What have you done to your Ferrari Today? | Page 113 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    Changed the clutch, pilot bearing, main seal and spigot shaft seal.
    Dino246gt, Aus_yz, Dane and 2 others like this.
  2. DeRRis
    DeRRis Karting
    Nov 6, 2012
    81
    Netherlands
    Dennis B
    Check the bottom right corner
    Kidasters likes this.
  3. Kidasters
    Kidasters Formula Junior
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    I looked at it about 10 times before I figured it out.
    On the top one - look at the nub where the "i" used to be.
    Bottom one, it's smooth for the GTS.
  4. built2grind
    built2grind Formula Junior
    410
    The Peninsula
    ANDREW
    Went and had my ‘84 QV California smog tested again. Gotta love how California digs in our pockets every 2 years for this. Well jokes on them, it blew so clean I shouldn’t have a problem next time either. I ended up installing a new to me OEM catalytic converter last time (2 years ago) along with new exhaust gaskets and valve adjustment. It’s been running at optimum performance for over 2 years now with no maintenance other than fuel and regular mileage use! I haven’t even changed the oil in 2 years !
    Jbrauer likes this.
  5. absostone
    absostone F1 Veteran
    9,282
    Sir not changing the oil in two years will cost you eventually. It’s the cheapest thing you can do for the health of the engine
    Milkshaker0007 likes this.
  6. built2grind
    410
    The Peninsula
    ANDREW
    Unfortunately I have only put 200-250 miles on it since last major in late 2018 (shame on me). I see no need to change the oil simply because of age. When I hit 1000+ on the trip it will definetly get drained. Thanks for the input and concern, it’s always appreciated.
  7. Harry-SZ
    Harry-SZ F1 Rookie
    @Rosey: The first bagde still has a small tab on the 'S' where the "i" was attached previously
  8. 48969
    48969 Karting
    Jun 27, 2020
    105
    Chicago, Illinois
    J. Michael Collins
    Aus_yz, Kidasters and thorn like this.
  9. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    144
    Austin
    Spent the afternoon on my back under the dash staring at the wiring harness. Decided to clean up stuff previous owners had done between 1979 and 1997.
    After 10 minutes wedged under the dash, realized the job would be way easier with the drivers seat out. Fortunately that's easy to do. Also gave me a chance for some driver's area vacuuming.
    Removed a switch under the passenger dash that I think was used for anti-theft. It wasn't connected any more but looks to have disabled the fuel pump. Wiring didn't look factory.
    Dug into the rats-nest someone created from the stereo install. It was loosely tied up under the steering wheel. I'd use the term "bailing wire" but I'm not sure it was even that good. Got it nice and wrapped, straightened out, and tucked up behind the heater rather than threatening to fall on my leg. Moved the antenna cable that was threatening to get jammed up in the throttle pedal.
    Found an interesting yellow wire running from the fuse box for the instrument lights (right fuse block #5) all the way across the bottom of the harness, behind the radio, under the steering column, and spliced in to the yellow supply to the oil pressure gauge instrument lighting input. The wire is the same style as factory but was held by 3 black zip-ties that clearly aren't. Left it in place until it’s more clear why it’s there. Maybe it’s to bypass the instrument cluster dimmer.
    Removed the clock. It's been missing the adjustment hand since I got it but now it doesn't even move. Time for a trip to PA Speedo or one of the others. While I was in there, found that the backup frunk release does indeed work. That was good news. My rear one doesn't seem to work - need to find a thread on that one. Also found the emergency light socket (part 40179301) was broken. Not like I've ever used it in 22 years or even have the light. Strangely the socket is glass. Is the replacement really only $16? Sign me up.
    Finally got the battery tender cable run from the battery posts to the grille so it’s way easier to connect. Some future owner can say “yeah. That’s not factory...” and we come full circle.
    newark_308, Kidasters, Du_Man and 4 others like this.
