Whom has a Rolls Royce? | FerrariChat
Discussion in 'Australia' started by carl888, Jan 23, 2021.
  1. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,431
    Melbourne, Australia
    Carl
    I suffered the indignity of scrolling through the thread regarding the Rolls Royce cooling issue. I have no experience with the Evans product however it would appear that there is insufficient evidence to suggest that it would cure the hot running issue. Since there are many Whoms here with the abovementioned carriage, here's some technical information.
    Of all of the old **** I work on, in every case bar one (De Tomaso Pantera), cooling system issues have stemmed from the following conditions:
    1. Neglecting the coolant change intervals causing the radiator to scale/corrode.
    2. Improper functioning of the radiator fan clutch.
    3. Aftermarket installation of air conditioning with an insufficiently upgraded thematic fan.
    4. Thermostat not opening fully.
    5. Damaged/incorrect/corroded water pump impeller.
    6. A factory directive regarding a cooling system upgrade not being followed.
    Or a combination thereof.
    The Rolls Royce/Bentley cooling system was upgraded as per the TSD below, perhaps SBH 5495 still carries its earlier system? It would be interesting to check the pulley, fan and cowling (if fitted).
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Arvin Grajau likes this.
  2. Horse
    Horse Three Time F1 World Champ
    Dec 1, 2005
    34,652
    Brisvegas
    Jon
    Yes, he does.
    Silly signature here to annoy KIAI
  3. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    25,476
    Sydney,Australia
    Greg
    Whom cares. Boring cars
  4. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    28,802
    North Qld
    simon klein
    You forgot incorrect radiator cap,one of the issues I had with the 308 after picking it up from you and including a couple of the others you mentioned.
  5. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Peter
    Good sleuthing Carlos.
  6. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    76,922
    Wurundjeri man.
    Arvin Grajau
    Only one radiator cap available .
  7. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,431
    Carl
    Yeah, don't forget the butt plug too.
  8. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,431
    Carl
    How is yours going?
  9. Arvin Grajau
    76,922
    Wurundjeri man.
    Arvin Grajau
    I know Kim at Autocooling , even though its been flushed , i might get a new core made up.
    Has no cowling ..
    Ta Carlo.
  10. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,431
    Carl
    Thanks, did yours ever run hot?
  11. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,431
    Carl
    I don't have any experience with the pre 1972 models however I understand the cowling makes a significant difference.
    You will probably find one here:
    https://www.newmodelwreckers.com.au/vehicle-search/
    Search under Rolls Royce, they seem to get more Shadows than any other dismantler I know of.
    It would make sense to fit the cowling if you plan to take your radiator out.
  12. Arvin Grajau
    76,922
    Wurundjeri man.
    Arvin Grajau
    as i said it would be an issue like a day similar today in traffic for say 30mins, but on the move it would fine .
    Today I went down to Fis, took the E-type 70c all the way no issue
    Tony Z can have a fiddle when i get her serviced.
  13. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,431
    Carl
    Did you have a pee from the tower?
  14. Aircon
    100,524
    Peter
    As if I remember. Mine was a 1977 model though.
  15. simon klein
    Feb 25, 2009
    28,802
    North Qld
    simon klein
    For the 308....
  16. Arvin Grajau
    76,922
    Wurundjeri man.
    Arvin Grajau
    No she did .
    carl888 likes this.
  17. Arvin Grajau
    76,922
    Wurundjeri man.
    Arvin Grajau
    different to the old series in many ways .
  18. Arvin Grajau
    76,922
    Wurundjeri man.
    Arvin Grajau
    RR/B
  19. simon klein
    Feb 25, 2009
    28,802
    North Qld
    simon klein
    What only one radiator cap in the world physically fits?
  20. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,431
    Carl
  21. simon klein
    Feb 25, 2009
    28,802
    North Qld
    simon klein
  22. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,431
    Carl
    Not really, the cooling system still vents to atmosphere, just through the header tank, not through the radiator. Plenty of other cars like this. 1980s Mercedes W126, Audi A4, Porsche 996, Any Ferrari V6 and V8, Boxer, testarossa, 550 etc.
  23. Arvin Grajau
    76,922
    Wurundjeri man.
    Arvin Grajau
    One smart company , google about the brake servos, never get lock up on a drum brake Rolls-Royce or brake fade .As the Servo takes up for a better word the brake pedal slack...correct Carlo?
    carl888 likes this.
  24. au-yt
    au-yt F1 Veteran
    5,834
    Burradoo... Actually
    Graeme
    I studied this stuff and used it for about a month, its now back in the bottle.
    Its best use is in verterin cars without pressure systems. It runs about15 degrees hotter and takes ages to heat up and slow to cool and Bloddy expensive.
    Pre mix long life thanks and change it every three years.
  25. Andy 355
    Andy 355 Formula Junior
    Jun 2, 2013
    434
    The cap on the expansion tank is for filling. There is a component in the tank called a steam valve. Rolls Royce over heating issues are almost entirely caused by blocked radiator cores. Remove and test the thermostat in the first instance.
