Why is it called a "dog-leg first"?
Discussion in 'Ferrari Discussion (not model specific)' started by millemiglia, Nov 11, 2004.
  1. millemiglia
    millemiglia Formula Junior
    Jan 14, 2003
    925
    Stockholm, Sweden
    Peter B.
    #1 millemiglia, Nov 11, 2004
    In the pre -89 (?) Ferraris, first gear used to be to the left and down, known as "dog-leg first" (see the attached picture).
    I heard it was designed this way because at racing events, it was useful only at the start and for getting the car back on the trailer.
    But why is it called "dog-leg first"?
    Am I missing something on the anatomy of dogs?
    /Peter
  2. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Maybe because in the diagram, the R would be the dog's head & 1 & 5 would be the legs?
  3. ASG 86TR
    ASG 86TR Formula 3
    Aug 23, 2001
    1,474
    New Jersey
    Adam G
    Because if you look at a dog's leg (Rear leg) it has a bend in the middle of it. So if you were to draw a line from first to second, it goes up, bends to the right and then continues up, just like a dogs leg.
  4. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    I think it refers to the pattern of movement from the central position of neutral to first gear. To the left and then down. Like a "dog-leg" hole in golf. I have no proof to back it up, but that would be my guess. Similar to a "dog-leg" left on a golf course. A colloquialism.
  5. millemiglia
    Jan 14, 2003
    925
    Stockholm, Sweden
    Peter B.
    Thanks for the replies guys!
    Ohh, "colloquialism", tough word for a "bloody foreigner" as myself...
    Had to look that one up.
    F-chat is amazing, I learn something every day!
    /Peter
  6. dwhite
    dwhite F1 Rookie
    Taken from golf. Figure the center position is the tee box and first is the green. All dogleg holes either have a bend to the right or a bend to the left. I think on the fcar it is a par 5 from first to 2nd. : )
    Ooops, just reread and golf thing already mentioned.
  7. cab7104
    cab7104 Karting
    Mar 25, 2004
    237
    Rochester, NY
    Craig
    I thought that it might have to to with a "dog-leg" in the terms of a race track. It curves as well..then I guess the question is, how did the dog leg in race track terms got its name. Maybe from golf, maybe from dogs legs. Just my two cents.
    Craig
  8. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,655
    The fabulous PNW
    Han Solo
    Meaning the zig zag from first gear to second gear as opposed to a straight shift inline from first to second. (The crooked hind leg of a dog)
  9. SimonA
    SimonA Karting
    Sep 2, 2004
    112
    Wilton, Ct.
    Simon Adams
    This is funny. For the golfer's out there why do you think the term dog leg came from. The dog same as the shift pattern. It is because it resembles the hind leg of a dog.
    Cheers,
  10. GaryReed
    GaryReed F1 Rookie
    Feb 9, 2002
    3,127
    Seattle
    Gary
    I think Spasso's definition is correct.
    As far as "the last" model Ferrari to have a dogleg 1st gear, 5-spd.... I think it was probably the 1995 F512M.
    That same year, 355s came out with 6-spds (and a regular shift pattern).
  11. Admiral Thrawn
    Admiral Thrawn F1 Rookie
    Jul 2, 2003
    3,932
    Don't ya just love it? :D
  12. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,820
    Santa Fe, NM
    for 10 more points, what does the term "dog box" mean re: certain transmissions? and why?
  13. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    Could be wrong, but I understand it to mean a transmission with straight-cut gears (for strength, vs beveled), also known as a "crash box." I think the term "dog box" comes from the barking sound when the gears mesh.
  14. mannytranny
    mannytranny Karting
    Dec 17, 2003
    225
    nor cal
    Brady Klopfer
    hmmmm....interesting, I had never heard that term before. you learn something everyday......
    I do love that transmission setup....
  15. Gatorrari
    Gatorrari F1 World Champ
    16,379
    Georgia
    Jim Pernikoff
    #15 Gatorrari, Nov 14, 2004
    I think "crash box" can refer to any transmission that doesn't have synchromesh.
  16. El Wayne
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    On second thought, you're right.
  17. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    A dog box is a gearbox that does not have synchromesh not a gearbox with straight cut gears.
    These dog boxes are used in serious race cars and require much more skill in changing gears. The reason they are called dog boxes is because the 'dogs' are what engage the gears ... silly term but if you look at a gear in a constant mesh gearbox they the gear teeth (straight or otherwise) and then they have the engagement teeth (the dogs) which the selector hub lock together with.
    In a synchromesh gearbox the teeth are differently shaped and also have the synchro's to synchronise the input and output shafts.
    Refering to crash box ... I think this term refers more to the vintage gearboxes where the gears actually moved and thus were not constant mesh. You had to choice but to crash from one gear to the next because synchro's were not even in the equation.
    Pete
  18. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,820
    Santa Fe, NM
    10 points for Pete - the 'dogs' are the nubs on the sides of the gears themselves and the gear selector ring in the older racing transmissions.
  19. El Wayne
    Aug 1, 2002
    18,069
    San Marino, CA
    L. Wayne Ausbrooks
    Guess I can just sit back and shut up now. Thanks Pete.
  20. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    #20 PSk, Nov 14, 2004
    Pleasure :)
    Pete
