Who has changed his own timing belt? | FerrariChat
Discussion in 'Mondial' started by FCnew, May 6, 2015.
  1. FCnew
    FCnew Formula Junior
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    Noob questions here...
    Where did you get the belt?
    Was it difficult to do? Any pictures? Video on the web?
    What to look out for?
    Would you do it again?
  2. wildcat326
    wildcat326 Formula 3
    1,777
    Chicago, IL
    Justin
    Step-by-step video...
    https://www.youtube.com/watch?v=rn-bpUziJag
    eBay, Superformance UK, Ricambi America, T. Rutlands, Ferrparts all have them. Manufactured by Dayco if you want generic
    Also, as I believe at least certain Mondial blocks are substantially the same or similar to the 308, look up the procedure write-up at birdman308.com, an invaluable resource.
    Welcome to the club!
  3. wildcat326
    1,777
    Chicago, IL
    Justin
    Recommend buying a set of cam locks. Perhaps Unobtainium Supply Co. has a set sized for Mondial? If it's the same as the 308 engine, then definitely.
  4. 123howie
    123howie F1 World Champ
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    I see this is your first post. Welcome to Fchat.
  5. FCnew
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    Yes this is my first post... thanks for the welcome.
    I thought I would do some research to see if I can afford this toy. Looks like a great community here... lots of info, and lots of helpful folks.
  6. MvT
    MvT F1 Rookie
    May 25, 2013
    4,248
    The Netherlands - NH
    Tijn
    Welcome! which Mondial you have put your senses to? 8,QV,3.2 or T? The T is a very different ride.
  7. decardona
    decardona Formula 3
    Apr 23, 2005
    1,019
    PA
    Dennis Cardona
    Did my own belts on my 308. Getting ready to do it on my new to me Mondial 3.2. Not a difficult job. Just be patient and methodical.
  8. godabitibi
    godabitibi F1 Veteran
    6,277
    Papineauville, Quebec
    Claude Laforest
    Belts are an easy job if you no how to turn a wrench. There is not much a good DIY can't do on a Mondial 3.2. A lot of the maintnance cost is labour on a Ferrari, if you buy the parts at the right place and DIY you can afford to own as any other car.
    And this community has a lot of good knowledge guys ready to help.
  9. FCnew
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    I did not even know there are so much differences until yesterday when I read up the forums here. I am still learning; it seems most people prefer the 3.2, but the T is more technologically advanced. I will keep an open mind and do more readings before deciding.
  10. FCnew
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    Just watched the video... thanks for the link.
    It appear the job is doable. Not easy... but doable. Will watch the video again.
  11. srephwed
    srephwed F1 Veteran
    6,470
    street,md
    fred brown
    The hard part for me was getting the a-c out of the way. Just make sure you mark everything very well before removing the belts. Then if something happens to slip a little it will be easy to go back. Good luck.
  12. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
  13. FCnew
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    Wwoow... thanks for the documentary. This is very detailed and very informative. I will study it carefully. Thanks again.
  14. dpospres
    dpospres Formula Junior
    Jun 29, 2005
    275
    Replacing the belts yourself is a very straight forward job that can be done yourself. There is an exception to that since you are looking to buy. The Mondial T has to have the engine dropped out to do the service on it.
  15. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    As stated before 3.0 and 3.2 don't "have" to be dropped but they are engineeered to drop the subframe and engine in one section, so why not do it that way. Just changing the belts is only one part of the job and a small one at that. There are many hoses to check and replace, h2o pump, degree the cams, etc. Just swapping out the belts without doing much more is really a short cut IMO
  16. MvT
    MvT F1 Rookie
    May 25, 2013
    4,248
    Tijn
    Most prefer the 3.2 and earlier as you don't have to pull the engine for most of the work. However at a certain point you will need to drop it. Like Meister said, you sometime have no view on things that are important. It is doable to do all hoses with the engine in, but if I would do it over again I will drop the engine. Also for other things to inspect etc.
    If you do not mind to drop an engine and like to wrench.. get a T. Keep in mind they in general have a higher maintenance price then earlier models. Good luck and let us know what you will decide. Don't buy anything without a technical inspection. Mondials can be quite a money pit ;)
    and how tos... you can all find it here, like Mike's great post or in the 348 section for a T on the engine!
  17. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    If you want one to drive, find one that's been driven regularly for the last few years. It's a good indication. Maintenance is important. These cars can eat you alive if you get a needy one. Other than that they are like many other cars. Before my Mondial I'd replaced a timing belt on a Honda Civic. I took my time and it went alright. I put marks on the belt in place and the cam sprocket in two places on each one. I pulled the belts without locking the cams. I then put paint marks on the new belt to match the old belt and lined it all up. It was perfect. I did put the engine to TDC in case anything went awry. On second thought I may not have locked the cams because I pulled them from the engine. First time I'd ever done that.
    It will likely be more expensive than you had hoped, but if you are a car guy, you will be glad you did it anyway. They are amazing cars, but artists and car guys get it best.
  18. braq
    braq Karting
    Mar 29, 2010
    226
    Hill Island
    Paul XXXcX
    I would like to do it myself, or even better assisting someone to learn, next time the change comes up.
    A well reputed shop has just done the change on mine and it turned out both were off by one tooth. We considered the likelihood of jumping just one tooth as minimal and guess the shop before that did not check after completing (I did see the TDC lining up).
    I have interviewed a friend who assisted two times in the timing belt change (a knowledgable Alfa owner took the lead and was paid fairly for his time) and asked if he would do it himself the next time.
    Answer, no, because if you mess it up it is close to a financial meltdown of the whole car (regarding engine rebuild). I've done the timing belt on my cheapo Chrysler convertible, but I know I can pull an engine for less than the car's value in case it goes wrong.
    Cheers
    braq
  19. Mondial 1985
    Mondial 1985 Formula Junior
    Jun 13, 2012
    344
    Greenville, SC
    Mark Alan Day
    Well, not everyone has a lift in their garage by which they can raise their car to drop the engine. I'm in perfect agreememt with engine removal; that removaL is the best thing to do, maintainence-wise, but even cheap lifts run close to $1K.
  20. FCnew
    May 5, 2015
    687
    Hong Kong / Canada
    Jonathan
    With the money you saved, you can afford to buy a lift.
  21. soucorp
    soucorp F1 Rookie
    Sep 20, 2011
    4,814
    Old Dominion
    #21 soucorp, May 8, 2015
  22. Rapalyea
    Rapalyea Formula 3
    Jun 18, 2013
    1,511
    Georgia Mountains US
    David Rapalyea alias
    Every last belt failure I have read of [three or four] occurred after new installation. This tells me it is not to be taken lightly. I have looked at these belts and they look mil spec for an Abrams M-1 main battle tank. Further, I have seen these cars for sale that had something like SIX belt changes over the years even though they were almost never driven. [15,000 miles or three years].
    Pullleeessseee. I will probably have local wrench do mine in a year or two. But the belts are clearly designed for extreme use and almost none of us does that. Even me! I have had discussions with mechanic on this issue and have been told, more or less confidentially: "Change them every ten years whether they need it or not."
    I am interested in anyone who is aware of belt failure after 15,000 miles and the details?
  23. Rapalyea
    Rapalyea Formula 3
    Jun 18, 2013
    1,511
  24. MvT
    MvT F1 Rookie
    May 25, 2013
    4,248
    Tijn
    That is indeed true :)
