Why do F1 cars not have starters? | FerrariChat
Discussion in 'F1' started by F1Ace, Aug 17, 2004.
  1. F1Ace
    F1Ace F1 Rookie
    Mar 15, 2004
    2,980
    Wes
    I have always wondered about this. I believe they have batteries, and weight isn't the issue, 'cause if you mandate it they're all even.
    Anyone ever heard a reason why they've never had on board starters?
    Best!
    Wes
  2. Aureus
    Aureus Formula 3
    I would think weight *is* the issue because they're not mandated. If it were mandated then weight would not be the issue. But since you don't need to have a starter why add the extra weight necessary to have a starter?
  3. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    ^^ Yep to save weight. Though it might have saved Montoya's 4th position in the Indy race this year. He couldnt start his race car because the angle of the started pulley was not able to reach the engine. He thus ran to his spare car at the 11th minute and was penaluized as a result..
  4. F1Ace
    F1Ace F1 Rookie
    Mar 15, 2004
    2,980
    Wes
    Help me out here, aren't the cars inherently underweight to the point where they have to add weight to the car to bring it above a minimum weight?
    Wes
  5. Mr Payne
    Mr Payne F1 Rookie
    Jan 8, 2004
    2,878
    Bakersfield, CA
    Payne
    Yes, but the starter weight is more poorly positioned than the extra weight that they would simply put on the bottom of the car.
  6. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    They would also have to have an extra battery or use a bigger one, no? There would be extra weight and wires to get in the way also. Not to mention another fire hazard.
  7. Kram
    Kram Formula Junior
    Jul 3, 2004
    867
    Park bench, Canada
    Mark
    Everyone above is right on the money, weight is the key, particularly low weight which helps the handling. Have you ever wondered why a couple of mechanics are needed to carry the undertray about? Because that is where all the weight that has been saved elsewhere is put back on, there is no lower place on the car.
    The other reasons for leaving off a starter are as follows:
    A starter is just another thing to go wrong, so leave it out.
    A starter drains so much power it will knacker the small battery in a race car.
    Most racing engines won’t run at low r.p.m. and thus need a serious starter to whip them up to speed, so the little bitty thing you could fit onto the flywheel just won’t cut the mustard.
    Mind you, some racing cars do have starters. In endurance racing (Le Mans, Daytona) the car must start in the pits under its own power or it will be disqualified. And yes, they always give trouble.
    Kram
  8. F1Ace
    F1Ace F1 Rookie
    Mar 15, 2004
    2,980
    Wes
    Thanks for the comments guys, even you who are just some guy on a 'park bench' (love those touches).
    If I were a driver I would make a push to get starters on. It takes one slip up and your whole weekend (or perhaps career!) can be ruined. Still I wonder if they stay away from it for other reasons. Like so you don't have a guy spinning his starter on the starting grid just before the lights go out. Plus there's so much computer work involved now to just start the cars that's probably a reason too. Still, where there's a will there's a way. I wish they were on.
    Best!
    Wes
  9. ASU SAE
    ASU SAE Karting
    Aug 8, 2004
    59
    CA
    T
    There is so little reciprocating mass and very short stroke that I don't think the starter would really increase that much in size.
  10. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,591
    Toronto / SoCal
    Rob C.
    I'm really surprised to read that no one mentionned that on board starters are not allowed in F1 as per the regulations. I assume this to be the primary reason you do not see them on the cars. While weight is an important consideration, over the course of a season, if the starter were used just once, it would certainly net more good than any losses due to the static weight of a starter.
  11. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    It was talked about in the first few posts.
  12. 62 250 GTO
    Jan 9, 2004
    7,765
    Nova Scotia Canada
    Neil
    Weight is a massive deal in F1. A problem for Williams' nose cone was too much weight over the front. It weighs nothing, but I guess that's too much! Teams are upset if they pit a car 1 lap early because the difference between an empty tank and a full one is massive. Weight/ fire/ more electronics are all reasons.
  13. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,826
    The Cold North
    Tom
    Maybe they don't have any money left over to buy one,once the car and crew are paid for..
  14. Admiral Thrawn
    Admiral Thrawn F1 Rookie
    Jul 2, 2003
    3,932
    I can attest to that!
  15. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    There are also technical/logistic problems for a starter.
    A modern F1 engine idles at around 5000rpm, some more. So you need to spin it to close to that, now the problem really starts....with most cars running 100mm diameter clutches, the gear ratio of the starter is quite tall, so speed is not impossible to achieve, but the load/effort to turn it is...massive current would be needed to power the starter and that is simply not provided for on a modern race car. Most electrical systems run on small voltages...5V for most circuits as far as I know.
    Maybe a pnuematic starter could work, but again the air reservoir to operate it would be huge. And if you shared the valve pneumatic system you may run out of air for the valves to close rendering the starter useless!!
    Anyway, only geese stall an F1 car, and if the driver won't admit it, he can always blame the software!
  16. Kram
    Kram Formula Junior
    Jul 3, 2004
    867
    Park bench, Canada
    Mark
    Phil nailed it. Throw in high compression and starting the thing becomes a major job.
    Kram
  17. yellowtr
    yellowtr Formula Junior
    Feb 23, 2004
    368
    London
    Peter
    Sure do have batteries...They are very minute, but very powerful and cost HUGE amounts of money. Normally carry about 10 spares and they are charged over night. 3 starter trolleys are looked after the "gearbox" mechanic. The cars is started via a laptop which is linked into a large dongle lead into the car. Your normally have two Systems Engineers on hand when a car is started. The engine is revved via a hand control and then the driver is left to do his stuff...The car can be started without a laptop-but still requires a crank of the starter trolley...
  18. zff
    zff Karting
    Nov 1, 2003
    146
    Hawaii
    Ken
    If and when F1 engines evolve to the point where they have computer-controlled valves, they'll be able to start themselves w/o a starter.
    I read an article about Ford's research into an engine where valves were opened and closed directly by a solenoid. They built a working prototype and installed it in a Ranger. The engine was able to do some pretty amazing tricks including starting itself w/o a starter. After I read how they did it, I wondered if I would have been able to figure it out myself.
    Anyone wanna guess?
  19. F1Ace
    F1Ace F1 Rookie
    Mar 15, 2004
    2,980
    Wes
    My guess would me that they fire specific cylinders which are in the right position to "pick up where they left off". Then the others follow, and so forth.
    Am I right? Sounds like a great idea!
    Best!
    Wes
  20. zff
    zff Karting
    Nov 1, 2003
    146
    Hawaii
    Ken
    Yup, that's basically it. The EMS picks a cylinder that's just past TDC, opens the intake valve(s), squirts in some fuel, closes the valves, and fires the spark. All it needs to do is crank the engine far enough over for the next cylinder, and within fractions of a second, the engine is running normally. The system supposedly works so well they could have it shut the engine off at red lights and start instantly when you step on the gas.
  21. TestShoot
    TestShoot F1 World Champ
    12,255
    Beverly Hills
    I have this old Indy car in my garage, and the damned starter can dam near rip my arms off. Considering how much that badboy weighs, I'd be happy to leave it out. Then again push starting the car is a b!tch
    The idea of picking up where you left off seems neat in theory, somebody go build one, and use rotary valves please.
  22. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    See page 32 of Sept F1 Racing magazine for an interesting opinion on F1 starters.
