What Soap Used on Ceramic Coated Car | FerrariChat
Discussion in 'Detailing & Showroom' started by Tranch, Jan 22, 2024.
  1. Tranch
    Tranch Rookie
    Jul 9, 2023
    13
    Richard Tranchida
    I am having my 2022 Roma Ceramic.
    What soap should I use to not remove the ceramic and have it last a long time.
  2. LI2782
    LI2782 Formula Junior
    Jul 19, 2010
    917
    Koch chemie gentle snow foam is nice, but all of the coating manufacturers make their own. I’d ask your installer what they recommend.
  3. Andrew in AZ
    Andrew in AZ Rookie
    Jun 24, 2007
    19
    Scottsdale
    Andrew
    I always come back to Meguiars Gold Class. I have used Meguiars Gold Class for years on several different coatings and haven't found anything worthy of switching.
    dRoger45 and jcurry like this.
  4. 020147
    020147 F1 Rookie
    4,483
    Midwest
    I’ve been happy with Gyeon.
  5. JoeCab
    JoeCab Formula Junior
    364
    Colorado
    Joe C
    Soap will not remove a ceramic coating. It's tough and needs to be polished off.
    However, some car washes are specifically made to enhance (boost) a ceramic coating so they look better longer...
  6. Autodetailing
    Autodetailing Karting
    Oct 5, 2021
    220
    As the above says, once fully cured the only way to remove a ceramic coating is by machine polishing / hand polishing, a medium cut polish normally does the trick.
    Just use a good quality PH neutral shampoo from a reputable company and you will be fine.
    I always recommend people to stay away from " street car washes ", as some of them use very cheap chemicals that may reduce the life of the ceramic or worse, damage the paintwork.
    A lot of people dont realise that the ceramic coating is primarily applied for the sole purpose of protection from the elements, and not added gloss or shine.
    So dont forget to wax your car at least once a month or more if used as a daily driver.
  7. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    I'm sorry, normally I would disregard comments such as this but I had to step in. This is completely false, there is a ton of misinformation about what a coating can and can not do such as protect from rock chips, scratches, etc. but I have never heard of having to wax a car that has had a ceramic coating applied. A coating is basically a wax on steroids that is meant to last years (if its a proper coating and maintained correctly) and alleviate the need to apply a wax. Should you use a maintenance spray? Maybe, it all depends on the coating so I would ask your installer for any information he/she can give you about maintenance. In most cases a detail spray product is not mandatory but will add a nice glow or some slickness to the paint, it shouldn't be absolutely necessary to keep the coating working. I'll agree that the coatings purpose is not to add gloss or shine and it is debatable if a coating adds any gloss at all, if so, it is minimal and the naked eye would not be able to tell. The gloss and depth comes with the paint correction and jeweling stage in preparation for the coating as the last step product. Once the coating is applied you are theoretically locking in that "just detailed look" for the life span of the coating. This is why it is important to find a detailer that really knows what they're doing.
  8. Autodetailing
    Oct 5, 2021
    220
    We shall have to disagree i am afraid Jason on this one.
    In my opinion, the more protection you can give the ceramic coating the better, and it depends on what type of life the car will have once it has left your hands.
    This is especially critical if the car lives outside, is a daily driver or subject to everything the elements can throw at it.
    As you are well aware, bird poop, tree sap and tree lime from leaves will test the very best ceramic coatings.
    I am not saying you must wax your car after it has been coated, but i think its always best to explain to the customer what is achievable with the coating if cared for correctly.
  9. BudgetPlan1
    BudgetPlan1 Rookie
    Jun 13, 2007
    14
    NE Ohio
    While there are some waxes (generally hybrids) that are coating compatible, using a traditional wax or sealant on top of a coating is considered a step backwards as far as functionality goes. Some thoughts:
  10. MobileJay
    MobileJay Formula 3
    Sep 9, 2006
    1,441
    Houston
    Jason Cavallo
    Correct. Think of a coating as a living, breathing organism. When it's on the car it is working to shed off the dirt and grime and leave a clean surface. Once the car becomes very dirty, you are suffocating and clogging up the pores of the coating and it stops working as well as it should until you wash the car again. This is why we tell people that a coating requires a bit of maintenance with regular washes to work as it should. A wax won't work in the same manner that a coating will or at least not as well. So when you apply a wax onto the surface of a ceramic coated car, you are now just getting the protection from the wax and beading/sheeting characteristics from that wax and not the coating. Stick with one or the other but no need for both.
    BudgetPlan1 likes this.
  11. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,948
    MD and NE
    Robbie
    Wax over ceramic? Been detailing my whole life and never heard of such a thing. Wax = 1990 Ceramic = 2024
    Oengus likes this.
  12. dRoger45
    dRoger45 Rookie
    Aug 17, 2017
    48
    This is the best one to try! We've been using it for years with great results. After mounting the new brake pads and tires from 4Wheelonline on my friend's new Camaro project, we washed it with Meguiars Gold and looks like new.
  13. DiamondDog
    DiamondDog Formula 3
    Aug 29, 2021
    1,420
    Orange County, CA
    Any quality car soap can be used on ceramic coated cars.
    If you are going to contact wash, pH neutral is good. When they shart adjusting pH levels out ofmthe neutral range you have to be more careful, but those soaps cut through grime better.
    Right now I am using Jaxwax soaps as they seem to be at the good balance of quality and good price point. If money was no object, I would use Csr Pro products.
    On a side note, I wish this forum section was more robust with detailing posts.
