Which Charger is This? | FerrariChat
Discussion in '458 Italia/488/F8' started by mdrums, Mar 30, 2020.
  1. mdrums
    mdrums Formula 3
    Jun 11, 2006
    2,223
    Tampa FL
    Hi, I have seen threads about various 488 chargers that come with the car. However all of them are much smaller than the one I have that came with my 2019 488GTB. It seems to work....I keep it on the charger if I am not using the car for a few days, per my dealers suggestion.
    What charger do I have?
  2. RayJohns
    RayJohns F1 Veteran
    7,401
    West Coast
    Ray
  3. mdrums
    mdrums Formula 3
    Jun 11, 2006
    2,223
    Tampa FL
    Yep I saw that but no idea what the real difference between this larger charger and the smaller one really is. Specs on the Ferrari site are the same. Dealer didn't really say much or get back with me on info either. I am just curious is all.
  4. RayJohns
    RayJohns F1 Veteran
    7,401
    West Coast
    Ray
    Yeah, no idea either.
    Ray
  5. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    That is the one my 2019 488 came with
    mdrums likes this.
  6. mdrums
    mdrums Formula 3
    Jun 11, 2006
    2,223
    Tampa FL
    Thanks Scott..!
  7. Ragnomn
    Ragnomn Karting
    Oct 19, 2012
    58
    My new F8 came with that charger
  8. Jason B
    Jason B Formula Junior
    Apr 7, 2006
    397
    Hbg, PA
    I have that
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,112
    Mel
  10. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    552
    SW Suburbs of Chicago, IL
    Lawrence P.
    This one looks just like my CTEK MUS 4.3 battery maintainer that I have but with a Ferrari label. I use the CTEK in place of my original Ferrari maintainer.
  11. Jason B
    Apr 7, 2006
    397
    Hbg, PA
    Cool, but without the $500 markup.
  12. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    Bigger is Better
  13. Jason B
    Apr 7, 2006
    397
    Hbg, PA
    Boomhauer likes this.
  14. Melvok
    Jul 25, 2008
    14,112
    Mel
    Indeed !!
    You se what's happening now !
  15. rob5819
    rob5819 Formula Junior
    Dec 12, 2017
    819
    San Diego
    Rob Barry
    The different LEDs in the tender above show you what programs are being run. For the CTEK tenders the programs are generally:
    STEP 1 DESULPHATION Detects sulphated batteries. Pulsing current and voltage, removes sulphate from the lead plates of the battery restoring the battery capacity.
    STEP 2 SOFT START Tests if the battery can accept charge. This step prevents that charging proceeds with a defect battery.
    STEP 3 BULK Charging with maximum current until approximately 80% battery capacity.
    STEP 4 ABSORPTION Charging with declining current to maximize up to 100% battery capacity.
    STEP 5 ANALYSE Tests if the battery can hold charge. Batteries that can not hold charge may need to be replaced.
    STEP 6 RECOND Choose the Recond program to add the Recond step to the charging process. During the Recond step voltage increases to create controlled gassing in the battery. Gasing mixes the battery acid and gives back energy to the battery.
    STEP 7 FLOAT Maintaining the battery voltage at maximum level by providing a constant voltage charge.
    STEP 8 PULSE Maintaining the battery at 95–100% capacity. The charger monitors the battery voltage and gives a pulse when necessary to keep the battery fully charged
    https://www.ctek.com/storage/ma/3f8cf34932cc46889f1d189ca335379c/cd879e35fdd145898b6b99c549c40292/pdf/7F18A34BA7A2CF91AC9F5404D8EB07FE2E6CAA66/MXS_5.0-manual-low-UK-EN.pdf. The chart also shows the maximum amount of time per step.
    My CTEK 7002 tenders have helped me diagnose batteries that would not take a charge and batteries that would not hold a charge.
  16. Jason B
    Apr 7, 2006
    397
    Hbg, PA
    Great, good info above. Now, the Ferrari tender I post the pic of has 7 lights, So I assume maybe it doesn't do step 8?
  17. LVP488
    LVP488 F1 Rookie
    Jan 21, 2017
    4,869
    France
    Looking at the doc and pictures I'd say that the CTEK step missing is 6 (recond) - the "recond" light is only meaningful for the "recond" operating mode, but the Ferrari unit does not have programmable modes (the "mode" selection button is replaced by a "reset" button on the Ferrari unit) so it does not exist. Pictures associated to steps 7 and 8 on the CTEK unit are the same as pictures for steps 6 and 7 on the Ferrari unit, I assume for "battery fully charged / float" and "pulse".
