Noticed a hole in the wheel well, anyone know what material it's made out of? Wanted to try to patch it up. Image Unavailable, Please Login
Had an unfortunate incident with what I thought was a small rock...turns out it was a chunk of concrete curbing and it wasn't that small. Damaged my under tray which I think is the same material. Cleaned up the backside, laid some fiberglass to repair it, painted with GM specific semi-flat/satin paint
They are fiberglass with a black mat gel coat. I believe I have 3 out of 4 wheel liners available in good shape for cheap if you can’t fix it and it’s one I have.
I thought they were a thermoplastic but, the photo sure looks like fiberglass. Unless you are concourse, you should cut out the slats and replace with stainless screen.
