wheel sizes | FerrariChat
wheel sizes
Discussion in '308/328' started by Sigmacars, Mar 15, 2020.
  1. Sigmacars
    Sigmacars Formula 3
    1,251
    I have a 1988 328 NON ABS and i am looking for new wheels,all i know is the bolt pattern 5x108 the rest i don,t know can you help with a complete Drawing or all other dimensions i need for ordering new wheels,
    thank,s
    miketuason likes this.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,849
    Cerritos, CA.
    If it’s the same as the 308 QV, the front is 7” wide and the rear is 8” wide and the offset is about 11mm
  3. Steve Magnusson
    26,990
  4. jdjagguy
    jdjagguy Karting
    Sep 11, 2007
    76
    Enid Oklahoma
    Richard Crump
    I could use your take offs if they are in reasonable/repaintable condition.
    Richard C
  5. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,302
    Gold Coast, Aust.
    Patrick
    I've got a set in excellent condition I don't need
  6. Sigmacars
    Sigmacars Formula 3
    1,251
    is there a diagram around with all the dimensions of the 1988 / 328 NON ABS wheel?
  7. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I was looking for one to get some 16" rear wheels cast but an exhaustive search came up blank. What other dimensions do you need as I am going to get measurements for the drawing soon.
  8. Ferraridoc
    Jun 20, 2012
    17,302
    Gold Coast, Aust.
    Patrick
    I don't get it: you already have a set of 328 wheels. All you need to do is measure them.
  9. Sigmacars
    Sigmacars Formula 3
    1,251
    I know i can do that but the are on the car so diagram would save me taking the of that,s all
  10. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    If you have to do it anyway, could you take some measurements for me :)
  11. Ferraridoc
    Jun 20, 2012
    17,302
    Gold Coast, Aust.
    Patrick
    Fair enough
  12. Longstone Tyres
    Longstone Tyres Formula 3
    Sponsor
    Feb 2, 2006
    2,054
    Dougal
  13. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,223
    MO
    Omar
    Do you have concave or convex wheels? 88 was a change over year.
    Convex:
    16x7, ET15.15 Front
    16x8in ET15.45 Rear
    Concave:
    16x7 ET38mm Front
    16x8 ET63.5mm Rear
    Here is an old photo of my 328 with 575 front wheels all around (ignore the mess)
    I still have the wheels/tires available for sale but havn't gotten around to listing them.
    Car looked great and drove much better. From memory it was a 225 front/255 rear setup with correct sidewalls/size for the 328.
  14. JC Andruet
    JC Andruet Karting
    Jan 16, 2013
    196
    Hi Derek, what width 16" rear wheels are you planning on having produced ?
  15. JC Andruet
    JC Andruet Karting
    Jan 16, 2013
    196
    Hi Steve, interestingly in Post 1 of the thread you've linked to, the OP states :
    "Ok here it is for future reference:
    Pre ABS 328:
    7in Front is 15.15
    8in Rear is 15.45"
    Whereas in Post 7 he states :
    "308/328 PRE ABS: 7" with +11mm Front; 8" +11mm Rear
    328 ABS: 7" with +38mm Front; 8" +63.5mm Rear
    And in my recent thread on this topic :
    https://ferrarichat.com/forum/threads/308-gtb-s-carb-i-and-qv-wheel-et-numbers-and-images-wanted.624756/
    It seemed to be confirmed that the ET numbers of 11 (ish) are in fact correct :
    "- Yes, the offsets for the 16" wheels were indeed 11.15 and 11.45 (up to, and including, the "série 1" 328s, but NOT the "série 2" 328s, which have a different suspension, and very different offsets)"
  16. Auraraptor
    Sep 25, 2002
    14,223
    MO
    Omar
    #16 Auraraptor, Jul 15, 2020
    That was me...I was the OP.
    We confirmed with a physical wheel it was ~15 for late concave 328s (early 88). See here
    https://www.ferrarichat.com/forum/posts/137981899/
    (also I am not a moderator anymore, so I can't go back and edit old posts any longer...I also realized I flipped the concave/convex name/specs above..sorry about that)
    Here are photos:
  17. JC Andruet
    JC Andruet Karting
    Jan 16, 2013
    196
    So the 308 7 & 8 X 16" wheels have a different offset to the early 16" 328 items ?
  18. Auraraptor
    Sep 25, 2002
    14,223
    MO
    Omar
    Limited data tells me at least two variants of the original 328 concave wheel were both ~ET15 as listed above...they were the most common version circa '86-early '88. There were *many* variants made for different markets around the world. I have never seen most to get numbers off them. Nor have I ever seen an '85 spec wheel... Mind you, I have only ever held later 328 wheels (I had an 88.5)...the rest comes from photos of wheels over the years.
    308 16'' wheels are quite rare...as you know far more common are the OEM 14s or TR 390. Back in the day, people would buy 328 wheels to swap out their TR390s as they were far more readily available and much cheaper then the OEM 16s. Old data states it was: 16x7 ET11.15 front and 16x8 ET11.45 rear. I don't have a photo confirming. I never did get numbers for 14s.
    Mondials are their own beasts with very different numbers.
  19. Steve Magnusson
    26,990
    Yes, a small difference. When people say 308QV and non-abs 328 wheels are the "same offset", what they really mean is the difference in offsets is small enough that either can work on either chassis.
  20. JC Andruet
    JC Andruet Karting
    Jan 16, 2013
    196
    Hi guys, I'd like to contact a board member on here, but I can see no way to PM/DM or email them. Does this function need enabling on my account ? Or am I missing something simple ?
    Edit : I see that by clicking on the user's name, it brings up a box with "Start a conversation", is this the method for sending a PM ?
  21. Auraraptor
    Sep 25, 2002
    14,223
    MO
    Omar
    Yes, it is.
  22. JC Andruet
    JC Andruet Karting
    Jan 16, 2013
    196
    Many thanks :)
    Auraraptor likes this.
  23. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    I almost have enough interest to get some 16” wheels cast. They would be 7-8” front design and 8-9” rear. I think we can get away with one mould as the lips can be rolled or machined to give the different widths and the extra groove near the spokes can be machined. Price would be about £350 each plus shipping a any duties.
