What was the quickest/fastest period in F1? | Page 2 | FerrariChat
Discussion in 'F1' started by SSNISTR, Jan 17, 2011.
  1. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Indeed - Apparently, that's one of the reasons they won't allow active suspension - They could *sustain* over 5-6G's (with suitable rubber) - The guys would have to wear g-suits!....
    We're also deep in the land of diminishing returns wrt to aero (which has come a long way in just a few years) - I forget the details, but you need a *huge* amount more power to go from 200 to 250 than from 150-200.
    So, even going from ~800 to ~1500hp isn't going to make you a lot faster on the straights - But you're going to be quicker (over a lap) 'cos you can get to the top speed in less time.
    Cheers,
    Ian
  2. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    Sort of explains it a bit here.
    [ame]http://www.youtube.com/watch?v=jk1t6S737Cs[/ame]
  3. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,741
    Atlanta
    John!
    Even if they did allow active suspension, the tire technology to really take advantage of it is just not there. Or maybe it is but a set of tires would last 8 laps.
  4. madmaxatl
    madmaxatl Formula Junior
    Mar 22, 2007
    687
    Buckhead, Palo Alto
    Don Johnson
    The F2002-2004 are the fastest cars F1 has ever seen. The improved aerodynamics and V10 engines are a devastating combo. If you want to talk the most fun to watch and drive, thats another story entirely. For that it goes to the turbo cars of the 80's. Theres a clip somewhere, I think top gear featured it, of Piquet overtaking senna on the outside on full opposite lock. You aren't going to see anything like that today.
  5. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    #30 Fast_ian, Jan 18, 2011
    No argument from me there - But, given the incentive I reckon those 8 lap tires would become 30 laps real fast......
    OK [It's debatable, but we'll go with it ;)]
    The V10's made ~1000 at their peak, right?
    Put a 1400 turbo together with todays aero, and kick some ass!.....
    Show me the link ;)
    Cheers,
    Ian
  6. CRG125
    CRG125 F1 Rookie
    Feb 7, 2005
    2,619
    Los Angeles, Ca
    Vivek
    You put a V10 in today's cars and they would be the fastest.
  7. Chicko
    Chicko Formula 3
    This is not correct.
    When 1400HP is quoted, its only stating the peak power. Also, 1400 to 1500bhp was in qualifying trims only, race distance boost pressures achieved ranged from anything between 500 to 900HP.
    As I'm sure you know, peak power is only a very small statistical measurement of an engine's overall ability and performance. These 80's turbos were very peaky by nature, with crud engine mapping and combustion, in comparison to modern turbo technology.
    They had extremely uneven power and torque graphs, with extensive lag and narrow peak power bands only available at very limited rev ranges. They were also terribly inefficient and unreliable when running on high boosts.
    The last of the F1 V10's were extremely efficient, flexible and light weight for combustion engines. With the last of the breed topping 19'000rpm, 900bhp and weighing less then 200lbs.
    And when you talk about modern F1 engine performance, you have to also take into account there Seamless shift Transmissions, Electronics and Hydraulics systems and a whole host of other components, as modern F1 cars are designed as a complete package, with every part being custom deigned to work in complete harmony with every other. The engine its self is also an integral load bearing part of the chassis, so to introduce a primitive 80s turbo engine into one of these finely honed packages like the F2004, and to presume it would be make the car faster is simply ridiculous.
  8. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    I don't understand how you can say that;
    - The V10's reached ~1000HP at their best.
    - The turbos reached ~1400 - *And*, they're smaller than the V10's so "packaging" is easier.
    My money is on todays car (& the best tires) with 1400HP every time.
    My 02c, cheers,
    Ian
  9. madmaxatl
    Mar 22, 2007
    687
    Buckhead, Palo Alto
    Don Johnson
    Skip to 3:20 (piquet overtaking senna on full opposite lock)
    [ame]http://www.youtube.com/watch?v=kC9ZeCr5bEA[/ame]
  10. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Agree with everything you said.
    OK - My bad - I should have said "the modern equivalent of" the 1400hp turbos.
    I'll stick with the premise that (all else being equal, as already noted) more power = reduced lap times though. :)
    Cheers,
    Ian
  11. CRG125
    CRG125 F1 Rookie
    Feb 7, 2005
    2,619
    Los Angeles, Ca
    Vivek
    It all about useable horse power.
  12. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    *Sweet* - Thanks for posting.
    Yep, those days are gone - "Aero" is the God now - Go sideways, go off.......
    Cheers,
    Ian
  13. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    #38 SSNISTR, Jan 18, 2011
    FALSE. If you toss in a 1400 horsepower turbo era motor they would not be as quick around the track as the turbo era motors were VERY peaky. Plus they ran way less power during the races as they were not reliable like the V10's. Motorsport magazine talked about this in the mid 2000's. 800-900 useable (V10) horsepower is going to make for a quicker car around a track then 1400 peaky (turbo era) horsepower.
  14. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    I was just proving the point that they could hit those speeds, and did in the F2001.
  15. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    #40 SSNISTR, Jan 18, 2011
    From researching this more it does seem like most people site the F2004 as the quickest F1 car around a track, although Motorsport magazine choose the F2002. Either way that backs my early to mid 2000's theory. :D
    Not to mention how dominate the F1-2000, F2001, F2002, F2003-GA and F2004 were.
  16. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Indeed.
    "Horsepower sells engines, torque wins motor races." [Dunno who said that first?]
