Where can I get my Bosch K Jetronic refurbished? | FerrariChat
Discussion in '308/328' started by cessna, Oct 26, 2010.
  1. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Hi,
    Could anyone recommend a place to have my Bosch K Jetronic refurished and re callibrated.
    Model is 0438100034 and airflow meter 0438120207.
    I live in Europe.
    Regards,
    Stephen
  2. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    Larry Fletcher, he ships world wide. Flotech.com. Larry is more than glad to help you with advice also. I had him rebuild my WUR when I could not get a proper A/F curve. Fast service and reasonable prices. lost
  3. Steve Magnusson
    26,507
  4. drsmith30
    drsmith30 Karting
    Jul 24, 2009
    66
    Winter Park, FL
    David
  5. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    larry's the man. he's like a wizard. i've seen him fix these things by just touching them.
  6. Dr Tommy Cosgrove
    36,228
    Birmingham, AL
    Tommy
    He is a remarkably likeable guy too.
  7. mwr4440
    57,700
    Bavaria, The 'Other' Germany
    Mark W.R.
    Stephen,
    There is a place in Nurnberg Germany but unless you have a HEAVY wallet that needs a LOT of lightening (THEY ARE VERY, VERY EXPENSIVE), go with Larry Fletcher.
  8. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Thanks for all your help. I emailed Larry for a quote but still no reply.
    Yeasterday spoke to another mechanic who is really good on Alfa'a and he beleives that I must have an air leak in the system which is depressurizing the fuel system.
    Believe me guys, I'm f..kin lost here. I guess I will put it on a trailer and drive it up (via sea) to Sicily and take it to a Ferrari shop.
  9. tatcat
    Sep 3, 2001
    11,013
    rick c
    be patient. he's really busy as it's just him and his wife doing everything.
  10. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    +1000 Larry Fletcher. i did a core swapout and Larry is a great guy! i saw the before and after via dyno, Larry's rebuilt unit obviously fixed a small niggle.
  11. carl123meyers
    carl123meyers Rookie
    Jun 2, 2010
    45
    houston, texas
    carl meyers
    also plus 1000 for larry!!
    He is at sema this week so try to get ahold of him next week!!
  12. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    This is an email report I got today from KMI petrol injection uk.
    Hello Stephen,
    Have finished testing parts this morning.
    Fuel distributor has tested ok, all calibration figures correct.
    The inlet union to the fuel distributor has a filter in it please check this is not blocked.
    Air flow sensor is ok, paid attention to the fuel pump cut out on the side which is making and breaking. The co screw seems to be set in the correct position and the screw moves ok.
    Warm Up Regulator, the warm pressure is in spec but the cold pressure is to low, this would make the engine run rich during warm up.
    Injectors, 3 are fair to good and 1 is poor.
    Cold start injector is ok.
    I will be changing all injectors with new ones. Do you think car will start eventually?
    Stephen
  13. fletch62
    fletch62 Formula Junior
    Mar 8, 2004
    333
    Fairhope, AL
    Larry Fletcher
    Hi Stephan,
    We have been out of town. But also we have never received a message from you.
    If you are still having Problems please give me a call.
    001-251-929-3771. I will do my best to help you get your Car running.
    Greetings from sunny Alabama
    Larry
  14. PittsS2APilot
    PittsS2APilot Formula Junior
    Jun 29, 2007
    857
    Gulfport MS
    Joe
    Fletch is da man!
  15. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Thanks Larry.
  16. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Last Saturday I installed the fuel system back onto my car, however not all is working fine. I will contact my mechanic to check it out for me.
    What should happen is that on actual starter engagement the fuel system starts to operate, but in my case the minute ignition electric power is on, the fuel system starts resulting into a flooded system. I then remove the fuel pump relays, start the engine with the fuel inside the system, then place relays back and start it up.
    The car exhaust is black with high idle.
    Any ideas from your side Larry.?
    Others opinions welcomed too.
    Stephen
  17. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,301
    Isn't it the metering plate being pressed down that starts the fuel flow? (i.e. is that set up correctly or is it jammed for some reason?)
  18. tomberlin
    tomberlin Formula Junior
    849
    Bethesda
    tom berlin
    #18 tomberlin, Nov 21, 2010
    It sounds like possibly the mixture is adjusted too rich. This can make the fuel distributor feed fuel even when the air flow sensor is at rest position. It's worth gently adjusting the screw a bit at a time to see if this is the cause. A little adjustment goes a long way so keep track of how much you turn the screw. How did this problem originate?
    Also, the fuel pressures, both line pressure and control pressure, are a great help in diagnosing this system and hooking a gauge up is not a big deal. It would be beneficial long term if you got a gauge for future problems even if only to help you to post pressures for further help.
    TomB
  19. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    The problem was sudden, the car engine just switched off.
    First, since I taught it's electrical I changed one cracked distrinuter cap, then found fuel pump was not working so replaced same. Still nothing although I had spark and four wet plugs.
    Mechanic told me that Bosch K Jetronic was the problem, so I took it out and shipped to KMI UK for servicing.
    The only fault they found was that the fuel warmer regulator cold temperature pressure was inop, so I changed the regukator and replaced all 8 injectors with brand new ones.
    The rest is yesterdays history.
  20. tomberlin
    849
    Bethesda
    tom berlin
    Do you know if fuel is coming out of the injectors? I had one CIS car, not a Ferrari, on which the cold start valve had gotten stuck open. You can take an injector out and turn on the ignition to see if it's passing fuel. Be careful where the fuel goes, of course.
