What have you done to your Ferrari Today? | Page 96 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    You would be astounded about how much less fatigue there is. Long drives are suddenly easy! I had no idea the noise caused so much fatigue.
  2. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,795
    Australia
    Mark R
    Yeah but I think he doesn't want to look like a call centre telephone operator while driving his car... :) :)
    Banzairacer likes this.
  3. Aircon
    100,524
    Peter
    As if anyone looks at me with a car that looks like that.
    Rosey likes this.
  4. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,185
    Gold Coast, Aust.
    Patrick
    Fixed
  5. Aircon
    100,524
    Peter
    That doesn't make sense
  6. Banzairacer
    Banzairacer Formula Junior
    486
    San Diego, CA
    Sanjeev Thohan
  7. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    After adjusting my accelerator pedal stop screw, took the 308 to have dinner with my wife in Village of Arroyo Grande, Calif. It accelerates very good.
    thorn, eyeman1234 and miketuason like this.
  8. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    Used my Chinese made wifi 5mm HD borescope and IPAD to verify no loose parts in all the intake ports. I could see the intake valves easily by putting the borescope past the open throttle plates. I was missing a steel bushing which goes over the carb stud after a shop worked on it. Scope worked great!
    I also used it to verify my carbs were not on the full throttle stops to prevent stress on throttle cable when pedal was on stop. I also checked my Alfa Engine piston / cylinders were not damaged.
    JuLiTrO likes this.
  9. GordonC
    GordonC F1 Rookie
    4,162
    Calgary, AB, Canada
    Gordon
    There you go, it's allowed to attenuate the high noise levels of the 308 exhaust.
  10. Banzairacer
    486
    San Diego, CA
    Sanjeev Thohan
    try explaining that to Officer Friendly behind the mirrored shades....."let me introduce you to my friend BIlly (the club)"
  11. rdefabri
    rdefabri Three Time F1 World Champ
    Jun 4, 2008
    33,571
    NJ
    Rich
    Put mine up for sale :(
  12. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    Sadly, connected the battery tender
    Making the final push on the deck project
    No time to play
  13. BrockBenson
    BrockBenson Formula Junior
    Oct 18, 2018
    277
    Australia
    Finally finished my major service (cam belts, tensioners, all filters, all oils, rotors, caps) and fixed a couple of minor oil leaks along the way. Last thing left was the ignition leads, which has taken me three months to sort out. Previous owner had fitted Taylor 8.2mm straight boot leads. They where looking old and heat affected (even though car ran fine) but were a pain to fit onto the plugs and he had done a pretty ordinary job of trimming the outer insulation to make them fit into the distributor caps. I wanted a modern look that made it easy to remove the leads and eliminated the need for the extenders. After months of searching the internet and collecting second hand sample leads from parts recyclers (to test fit) I found a set that work pretty well. I chose MSD 8.5mm Super Conductor leads, I like MSD and have never had any problems with them on lots of different cars. I reamed out the holes in the cap +.022" and the leads slipped in. Here's some pics of the final result. Cheers
    thorn likes this.
  14. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I may be replacing spark wires & boots in the coming months; I might hit you up for some hints?
  15. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    I got tired of hearing a loud vibration at 3500 - 4500 on the passenger side near the seat for a over a year.
    I put it up on my lift and remove the cover in the rear passenger wheel well. I found both of the AC hoses were laying on the air intake portion of the body. I put pipe insulation foam around both hoses and installed cable ties to hold in place. No more loud vibration. Yea!!! Photo before foam installation.
    thorn, EastMemphis and Martin308GTB like this.
  16. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    I had the same problem for many years. It appeared after an A/C hackjob, when they tightened the hose fittings on the compressor and altered the angle.
    When I figured out the problem I played with the fittings and found the correct angle so that the noise disappeared even without sound deadening insulation.
    With fittings in this angle position there should be no noise:
    Best from Germany
    Martin
    lm2504me and thorn like this.
  17. Aircon
    100,524
    Peter
    Has ez power steering installed. I have a quick rack. Now I need to get used to using less effort!
    Certainly very nice around the local streets, but need to try out in the hills.
  18. Ferraridoc
    Jun 20, 2012
    17,185
    Gold Coast, Aust.
    Patrick
    What's the matter - have you got puny arms, or something? :p
  19. Aircon
    100,524
    Peter
    Well yes..... But a quick rack with lots of caster really loads up through fast corners
  20. Ferraridoc
    Jun 20, 2012
    17,185
    Gold Coast, Aust.
    Patrick
    Sh** of a job putting it in - took me months. Even with the proper tools and an extra set of hands, it must have cost a fortune if you had someone do it for you.
  21. Aircon
    100,524
    Peter
    Nope. Took a couple of days.
  22. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,848
    Memphis, TN
    Broke 18k miles today! No parts came flying off so I guess it's still going strong.
    (2001 gated Azzurro California / Crema Spider)
  23. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,802
    Cerritos, CA.
  24. Ferraridoc
    Jun 20, 2012
    17,185
    Gold Coast, Aust.
    Patrick
    Ooh! I might do that before I put the grille back on!
    miketuason likes this.
  25. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    What? Wow. Seems like it took me one day to remove, another day to install. (Several days between the two, as I was also replacing bushings, making shims, etc).
