Wheel base, length of TRC? | FerrariChat
Discussion in 'Recreations & Non-Period Rebodies' started by Vintage Ferrari, Jan 22, 2017.
  1. Vintage Ferrari
    May 1, 2011
    42
    I've found conflicting information with my google searches and couldn't find the answer when searching this forum. Does someone know the wheelbase and overall length of the TRC body? Are all TRC bodies the same dimensions? Specifically looking for wheelbase and length for '57 625 TRC.
    Thank you in advance.
  2. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    500 TRC wheelbase = 2250 mm according to a number of sources including Ferrari. RM Auctions stated wheelbase of 625 TRC 0680 MDTR as 2250 mm at 2012 auction. There were only 2 625 TRC cars, 0672 MDTR and 0680 MDTR.
    I do notice that one source gives the 625 TRC wheelbase as 2350 mm and another 2500 mm which seems way over.
  3. Vintage Ferrari
    May 1, 2011
    42
    Thanks, that is the conflicting information and I find 2250 mm (88.5 inches) seems so close, as the car looks so long and slender.
  4. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,398
    I am quite sure it is 98 inches (2489mm).
  5. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    Please can you let us know how you are quite sure? Thank you.
  6. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    #6 miurasv, Jan 24, 2017
  7. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    The only source that I found for the length of a 500 TRC was one of Dean Batchelor's books which states it as 155 inches, 7.5 inches shorter than a 250 TR (same source).
    Width = 64.5 inches.
    Height = 38 inches to top of headrest.
    Wheelbase of 250 TR = 2350 mm.
  8. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    Question for Vintage Ferrari: Is the reason your question is in this section because you are intending to make a 625 TRC replica?
  9. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    Not all 250 TR have 2350 mm wheelbase. Some are 2320 mm.
  10. Vintage Ferrari
    May 1, 2011
    42
    I am making a 1:5 scale version of the body. From pictures of 0608, the #211 car I have the overall length, relative to the wheelbase is 1.73 times as big. Just need to know what the wheel base is or I guess for that matter the overall length.
    Did all the TRC cars use the same frame?
  11. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    OK. Did you see post 7?
  12. Vintage Ferrari
    May 1, 2011
    42
    I did. My question was the frame, not the body.
  13. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    #13 miurasv, Jan 24, 2017
    You may need the drawings for the length of the frame. I believe the frame tipo for the 500 TRC was 518C. I'm sure you know the C in TRC refers to Appendix C, changes/requirements in which are said to be directed mainly at the bodywork.
  14. Vintage Ferrari
    May 1, 2011
    42
    #14 Vintage Ferrari, Jan 24, 2017
  15. 2006scinta
    2006scinta Rookie
    May 31, 2011
    47
    I'll check what I made the one I built and post it soon.
    I don't exactly replicate so I wouldn't go off mine.
  16. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    0680 has a 250 3 litre V12 engine in your picture. The original 625 had a 4 cylinder 2.5 litre engine. What about the gearbox? Does it use a different one from 500 (625)? Might the wheelbase be different from original due to these factors?
  17. 360modena2003
    Jul 11, 2009
    2,398
    There is a gentleman that is building replicas, and he took measurements from a real one at the time when all the measurements were done.
    I believe he posted here as well.
  18. 2006scinta
    2006scinta Rookie
    May 31, 2011
    47
  19. miurasv
    Nov 19, 2008
    10,037
    Cardiff, UK
    Steven Robertson
    Do you know the chassis number of the car he took the measurements from?
  20. Vintage Ferrari
    May 1, 2011
    42
    #20 Vintage Ferrari, Feb 8, 2017
  21. Vintage Ferrari
    May 1, 2011
    42
    #21 Vintage Ferrari, May 17, 2017