    I remember the *brutal* power delivery of the turbos - "on" & "off" seemed to be criteria. But, the boys figured 'em out and went pretty quick - Give 'em modern electronics & fancy ass turbos coupled with todays cars and look out..... [Won't be allowed as "they" want around 750-900hp in order to remain "safe" of course.]
    Cheers,
    Ian
  17. Chicko
    Chicko Formula 3
    A quick and simple way to compare various early 2000's Ferrari F1's can be done by looking at the ultimate lap times for each car achieved around the Fiorano during 1000s of km done during testing.
    Ferrari F2004 0'55.999 Michael Schumacher 2004
    Ferrari F2003-GA 0'56.33 Michael Schumacher 2003
    Ferrari 248 F1 0'57.099 Felipe Massa 2006
    Ferrari F2005 0'57.146 Michael Schumacher 2005
    Ferrari F2002 0'57.476 Michael Schumacher 2002
    Ferrari F2007 0'58.366 Felipe Massa 2007
    Ferrari F310B 0'59.00 Michael Schumacher 1997
    Ferrari F2008 0'59.111 Mirko Bortolotti 2008
    Ferrari F399 1'00.226 Luca Badoer 1999
    Ferrari 412T 1'00.31 Jean Alesi 1994
    You can also look at the fastest laps for various circuits that were mostly unchanged through out that period, and many are the still the same too this day, and you will see in most cases cars from 2004 broke the records, which still stand.
    Magny-Cours - 1:15.377 - Michael Schumacher, Ferrari F2004
    Nürburgring GP - 1:29.468 - Michael Schumacher, Ferrari F2004
    Monza - 1:21.046 - Rubens Barrichello, Ferrari F2004
    Melbourne - 1:24.125 - Michael Schumacher, Ferrari F2004
    Interlagos - 1:11.473 - Juan Pablo Montoya, Williams BMW, 2004
    Sepang - 1:34.223 - Pablo Montoya, Williams-BMW FW26, 2004
    Bahrain - 1:30.252 - Michael Schumacher Ferrari - F2004 ( GP Circuit)
    Montreal - 1:13.622 - Rubens Barrichello, Ferrari F2004
    Silverstone - 1:18.739 - Michael Schumacher, Ferrari, F2004. (Bridge Circuit)
    Hockenheimring- 1:13.780 - Kimi Räikkönen, McLaren, 2004
    Hungaroring - 1:19.071 - Michael Schumacher, Ferrari F2004,
    Shanghai - 1:32.238 - Michael Schumacher, Ferrari F2004
    San Marino - 1:20.411 - Michael Schumacher, Ferrari, F2004,
    Monaco - 1:14.439 - Michael Schumacher, Ferrari F2004
    Catalunya - 1:17.450 - Michael Schumacher, Ferrari F2004 ( Pre Chicane)
    I could not find a lap record for the Indy F1 Gp circuit??
    The other notable tracks absent from this list, Spa and Suzuka, which were wet weekends during the 2004 season.
    So since all the evidence points too the 2004 cars being quickest of there era, and have still yet to be bettered (80's turbo cars are simply not even close in terms of ultimate lap time), i think its has to be said that the 2004 cars are the fastest of all time, with the Ferrari F2004 being the fastest of them all.. :)
  18. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    #43 SSNISTR, Jan 18, 2011
    I checked that too, but they for whatever reason don't list all the cars....plus that is a very short tight track.
    I agree too, that the F2004 is probably the quickest F1 car ever, although as I said Motorsport magazine says the F2002. Not sure what they are using as their basis. Either way, it seems the cars from 2000-2005 are tops overall with an occasional car before or after that period popping in....
  19. Chicko
    Chicko Formula 3
    The F2004 is a direct evolution of the F2002 as the rules where stable and did not change much during this period. If the F2002 was quicker then the F2004, why would Ferrari not just race the older car?
    I could be wrong, and I have also not read the article you mention, but it sounds like the Motorsport Magazine writer has it wrong, as all the evidence points to the F2004 package being faster.
  20. SSNISTR
    SSNISTR F1 Veteran
    Feb 13, 2004
    8,046
    SFL
    I agree with you. But even without rules changes the later car is not always faster. Example, the F2005 is "slower" then the F2004.
  21. Chicko
    Chicko Formula 3
    The one set of tires per race rule was a huge change for 2005, and was the main reason for the slower lap times. And as we know this rule effected the Bridgestone runners the most.
    And they also introduced a rule that engines were required to last two Grands Prix without being changed, so as a whole, the car's were down on power compared to 2004 as the emphasis was on reliability.
  22. 430lover
    430lover Karting
    124
    My first answer. Always
  23. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,383
    ESP
    Bas
    I do have to clarify that I didn't mean an 80s car with the last V10 running gear would be quicker than todays car...
    I think that, because of the far more efficient power of these cars, that if the 80's turbo cars had todays V10's, they would be quicker in their era.
  24. Remy Zero
    Remy Zero Two Time F1 World Champ
    Apr 26, 2005
    23,446
    KL, Malaysia
    MC Cool Breeze
    What's the winning ratio of the F2002 vs the F2004?
  25. Chicko
    Chicko Formula 3
    F2002 - 17 races - 15 wins ( MS 11 wins, 0 DNF - RB 4 wins, 5 DNF )
    F2004 - 18 races - 15 wins ( MS 13 wins, 1 DNF - RB 2 wins, 1 DNF )
    F2002 won 88.2% of the races it entered.
    F2004 won 83.2% of the races it entered.
