why can I only drain half of coolant
Discussion in '456/550/575' started by stevepaa, Mar 21, 2020.
  1. stevepaa
    stevepaa Formula Junior
    Apr 5, 2006
    762
    san jose, ca
    steve
    So the owner's manual says there are 5 gallons of coolant.
    I can only drain 2.5 gallons from the radiator and block.
    Where is the rest?
  2. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    Steve, with careful draining without losing a drop I collected 3 gallon plus 1/2 quart from heather. Pete mentioned in his work that he used shop vacuum to suction coolant from top after removing the coolant manifold. Base on that fact I removed the coolant manifold to have access to the bottom of blocks but unfortunately it was not feasible. Later on he documented reaching left side water drain plug obtained very little may be hundred ml or so which did not worth the effort of doing it. so leave us with no answer except some one with flexible bronchoscope enter and check the bottom of water jacket if there is any coolant sitting there ( bellow the drain plug level).
  3. stevepaa
    Apr 5, 2006
    762
    san jose, ca
    steve
    Well, the best I could remove after warming up the car and filling the reservoir was 2.6 gallons. I have flushed with distilled water of 2.5 gallons 6 times. The flushed water is not clear, but of a slight yellowish color.
    So there must be 2.4 gallons unreachable by radiator or block drain.
    I did this on race ramps.
    I will try to back the car down to see if I can get any more from block drain.
  4. stevepaa
    Apr 5, 2006
    762
    san jose, ca
    steve
    I filled up reservoir after starting engine and was able to get 2.6 gallons. The car is on race ramps and so I will move it backwards to lower the front and see if I can get more from block.
  5. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Try to check the left side drain plug to see if it is easily accessible, I will do it tonight or tomorrow and will let you know.
  6. Rifledriver
    36,786
    It isn't worth the trouble. When you change oil you don't get 100% either. Changing oil or coolant in a timely fashion for good maintenance assumes some level of dilution of old with new. Many of the newer Ferraris do not even have drain plugs. You would need to turn the car upside down to drain it.
    bruzzifumi, Texas Forever and F456M like this.
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,685
    Central NJ
    Dominick
    Wouldn't a good practice to flush 2 3 times (drain and refill) with distilled water and then add the right amount of pure antifreeze to get right dilution considering what water is left inside .. then you would pretty much clean everything?
    Sent from my moto g(7) using Tapatalk
  8. Rifledriver
    36,786
    If regularly maintained it never got dirty. Coolant is good for a few hundred thousand miles. Some of the additives wear out and need replenishing. A 100 % change is totally unnecessary for that purpose. No engine manufacturer requires it.
    bruzzifumi likes this.
  9. fatbillybob
    Aug 10, 2002
    28,617
    socal
    humm....
  10. stevepaa
    Apr 5, 2006
    762
    san jose, ca
    steve
    I drained the left side when I changed coolant last time. There is very little after draining the right side. And it is hard to get to.
    I have done 6 flushes with distilled water to remove 99% of old coolant and now will add rotella in two steps to get to 50%.
  11. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    Did you have the wrong anti-freeze in it since you are changing it?
  12. Rifledriver
    36,786
    Hey dumb ass. Nothing I said there is a contradiction.
    Learn the language and learn about cars.. It pays to have better than a grade school understanding of both to participate. Try to keep up.
  13. stevepaa
    Apr 5, 2006
    762
    san jose, ca
    steve
  14. Texas Forever
    Texas Forever Eight Time F1 World Champ
    85,580
    Texas!
    No drain plug? Guess that’s one less thing to leak, huh?
    fatbillybob likes this.
