Where is Battery Master Switch for 2007 F430? | FerrariChat
Discussion in '360/430' started by conscom, Apr 15, 2014.
  1. conscom
    conscom Formula Junior
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Can anyone tell me where the battery master switch is located in my 2007 F430? It's not where the manual indicates. The location only has a cover plug and nothing behind. So obviously it must be somewhere else or there isn't one. Thanks for any guidance.
  2. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    #2 English Rebel, Apr 15, 2014
  3. 993turbo
    993turbo Formula Junior
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    On my 09' the switch is also covered. Its not like the 360 where the knob is visible.
    :D
  4. Tally Ho
    Tally Ho Formula Junior
    Jul 4, 2007
    720
    Niceville, FL
    Bill
    Mine is located on the upper right side of the back wall in the boot. You should be able to get to it easily. I'd send you a pic but I'm at work and the car is in the garage at home. My cover plug looks like a valve handle. A turn to the right and it pops off and is attached by a lanyard. The battery is then shut off.
  5. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    That looks like #10 in the diagram as there appears to be a lanyard attached to it. According to the diagram it's in the top left of the luggage compartment as you face it (and that is the side the battery is on).
    Alan
  6. Tally Ho
    Jul 4, 2007
    720
    Niceville, FL
    Bill
    #6 Tally Ho, Apr 15, 2014
  7. handdoc
    handdoc Karting
    Apr 3, 2014
    154
    need a tool to turn it on and off
    owners manual says for ferrari use only
    u can order the tool from ferrari
  8. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I guess the tool got lost somehow -- that's what the lanyard is for though.
    Alan
  9. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    The tool is a torx head screwdriver. You can buy it a Home Depot like I did. I believe it is a T40 torx head.
  10. zzade46m3
    zzade46m3 Rookie
    Aug 20, 2013
    48
    OC CA
    just fyi not all the F430s came with a battery master switch, mines does not have one, its a 2007 as well.
  11. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Now that is surprising. I didn't think it was listed as an option and I would think that 99% of them came with it. Not wanting to be disrespectful but are you sure you don't have one?
    Alan
  12. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,619
    South East
    Jimmie
    There is an older thread I think where someone made the same observation ie not fitted
  13. conscom
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Scottsdale Ferrari just confirmed that later model F430's do not have a Master Battery Switch. The switch location on my 2007 F430 is just a rubber plug. While installing a backup camera system, we connected a battery maintainer which is simpler than switching the battery off anyway. Thanks for all your input.
  14. 993turbo
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Just as I wrote above.
    I think they all have the actual switch, but on some they dont have the actual tool to use it and the unit itself is covered by a plug, not visible. Remove plug, look inside, insert tool and voila.......
    :D
  15. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    My scud is a 2008 and has the plug. You access the screw head by pulling out the plug.
  16. conscom
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Will check again when I get back to the shop. Thx guys.
  17. zzade46m3
    zzade46m3 Rookie
    Aug 20, 2013
    48
    OC CA
    Maybe I misspoke yes the tool is not there. I haven't taken the rubber plug off to see what's behind it. Either way I just use my CTEK.
  18. conscom
    Jan 6, 2008
    467
    Vancouver BC Canada
    Gary
    Just checked. Nada. Void of anything. I just use my battery maintainer anyway. Just avoid having to jump start the car.
  19. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Not too sure why you connect the maintainer. If you work on the car then the battery has to be disconnected. Do you remove the battery cable and connect a maintainer? If the battery is disconnected then there will be no drain -- therefore no need for a maintainer.
    Sign me confused.
    Alan
  20. ideloera
    ideloera Formula Junior
    Jun 2, 2015
    525
    Chicago
    Isi
    Hi, I have a 2007 F430 coupe.
    Same here. I removed the rubber plug and there is nothing there, you can actually see a piece of the aluminum chassis. I am planning on changing my battery to an Odyssey 34R-PC1500T-A this weekend, just not sure how to switch off the battery as I don't see a Master battery switch.
  21. yangstein
    yangstein Formula Junior
    Mar 23, 2015
    571
    Orange County, CA
    Brian
    I used it once and do not want to use it again. Of course it kills battery drainage but once you put it back on, then you will have to put the radio code back. Then you will hear alarm go off every 3 minutes as you drive wondering what happened... You will have to get out of the car, close the doors, lock it with remote, then unlock it to reset the car. I use battery tender every Sunday afternoon even I would take the car out during the week days.
  22. Rbwiii
    Rbwiii Formula Junior
    Aug 9, 2014
    606
    Cali
    BW
    I have a 07 430 spider and it came with tool....
  23. Dward69
    Dward69 Rookie
    Apr 2, 2015
    9
    I have a 2007 f430 no rubber plug or switch for battery shut off.
  24. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,907
    Isle of man- uk
    You guys need to get the right info here- the switch is in the negative line, not the positive so if you work on the car it can still be live. Also when you turn this isolator switch it does not break all the negative connections, as far as i understand it - the negative clamp has small aux cables but these are not effected.
    My 08 has the switch but they did not supply a key after some time in 07- a standard T40 tork key fits- best to have 1 in the car in case of fire as it might be help.
