What's normal oil pressure range? | FerrariChat
Discussion in '456/550/575' started by Fcarhappy, Feb 24, 2013.
  1. Fcarhappy
    Fcarhappy Karting
    Dec 19, 2012
    104
    Been gone from home for months and haven't been driving my 550 for a while (at best once a week for less than an hour). I also own 7 cars so in the rotation I get confused at times. Point is today I went out for a drive and noticed that the oil pressure gauge was ranging "high" pulling off the accelerator backed it off but of course acceleration brought it back up slightly over the third mark. In the past I think it tracks around 80 or 90 after warm. So was it high because it hadn't warmed?
    I know low oil pressure is bad but what about high??
    Long ago I read something about high oil pressure in 550's but I've long since forgotten the point they were making (isn't old age wonderful)
  2. 308 GTB
    308 GTB F1 World Champ
    11,643
    New Jersey
    Barry Wolinsky
    A failing oil pressure sender gives high readings. Sometimes cleaning the sender connection does the trick.
  3. atlshaver
    atlshaver Formula Junior
    286
    Atlanta, GA
    +1. Cleaning the connectors fixed mine
  4. 308 GTB
    11,643
    New Jersey
    Barry Wolinsky
    #4 308 GTB, Feb 24, 2013
    Yes, it's good preventive maintenance and you can check the sender's clearance of the torsion bar at the same time...
  5. Fcarhappy
    Fcarhappy Karting
    Dec 19, 2012
    104
    Where's the sender and how do you clean---sorry for sounding stupid but I'm not much of a mechanic. Again thanks for the prompt help.
  6. 308 GTB
    11,643
    New Jersey
    Barry Wolinsky
    #6 308 GTB, Feb 24, 2013
  7. Fcarhappy
    Fcarhappy Karting
    Dec 19, 2012
    104
  8. Eli355
    Eli355 Formula Junior
    Oct 12, 2010
    678
    Long Island, NY
    Eli
    What is the proper oil pressure range.
  9. Cribbj
    Cribbj Formula 3
    #9 Cribbj, Feb 25, 2013
    The 550 WSM states the oil pressure should be between 5 and 6 bar @ 6000 RPM and oil temperature over 212F. It also states that less than 4.5 bar @ idle is normal.
    Some 550's run a bit higher than that; my '99 hits 130+ on a cold morning startup but settles down to the range above when hot.
    Mike Sheehan wrote this in 2002 "As for the costs and pitfalls of ownership, the early 550s run much too much oil pressure and occasionally blow the oil filter apart, creating a major underhood mess. Should the oil filter start to leak as an inattentive owner cruises down the freeway, cheerfully chatting on his cell phone, a Ferrari dealer will be happy to install a new engine for a mere $75,000 or so. A rebuild will be in excess of $30,000 if you haven’t managed to spin bearings or score the crank. Preventing the problem is as simple as removing a few spacers in the oil system, which involves an hour’s labor, and drops the oil pressure to real–world levels."
    The Good and Bad of 456 GTs and 550 Maranellos
  10. 308 GTB
    11,643
    New Jersey
    Barry Wolinsky
    Hi John,
    I get similar readings as you under the conditions you specified. My 550 is maintained by a Factory-authorized service center and so UFI filters are installed and Shell Helix Ultra SAE 5W-40 oil is used.
    The oil pressure gauge on the dash can be checked for accuracy with a gauge connected at the oil sender housing. They did that once with my car several years ago to diagnose a failing sender unit.
    I read Michael Sheehan's article a few years ago. I wonder if the oil filters actually ruptured or just loosened. I know my shop properly torques the new filters being installed.
    Barry
  11. Cribbj
    Cribbj Formula 3
    #11 Cribbj, Feb 25, 2013
    Barry I'd always wondered about the wisdom of adjusting the pressure relief/bypass valves on these oil pumps. Their purpose is to allow the system to bypass "some" oil flow if the pressure gets too high - key words being "bypass some oil flow". So to me, adjusting the pump so it bypasses at a lower pressure is dangerous because you could be limiting oil flow to a part of the engine that needs it.
    So if the "system" pressure is too high, where is the restriction and can it be relieved? Initially I thought it might be those teensy weensy oil filters, so I've changed those to much larger and freer flowing Cantons - which didn't help the oil pressure at all. Next I tried changing the oil itself from a 5W-40 to a 0W-40 - that had little to no effect also.
    So the "restriction" if there is one, has to be either in the engine itself or the oil cooler, and since the oil cooler is on the scavenge side of the system, it's doubtful that it's the restriction.
    Any other theories or viewpoints?
  12. 308 GTB
    11,643
    New Jersey
    Barry Wolinsky
    #12 308 GTB, Feb 25, 2013
    John,
    I once asked the chief technician at my shop about any need of adjusting the pressure relief/bypass valves. He felt confident that there was no need to do so and that all parts of the engine were being properly lubricated. He didn't seem terribly concerned about high oil pressures indicated by the gauge on the dash. He told me to expect low pressures when idling, 75 or so at highway speeds in 6th gear and readings about 2/3rds up the gauge at the track. He told me to let him know if I didn't get those readings and he'd take a look.
