Where is the original ground location for power window switches? | FerrariChat
Discussion in '308/328' started by ATSAaron, Feb 20, 2020.
  1. ATSAaron
    ATSAaron Formula 3
    1,120
    Shady Shores, TX
    Aaron Bunch
    We are installing the Ferrparts upgraded window motors in a 308. They worked exactly twice and then our ground signal disappeared at the switches.
    The ground appears to be shared with the wiper motor, turn signal flasher, parking lights, and a few other things.
    Thanks in advance,
    Aaron
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,517
    Cerritos, CA.
    Couldn’t you just make a separate ground wire to the body or chassis for the Switch? Which is probably better than sharing it with the rest.
  3. ATSAaron
    ATSAaron Formula 3
    1,120
    Shady Shores, TX
    Aaron Bunch
    that’s the backup plan. Haha
    But I’d really like to find the original ground and clean/repair it.
  4. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,057
    Gold Coast, Aust.
    Patrick
    There's a big common earth up under the dash, above the fuse panel. If that screw becomes loose. all sorts of electrical gremlins show up. I knew a guy who had a brand new 328 which had an intermittent miss, amongst other gremlins. Two batteries and an alternator (under warranty) later, he found a loose ground screw under the dash - fixed. The local dealer was an idiot (I bought a car off him, too - don't get me started).
  5. ATSAaron
    ATSAaron Formula 3
    1,120
    Shady Shores, TX
    Aaron Bunch
    In case anyone else needs to know, it's behind and above the radio. If you remove the fuse panel you can (pretty) easily get a 10mm wrench on the nut.
    Aaron
