Hey, I was cruising on the highway yesterday with my Mondial QV at 120km/h nicely. Suddenly I noticed in my rear view mirror that a cloud of white smoke came out of the engine bay. I only drove for about 15 minutes. All temperatures of oil and cooling liquid looked OK on the gauges. I immediately pulled over and checked the following: - Any leak of cooling liquid: NO - Fan on the radiator was working, so no overheating. - Any other sign of liquids on the engine from above: NO I was able to drive further and everything seemed to work just fine, no more smoke. At home, I checked underneath the car and all liquid levels: everything OK. Any ideas on this? Thanks
Did you wash the car earlier this week? Water trapped? How about the expansion canister? Rusty tears on the black paint?
Well, I drove through some heavy rain 5 minutes earlier, but it must have been at least half a litre of water to generate so much smoke. Expansion canister looks brand new.
If everything seems ok, perhaps a pothole with water that was sprayed over the headers/exhaust? Keep a close look on the gauges and liquid levels in near future. Also on the mirrors... Where are you located in B?
Oil in the breather system. If I fill my mondial t even to the minimum stick level it puts out clouds of white smoke, as soon an I take half a litre out its fine. Seems to suck it in the inlet manifold.
One question, did you tap up your coolant reserve tank before you took the car out. I ask because when I first just got my car 3 years ago, I over filled my coolant expansion tank to the point when the car got hot, the pressure busted a hose and I got coolant all over the headers which in my rear view mirrors looked like a raging fire out of the engine bay but it was just white smoke. Scary to see it when it happens. Got a new hose and refilled the coolant, all was fine. Make sure you do not fill coolant past the half way line in the expansion tank leaving room for expansion, 'Duh moment for me. Best
Check the bushing near the intake (just behind it), it has deteriorated in one of my Mondials and there was smoke coming out when it finally broke off.
Surprised, I would think oil in the breather would show as a little darker smoke. I am pretty sure I have an overflow tube on the expansion tank; but if overfilled, it would pressurize and hit some of the hot exhaust pipes out of the non capped overflow tube. That would cause some white smoke until the amount of pressurized coolant got below the overflow tube. I have never had an issue, but most tracks require a catch can on the overflow tube. Easy enough to rig up. I would double check the coolant level when cold, and hope it was only an overfilled tank. Regards, Jerry
Thanks for all ideas. I haven't touched the coolant in the expansion tank for years, so for the moment, I think it must have been some rain water that cooled on the engine and produced the smoke.
I had a leak from the front cam cover which then dropped down on the exhaust heat shield, so when a suitable amount had dripped down it would either burn off or when you went around a corner drop on the exhaust and give smoke out the engine cover. its worth a check to see if you have the same problem. Jim
Hi, This exact thing happened to me - ended up being too much oil from the last oil change and no gasket on the oil cap - oil bubbled over and spilled onto the exhaust manifold cover...check for leaks and if you see some oil stains on your passenger side cover - that might be it! Good Luck
Hey! That might be it, there is some oil dripping on the passenger's side of the engine, right below the heads. But the oil cap has a gasket on it. May have escaped from the point where the cam shafts exit the motor block. Thanks for the tip.
Does your exhaust manifold shield look like this? http://mondialt.files.wordpress.com/2013/12/photo-42.jpg
hmmm, if you don't see any sort of oil residue - the problem might be something more sinister - make sure you have somebody check it out Best case scenario is it was just some oil that bubbled over, worst case it could be gasket leak! Good luck!
Check your coolant hoses that go under the air intake/house. There is a T split. The little pipe is known for corrosion and will leak. (Red arrow) For the rest I would check all the yellow area. 1. Coolant level ok? 2. Perhaps too much coolant? (It'll throw coolant out via the breather pipe..) HTH Tijn Image Unavailable, Please Login
I had an incident where the car dropped its aircon gas charge thru the front seal of the compressor in one big lot and it was as you describe a big poof of whiteish smoke. Does your car have A/C if so turn it on and see if you have aircon still
Well, some weeks ago, I noticed that the aircon belt had snapped. Never heard any weird noise, the belt was just hanging over the aircon wheel, partially shred. I have a 2-belt system for water pump, alternator and airco, so there was no impact on other things and I decided to just leave the airco belt out of the engine. Never used the airco anyway. I don't know what made the airco belt snap, all wheels on which the belt was mounted appeared to turn fine.
That can easily have created the white smoke I would check the cam belts though if no pieces are torn out from this snapped airco belt.
Is the smoke from the engine bay or the exhaust? I know the caption says engine bay but are you sure?
Well it can only be 3 things as I see it, Oil smoke, Steam,or burning rubber. What does it smell of? Regards Bell
