your FF with full fuel, 4 full standard sized adults, and a trunk full of 220lb worth of payload, and then decide to drive your car to the extreme I can see the axle loads being a consideration, as for the F12 Forged wheels in question, they had very low axle loads for typical wheels, most front forged wheels hover around the 500kg mark, which is more than fine. Personally, if they fit, and look good, just use them. Axel load consideration isn't very realistic, and a factor strictly due to the rated cargo carrying ability of the car.
Image Unavailable, Please Login Yes they do. These came with my purchase and seem to work great, although I have had 2 blowouts from potholes this year
Direct fit as far as I can tell. No sign of any spacers, can only tell you the front sizes atm. Will confirm rear when I check 245/35/20 - Summer Pzero 235/35/20 - Winter Alpines
Carl, I believe that your car is on the optional forged FF wheels. I really don’t think that they are the cast 812 wheel mentioned by the OP.
I hear you. But as I mentioned in my post, North American regulations and rules are vastly more relaxed than in Europe. Over here, an insurance claim can be denied if you’re on the wrong tyres or wheels. It’s also illegal in some countries to drive on uncertified wheels.
forgot photo of the wheels on my F12. Image Unavailable, Please Login Image Unavailable, Please Login
