What should I be washing my car with? | FerrariChat
Discussion in 'Detailing & Showroom' started by iheartf430s, Aug 16, 2024.
  1. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    196
    TN
    Ed
    I've always used Turtle Wax' MAX Power car wash, just because It's available at the Dollar General down the road. But I've only ever had mid-level sedans and SUV's and wanted to make sure I'm just a quality product on the 430 (also being that it's 17 years old) and has a PPF on the hood, mirrors etc...
    What do you use?
  2. blkfxstc
    blkfxstc Formula Junior
    856
    TX
    Eric
    Chemical Guys here.
    ryalex likes this.
  3. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,378
    Santa Clarita, CA
    Most of us just wipe the car down with a no water type spray wash. Chemical Guys or Adam’s makes good stuff too.
    Only when mine gets really dirty will I spray it with the hose. That’s only happened once in 3 years.
    JohnnyRay, Bundy and Mike Morrissey like this.
  4. iheartf430s
    iheartf430s Karting
    Feb 17, 2023
    196
    TN
    Ed
    Interesting. I got my car a few weeks ago, and it was raining when it was delivered. I whipped it down, but noticed water marks and a bit of dirt on the diffuser and wheels, so I wanted to give it one good wash 1st.
  5. Trev450
    Trev450 Formula Junior
    Mar 11, 2024
    525
    Trevor H
    When it gets dirty enough to need a wash I use Autoglym car shampoo on mine.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    Power washer with appropriate nozzle and pressure
    Portable power washer with bucket ..self contained
    Mr Pink in a foam cannon
    Powerful leaf blower and reverse shop vacuum
    Shade , rinse with power washer
    Foam up with power washer and foam cannon
    Let dwell
    Rinse again with power washer
    Foam again and create bucket of soapy water as well
    Using 8 mitts clean car ..one mitt per panel start high and end low .. one for roof One for roof ..after each panel put to side and never use again until you wash mitts after yii finished
    Rinse using power washer
    Then one more rinse using portable power washer with self contained water supply of distilled water ..one gallon or two would work
    Blow the car .spot dab with MF any place you need
    SCantera, montegoblue, docf and 2 others like this.
  7. BudgetPlan1
    BudgetPlan1 Rookie
    Jun 13, 2007
    14
    NE Ohio
    Sent from my iPhone using Tapatalk Pro
    338Lapua, Carbon Bits and Ak Jim like this.
  8. FerrfanFL
    FerrfanFL Formula 3
    2,229
    Florida
    Ara
    and i thought I was anal. lol
    NbyNW, David993s, montegoblue and 6 others like this.
  9. Bundy
    Bundy Formula 3
    May 18, 2011
    2,474
    Arizona & Kentucky
    Anir
    Oy vey!! I would never have the patience! [emoji23]
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,661
    Central NJ
    Dominick
    It sounds more intense than it is ..faster than you think..it takes more time to put stuff away than washing car .
    AD211 likes this.
  11. vdm9
    vdm9 Formula Junior
    373
    long island new york
    vasilios
    All good tech/ideas
    Unless its therapy and you have the time, call a pro to truly clean, detail, and show you how to maintain and protect your finish - paint, PPF, glass, wheels, carbon fiber, interior, etc.
    This way you don't damage your finish, don't buy expensive stuff you won't use, and its done right.
    Plenty of good detail guys that have shops and that are mobile.
    Just my two cents
    vdm
  12. DutchFerrari
    DutchFerrari Formula Junior
    Apr 7, 2022
    726
    Bollenstreek - Netherlands
    Jeroen
    Same here, my whole "detailing closet" exists of Chemical Guys products, used plenty of other brands in the past like meguiars, turtlewax, petes and many more, but i find the chemical guys products the easiest in use, and they dont give me a headache from the chemical smell like alot of other brands do when doing more than just washing the car...
