Where/what number is fuse for turn signals? | FerrariChat
Discussion in '360/430' started by Virgil, Feb 19, 2013.
  1. Virgil
    Virgil Rookie
    Jan 6, 2013
    10
    Scottsdale, AZ
    Jim Moore
    Both OM and Workshop Manual do not show fuse location (if it exists) so....where is it?
    Virgil
  2. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Good question. I just did an exhaustive search of the OM and cannot find its location either. I'd guess that it's possibly one of the fuses in the trunk, and that maybe it has been poorly labelled in the OM, but hopefully somebody else knows for sure.
  3. 360Grigio
    360Grigio Karting
    150
    Steve
    #3 360Grigio, Feb 19, 2013
    I found a wiring diagram for the 360 Spider, http://ferraridatabase.com/The_Downloads/The%20Documents/Wiring%20Diagrams%20360%20spider.pdf
    Looking through the diagram, it does appear that the fuses are in the luggage compartment. If I am reading it correctly than the fuse in question will be in slots 7-24.
    edit: Found this thread referring to a 15 amp fuse being blown http://www.ferrarichat.com/forum/360-430/322241-f360-flasher-turn-signal-hazard-problems.html
    WAG - Fuse #9 emergenza
  4. Virgil
    Virgil Rookie
    Jan 6, 2013
    10
    Scottsdale, AZ
    Jim Moore
    #4 Virgil, Feb 19, 2013
    I started tracing wires and started with the hazard light switch since I did have the center console out. I started looking at all the plugs in the console to see if I connected one wrong and I noticed that my mirrors would not adjust so I looked at the wiring diagram and found a wire common to both switches. I then decided to look for the mirror fuse and hoped it would be the one. Lo and behold it was blown! The labeling is "+15 Radio-Clock-Wing mirrors-Light switch" in the wiring diagram. This clued me in as to why my radio wouldn't turn off with the ignition (stayed on for I think and hour then internally times out) and the clock always had the wrong time between driving the car.
    The fuse is labelled differently on the RH Fuse box cover behind the passengers seat " +15 Radio-MR.Stalk-Clock" "Stalk" kind of clued me in because sometimes in other vehicles the light switch is called a "stalk". The fuse number is technically 43 and it is on the fuse box nearest the tunnel on the upper LH corner of the fuse box pg 4.22 in the owners manual. Ferrari of Houston didn't even know there was a fuse and only one tech in Scottsdale had a clue but could not remember the fuse number or even if FOR SURE there was a fuse!
    Anyway for anyone reading this we are probably the only guys in then universe to know exactly what fuse and what other symptoms to look for!
    Virgil
    Qavion likes this.
  5. 360Grigio
    360Grigio Karting
    150
    Steve
    Congratulations on finding "that which shall not be named" in the OM.
  6. Virgil
    Virgil Rookie
    Jan 6, 2013
    10
    Scottsdale, AZ
    Jim Moore
    I am eternally grateful to All Ferraris !! NO KIDDING !!
    Between removing and rebuilding my F1 tranny and belt service plus misc electrical problems, I have literally saved THOUSANDS of $$ due to access to all the corporate knowledge. I guess the caretaker/compiler of this site died last year.
    A posthumous "Thanks!" from me.
    Virgil
