What's your steps for removing the undertray? | Page 2 | FerrariChat
Discussion in '360/430' started by wheelman76, Apr 1, 2018.
  1. RedNeck
    RedNeck F1 World Champ
    11,971
    The CSA
    Me
    Get in shape and you can do it while the car is parked on the ground. Done it...but usually back it up onto ramps and take it off the easy way. Y'all with F1's might be wary of that process, backing up onto a grade seems to put extra wear on the clutch. Manual allows you to control it a bit more.
    shifter likes this.
  2. imahorse
    imahorse F1 Rookie
    4,267
    WI
    Dustin
    Here is how I do it without a lift.
    1. Drive car onto 3/4" board on one side.
    2. Undo all of the bolts. I have long arms so I can do it with the car on the ground.
    3. Undo half of the middle tray.
    4. Slide the back tray forward so it clears the beam across the back.
    5. Pound another beer and curse myself for not getting a lift.
    6. Slide the tray back with the front of it to the side. If you have issues just remove the rest of the middle tray. It should now be completely on the ground.
    7. Pound another beer because here is the tricky part. The board underneath one of the wheels should give enough clearance for the tray to clear the undercarriage. Jack up the otherside at the jack point and rotate the tray towards the side with the jack out the side of the car. IIRC you need to alternate between jacking the car and lowering it while sliding the tray out so that it can clear the jack.
    mathewr likes this.
  3. delaney
    delaney Formula Junior
    Nov 8, 2003
    711
    St Petersburg, FL
    PETER DELANEY
    After spending lots of time removing the undertray for oil changes I noticed two large grommets. Guess what they were for .
    Extreme1 likes this.
  4. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,323
    Honolulu
    Kevin
    You can see them in post 14.
  5. lkstaack
    lkstaack Formula Junior
    Dec 9, 2020
    252
    San Diego
    Lars
    Kevin Rev'n: are you happy with your two-piece 8" Race Ramps, or do you wish you had 10"?
  6. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    I use a floor jack with a hockey puck in the round recess to raise one side, then slide a car ramp under one rear tire. I put the ramp backwards so I can get the tray out. Then I do the other side the same way.
    fotostars and mathewr like this.
  7. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    I use 2 low profile alum floor jacks to lift both back sides almost simultaneously.
    Then the fronts.
    Ramps cost $100 pre-cut to size at HD
    Piece of cake
  8. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Wrt re-installing the undertray, swearing helps if doing it alone.
    Just saying!
  9. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
    What are the dimensions of those ramps? Did you use 2x8 or plywood? Any support in the center of them?
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    You can always use 2 pair of Rhino ramps ..less than a hundred dollars
    Sent from my moto g(7) using Tapatalk
  11. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
    Yes, that's a good economical solution. Unfortunately, car ramps are usually only about 6"-6 1/2" tall. Good enough for a quick visit underneath, but not if you're spending some time under there.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    I think the rhinos are 8 - 8.5 iirc ..
    I do like your build .. i did something for my mid rise lift where put budded up 2 @ 2x8x10 on each side to elevate car enough to clear arms
    The mid rise lift works fantastic for the 512TR
    What size wood and dimensions did you use exactly
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    8x4 railway sleepers work well
  14. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
    I bet they're good for an upper body workout too. Those would be some heavy ramps.
    Sent from my SM-G781U using FerrariChat.com mobile app
  15. grtoz
    grtoz Karting
    Dec 14, 2010
    161
    Byron Bay, Australia
    Graeme Towers
    I use Race Ramps 10" wheel cribs. They make removal of the undertray easy.
    Sent from my SM-G955F using FerrariChat.com mobile app
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    I just bolt 2 of them together and i have a 16 inch wide platform. Jack car up on a couple trolley jacks and slide them under the wheels. If u want it higher then double up- works pretty well for me
  17. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    No plywood. Not safe
    2' x 10"s and 1 box of 8 x 3" Deck Screws
    Power Driver
    1/2 hr to assemble
    Cuts were 20 x 21" and 8 x 10" for the sides
    21" width allows the wheel to sit just perfect at 8" above floor level
    2 low profile floor jacks with the power stroke allowed for easy lifting of both sides almost simultaneously and safely
  18. lkstaack
    Dec 9, 2020
    252
    San Diego
    Lars
    Gotcha! That think must weight a bit.
  19. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Not really but if I'm lying under it I'm good with the extra strength.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    Thanks for sharing
  21. hessank
    hessank Formula 3
    1,866
    Canada, Florida
    Fred
    Thanks but it wasn't my orig idea.
    I believe I first saw the suggestion by Black360 (I believe). I just modified it to suit me.
    flash32 likes this.
  22. Metastable
    Metastable Formula Junior
    My set up is similar to his... must be a Canuck thing. I have thought about the double jack method, but I have only one jack..... same exact model though. I made wood blocks and also have plastic ramps. Usually put the plastic ramps under the front wheels backwards and the blocks under the rear wheels.
    Also, I have Rennstands, which allow me to raise the car by the jack points with the top section of the stand attached.
    To put the tray back on, I support it with 2 conventional jack stands.... once 3 or so bolts are in it is easy.
    Just a note, made my blocks using 2 cut sections of 8” x 8” posts attached side by side.
