For starters (or should I say, to begin with), it's on the forward left side of the engine bay. Notice the vacuum canister.
I have an 85 qv cab. There are two wires grounded just below and right (inboard) of the digiplex that seem to have that same black outer sheath. they are grounded there by the digiplex. My car is on the lift, so I cant trace them back right now. But if the wire you are holding originates at that ground near the digiplex I can follow it to its destination later when I lower the lift later tonight.
Hi, Thanks for your help, I need to know where the connection I'm holding in the picture goes. Where is the ground on the digiplex so I can plug it back on? What else should be attached to the digi boxes other than the plugs?
the wires on my car that resemble the one you are holding are grounded just below the digiplex and then they dissappear behind it into a larger harness/protective sleeve. I see nothing above the digiplex area that resemble those wires. I'd pull off the digiplex and see if there is anything obvious on the back side.
heres a pic of where they are grounded on my 85 euro cab. They appear to enter the larger protective sheath and head upwards. From that point I can't find it again, sorry. Image Unavailable, Please Login