  13. EnzoItaly
    EnzoItaly Formula Junior
    Sep 29, 2016
    266
    I use Swissvax products: they’re awesome.
    Some of their specialty products can save you a lot of money, e.g. to rejuvenate rubber.
    It doesn’t have to be complex or take a lot of time: using the ‘two bucket’ method gives already great results. Waxing your own dream car with your bare hands is a really special experience.
  14. DreamCarrera
    DreamCarrera Formula Junior
    Oct 25, 2006
    822
    S.E. PA
    Eric
    Personally, I would stay far, far away from using Turtle Wax (or any other product from a dollar store) on any car that is special to me. My guess is that these cheap car washes are too harsh and do not properly lubricate the paint surface to avoid scratching.
    I like P21S Shampoo. I also find their Paintwork Cleanser excellent for cleaning paint every now and then.
    The wash instructions given in post #7 are great for a dirty car. When my cars are only slightly dirty (i.e., dust from sitting in the garage or light dirt from a drive or two in the counrty on dry roads), I use Optimum No Rinse (ONR) to wash my cars. I use a two-bucket method with the ORN and first spray the car down with a "quick detailer" made from the ONR wash. Or, if the car is only a bit dusty, I simply clean using the quick detail spray made with the ONR. The key is to use a lot of product and a light touch to avoid marring the paint.
  15. ryalex
    Aug 6, 2003
    25,726
    Las Vegas, NV
    Ryan Alexander
    +1 the dealer's detailer turned me on to it years ago. Especially their leather cleaner, wipes to a dry matte finish without leaving an oily sheen.
    The real trick is once you satin wrap or satin/"Stealth" PPF you can use a duster to brush off dust and mud, and then non-ammonia window cleaner - or Chemical Guys matte wrap spray - and wipe and spritz the car clean in about 5 minutes flat.
    blkfxstc likes this.
  16. Andviv
    Andviv Rookie
    Jan 8, 2024
    16
    Reston, VA
    Andy Vv
    Was thinking of using this to do a quick wile down after a ride… but after reading this thread, I am more confused than before
  17. Graz
    Graz Formula 3
    Oct 15, 2012
    2,327
    New Jersey and Florida
    Graziano
    I use Meguiar's as well for quick touch ups between drives too. Good product and trust me I've tried just about all of them . Just spray liberally so there's no dry spots and potential scratches from the microfiber towel. As far as washing any brand name car soap is fine. If you have a foamer better yet but if not soap in a bucket with water and another bucket with clean water to rinse the sponge or mitt off. Don't have to kill a mouse with an elephant gun.
  18. LondonParis
    LondonParis Formula Junior
    471
    Houston/London/Paris
    Bill Coates
    I use it all the time. Don’t skimp on the number of rags and it does an amazing job.
    Bill
    Andviv likes this.
  19. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,653
    France
    I use Vulcanet wipes, it needs some work but the result is typically not bad.
  20. jpfsunolefan
    jpfsunolefan Rookie
    Jul 27, 2021
    41
    Harrisburg, PA
    Jason
    I’ve tried and really like the products from Jay Leno's Garage.
  21. Solid State
    Solid State F1 World Champ
    10,427
    Maximus Decimus Meridius
    Be sure there are no petroleum products in the Meguiar's.
    Andviv likes this.
  22. jimmyr
    jimmyr Formula Junior
    Oct 10, 2004
    339
    Scottsdale, AZ
    Jim
    A couple of different thoughts on this; newer cars have newer better sealing seals, say next to the side window glass etc. Older cars 250's etc., may have older sealing rubber that may have hardened or shrunk a little and may not keep water from running into the doors. These older construction techniques usually have alloy door skins wrapped around steel door frames. Water sitting down there may/will cause damage. Ditto for those wire wheels. Have used Meguiar's Quick Detailer for the random dust over the years and have no problem with even older paint.
  23. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,097
    Calif
    Brett
    I like anal...oops bad boy!
