Who's 550 Modulars Are Leaking? | FerrariChat
Discussion in '456/550/575' started by Qksilver, Mar 23, 2008.
  1. Qksilver
    Qksilver F1 Rookie
    4,328
    Philadelphia
    Joe
    Please chime in. We are losing quite a bit of air/day.
    List:
    Qksilver
  2. PCH
    PCH F1 Rookie
    Apr 7, 2004
    3,007
    Not uncommon especially with older modular wheels. I believe there was a campaign on this however, I would assume too much time has elapsed for factory participation.
    Modular Wheel Inspection and Maintenance
    Two & Three piece modular wheels require periodic maintenance. You'll want to work out your own maintenance schedule, but here's an example of what the manufacturer recommends.
    Each Season disassemble, thoroughly inspect, clean, re-seal, and re-torque each wheel:
    Replace wheel bolts each season
    Wheel Bolt Torque:
    1/4" bolts 15 ft/lbs. or 180 in./lbs
    5/16" bolts 20 ft/lbs.
    After thoroughly cleaning all mating surfaces with an appropriate cleaner, add a thin skim coat of silicone sealant to these surfaces, assemble wheel and torque bolts to recommended torque
    Install a new valve stem
    Add a thick coat of silicone sealant to the drop center area of the wheel and let it cure for 24 hours before initial use
    Auraraptor likes this.
  3. Qksilver
    Qksilver F1 Rookie
    4,328
    Philadelphia
    Joe
    Thanks Drew. Maybe I'll just do it myself.
    Joe
  4. Texas Forever
    Texas Forever Seven Time F1 World Champ
    76,179
    Texas!
    I believe that this was the only official recall for 550s. It shoulda be taken care of a while back. You can find the recall notice on the DOT web page I believe.
    Dale
  5. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    394
    Lance Malcolm
    Good morning Fchat friends!
    So anyone have HRE 3-piece wheels... I bought a set and have two that are leaking a significant amount of air each day.... I would assume the above procedure would work for these wheels? Any reason why not? Thanks in advance!
  6. white out
    white out Formula 3
    Mar 3, 2010
    1,229
    That's a standard procedure for rebuilding 3 piece.
    If you want to drop rotational mass, you can replace the stainless hardware with titanium hardware.