    TomB
  21. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    I feel really down.
    I'm just goning to store the car in garage and not think about it for a couple of days.
    Stephen
  22. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    And the plot thickens.!!!
    I started my baby and left her running idle for about ten minutes. I was happy with the engine running after 3 months even though at idle power.
    Switched engine off, after a while oil started flowing out of the pressure relief situated at the clutch housing.
    Spoke to mechanic on the phone, and he instructed me to check oil level and odours of fuel in engine oil. He was on the money.
    He explained that car is so rich that fuel will drip dowm via piston rings and into the oil.
    I hope nothing is seriously wrong with my engine.
    Why? Why? Why.?
  23. docmirror
    docmirror Formula Junior
    May 6, 2004
    781
    Ft Worth TX
    First, change your oil, it is contaminated with fuel and will not lube correctly. Next, you need a tool called a 'Colortune' (see ebay or the like). It will screw in place where a spark plug is and give a visual indication of the fuel and air ratio.
    Now, that you have these accomplished it is time to setup the mixture of the CIS head. It is very common to have it badly out of adjustment when the CIS head is cleaned, injectors changed, warm up reg changed, or fuel pump renewed. It sounds like you've had several of these things done. We will assume you do not have access to the CIS pressure gage kit.
    If you have cold start injection, remove the connector from the cold start injector at the air plenum, we don't want to dump fuel in at this point. Make sure your safety plug is connected to the CIS head so that the pump doesn't run constantly with the key on(causes flooding so bad it will run into the crankcase). Key off, battery fully charged.
    At this point, you should have a car in which you can turn on the key, and the cold start will not run, and the fuel pump will not turn on until the starter is engaged. Install the Colortune in one of the rear plug wells and use the long black tube adapter and the spark extender that came with the kit. You should be able to look down the tube and see the glassine colortune element at the bottom.
    The adjustment screw on the CIS head is located in a small well between the air metering plate and the distributor head. It takes a 3mm long hex tool. Look at the large round air metering plate with the air cleaner duct removed, and make sure it's resting on the stop at the top and not depressed at all. Tap it gently down with your finger a few inches, it should return to the stop smoothly with a very slight delay. It has a damper that inhibits air flutter from reversion, this is also moderated by the intake plenum and the intake flex tube. If this is working correctly you may proceed to adjust the CIS mixture screw.
    Setting the initial mixture is easy. Remove one of the new injectors from the intake manifold. If you have removed the line from the distributor, reconnect it so you have the injector loose, and the line connected. Put the injector in a small cup so you can view it. Insert the 3mm hex tool in the CIS adjustment well, and engage the tool in the adjustment screw. When the tool is seated, there will be radial resistance felt, otherwise the tool is not engaged in the adjustment screw. The screw is very sensitive to adjustment. Perform the next step as quickly as you can.
    Remove the Bosch elec safety connector from the rear of the CIS head. Turn the key to the on position, and listen for the fuel pump running. Check the injector in the cup, you will likely see fuel dribbling into the cup. The adjustment screw is: 'Lefty Lean, Righty Rich'. Turn the adjustment screw to the Left(anti-clockwise as viewed from above) until the fuel is not dribbling out of the injector and into the cup. If the fuel were not dribbling into the cup after a minute or so, press the air metering plate down slightly and see that fuel is dribbling into the cup, let it come back to the resting stop and adjust the mixture screw to the Left slightly. Key off.
    Put the injector back in the intake, and re-connect the line from the distributor. Plug the safety Bosch connector back on the CIS head. Have the tool still in the CIS head adjustment. Hopefully the engine will start and run without the warm start injector being connected. Let's start with that. There should be some fuel in the cylinders already. It may take a bit of throttle playing to make the engine start. Look at the colortune, and adjust the mixture based on the legend. If it is very yellow(likely) make the adjustment to the Left to lean the mixture. If it is blue or white, you may need to adjust it a bit to the right. Try to stay as lean as possible to start with and get the extra fuel out of the engine. Allow the engine to warm up normally with the tool still in the CIS head. Do not exceed 1800RPM.
    Once the warm up regulator has warmed up fully, it's time for final adjustment. Set the throttle to about 1400-1600RPM so that we are away from the idle set point. Turn the adjustment screw very slowly Left until the engine just starts to die from fuel starvation. The Colortune will be white, and you will see it missing on some strokes. You will also hear the engine popping a bit which is lean-misfire. Now, very slowly turn the mixture screw adjustment Right, or Rich and monitor the Colortune. You will see it change from white to blue. At this point, you are in the correct zone. Small changes will be needed for final adjustment. Once you have the Colortune set between blue and white, shut off the engine, remove the Colortune, reinstall the spark plug, connect the warm start connector to the warm start injector and connect the air cleaner duct to the CIS head.
    Drive the car, and see if it will accelerate in 2nd gear rapidly. If so, you are done. If you hear popping, or if the car is running hot, you may to adjust the mixture very slightly right to make it a bit richer. Do not adjust it much.
  24. cessna
    cessna Karting
    Dec 4, 2008
    226
    Malta
    Stephen Grech
    Thanks for all the help guys.
    Even spoke to Larry Fletcher on the phone, and he really is a remarkable guy. Thanks Larry.!!
    Now managed to get the airflow sensor sorted out. The Flap must have got mis centered during shipment. Now fuel pump is excited on starter engagment.
    However car still is not starting until I remove the fuel pump relay. Since off to work, tomorrow will replace accumulator, change oil and give it another try.
    Once again thanks Guys.
    PS. Keep on ideas flooding in pls.