    During the four years I tracked my 550, I was on the same service schedule as the Challenge cars; brake fluid changes before events and oil changes after events. So lots of fluid changes, 5-6 times a year. Last year, I was getting some abnormally high oil pressure readings. Not like when the sender failed and I was pinning the needle, just high readings. He cleaned the contacts at the connector and everything read as usual. I drive the 550 in all types of weather. Maybe some tape around the connector will help keep things clean.
    Barry
  13. Cribbj
    Cribbj Formula 3
    Yea, I'd be concerned that if we removed a few spacers to lower the pressure, perhaps "all parts" of the engine would not then get proper lubrication. Don't know if that makes sense the way I've said it, but for example, if it takes 140 psi to lube all parts of the engine with cold oil, then which part of the engine isn't going to get fully lubed if we reset the relief/bypass to 100 psi?
    In my opinion, ideally you'd want all the oil from the pump going to the engine, and the relief/bypass would only be there to protect the system in case there was a major obstruction/blockage. However if there were an obstruction/blockage, the engine would be cooked anyway due to oil starvation, so which result is worse?
    In the real world, the engine's needs are probably quite a bit less than the full output of the oil pump, so when the pump supplies more flow than the engine can handle, the system pressure rises, and the surplus oil gets bled off/bypassed. It would be good to know, however, how low the pressure can be set and still ensure everything gets lubed properly.
  14. 308 GTB
    11,643
    New Jersey
    Barry Wolinsky
    #14 308 GTB, Feb 25, 2013
    Right, John. The chief tech at my shop is a wise fellow and always enjoys this type of discussion. I'll bring it up again when I'm over there on Saturday.
    Barry
  15. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,414
    Los Angeles
    Bill Karp
    #15 wbklink, Mar 2, 2013
    Hi John, My Tech Eric at the Auto Gallery did something to a small spring (took a little piece off) the first time he worked on the car to bring the op down, I ask why and he gave the reason above.
    It's been perfect ever since.
    cheers,
    bill
  16. Cribbj
    Cribbj Formula 3
    Bill, it's good you have a guy like Eric helping you look after your car. He seems like an out of the "yellow box" thinker who doesn't mind going outside the Ferrari parts bins or the WSM for better solutions :)
  17. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,414
    Los Angeles
    Bill Karp
    That's for sure John,
    Like the thing he had made to stop the actuators from twisting.
    I'm also lucky when in Vegas because I have the guys at PENSKE-WYNN who also look after me, I would ask about changing all the fluids and they would look at em and smell em and say, no all good, we will check again next time you're here.
    Between all these people and the fact that I drive it, I have a perfect running 550 with 47k miles !
    cheers,
    Bill
  18. 308 GTB
    11,643
    New Jersey
    Barry Wolinsky
    I'm sorry, John. I forgot all about this thread.
    I did ask the chief tech about this that Saturday I was there. He explained that several years ago there was a problem with the construction of the UFI filters and he had seen several cases where they failed. He mentioned that he carefully and properly torques the filters to insure they don't loosen. He mentioned that overtightening them might weaken the housing which would make them prone to failure.
    Sorry for the late response.
    Barry
  19. Genyosai
    Genyosai Formula Junior
    May 28, 2008
    501
    SC
    Nicholas
    #19 Genyosai, Dec 12, 2013
    My oil pressure is usually around 3 bar at idle (at operating temps), but today idled at 5 bar. And cruising at around 2.5krpm, oil pressure was at around 8 bar, but is usually more around 6 bar. The weather here today is 48 degrees, but I've still never seen it this high. As a matter of fact, today is a warm day by comparison, and the oil pressure hasn't run this high. I've taken pics; one of the oil pressure while crusing, one of the water temps and one of the oil temps.... both of which were normal.
    Should I be worried? I checked the oil level... it's dead on. So it's not over-filled. I'm really thinking the sending unit is acting screwy. Perhaps some water on the contacts?? This did happen right after washing it.
  20. Cribbj
    Cribbj Formula 3
    #20 Cribbj, Dec 13, 2013
    Nick, you might clean up the terminals on the sender and see what happens. It's a known issue with these senders that when there's enough crud on the gauge terminal for a partial path to ground, it'll give wonky readings.
    I've been working with a company to come up with a boot for these terminals to protect them better. Does the pic below look interesting? (disregard the fitting on the end of the sender - that's related to another project for remote mounting these senders):
  21. AKINSB
    AKINSB Formula Junior
    Feb 15, 2013
    502
    Santa Barbara
    Alex K
    Looks interesting. I assume the cap will also work on a 1995 456 GT. Had similar problems with my sending unit until cleaned.
    AK
  22. 308 GTB
    11,643
    New Jersey
    Barry Wolinsky
    Yes it does, John. That would prevent the majority of sending unit "failures."
    Barry
  23. Genyosai
    May 28, 2008
    501
    SC
    Nicholas
  24. Cribbj
    Cribbj Formula 3
    According to the Ricambi cross reference page, this same sender was used on nearly every Ferrari since the 348 / 512TR's and Maserati's since 2002.
    Maybe we could interest Daniel in stocking these covers.
  25. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,150
    Bay Area Calif.
    Dave
    Do they come in turquoise? that's my favorite color ;)