  10. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    wow........ just wow
  11. JC Andruet
    JC Andruet Karting
    Jan 16, 2013
    192
    200-250 miles in one run or several smaller 25 mile runs ? If so, that's just fine, but if those miles have been the result of a host of short trips, you'll be filling the sump with gas and water, and the oil will be breaking down, if not through contamination, then through age.
    Richard Widman
    Analysist for cause/effect mechanical problems and oil analyst.
    How often should you change your car's oil if you drive it less than 1000 miles per year ?
    "I have analyzed over 5000 oils over the last 15 years or so, and continuously see this situation, even in my own case with my classic cars. I can't possibly drive all four of them enough. I also see it with farm machinery that is used for our to 6 months a year and then sits. So here are the highlights:
    Never start the engine unless you are going to drive it. The idea of using it to charge the battery is damaging. the oil must get hot to burn off the moisture condensed from the air.
    If it is because you store if for several months and just use it in the summer, change it before storing, then drive normally until the next time you park it for a while. Always store it with fresh, or relatively fresh oil.
    If your trips are few, but at least 10 miles per trip in warm weather, one year is fine with today's good oils. I will admit to forgetting, having just changed my Corvair at 18 months. I sent it off to the lab to see how it is. I sell oil and filters, plus own two oil change facilities, so my 1 year policy is not based on saving money, but on experience with oil analysis.
    If your trips are short, I'd cut it to 6–9 months, although synthetic could make it through the year. If you drive in a very cold environment, stay with the 6 month no matter what oil unless those miles are enough to get the engine good and hot each time. Sometimes helpful to block off some of the cold air flow around the engine, as some of the big trucks do in Canada and other cold places.
    Sending it out for analysis won't tell you too much unless you have a point of reference, especially for the cost. Labs charge the average retail customer $25 to $30. I pay less than $10 and have experience in relating all the results to others and in the engines I have built.
    Forget your manual. It was not written for your case. It was written for an average usage.
    Shelf life of oil has nothing to do with it. Once you open the container, it begins to oxidize. Once you contaminate it with the oil in the engine (you are only changing 80 to 85% of the oil in the engine on each change), the original shelf life is irrelevant.
    Be on the alert for sludge when you look into the filler, or when you drain the oil. If you see sludge building, start taking longer trips, or change more frequently"
    built2grind and Portofino like this.
  12. absostone
    9,282
    ? Elaborate?
  13. built2grind
    410
    The Peninsula
    ANDREW
    Thankyou for all that info, greatly appreciated. To add more to the story for clarification purposes, the car has driven 317 miles in 2 years. A few longer hits around the peninsula at 60-75 miles each averaging 6-8 months in between trips, with some smaller 20-30 mile trips just to move the car back and forth between my house and shop. After a lengthy warm up of course. It will be going in for a “routine” oil / fluid service and general inspection this late spring/early summer but I see no need to change the oil every 3-4 months or even 6-9 months if not driven nor driven hard enough simply because oil manufactures or factory book says to. I do not need to “winterize” my car either as I don’t live in a drastic climate change region, we average 65 degrees 9 months out of year with no snow ever. I do need to keep a tender on it though.
    In the future I will be sure to consult with my factory trained Ferrari mechanic of this era on this issue as I may be overlooking the obvious as stated and recommended in earlier posts. Everyone’s opinion and suggestions are always welcomed and appreciated, Thankyou to all that offered their opinion.....
    lm2504me likes this.
  14. Hinecker
    Hinecker Formula Junior
    Mar 14, 2011
    379
  15. Hinecker
    Mar 14, 2011
    379
    Sorry! I repeated pictures:(
    Bottom one is my pony:)
  16. st@ven
    st@ven F1 Rookie
    Aug 4, 2008
    3,279
    Netherlands
    Steven
    miketuason, Rosey and Jbrauer like this.
  17. Miklas
    Miklas Karting
    Dec 10, 2018
    80
    Luxembourg
    That looks like a fun exercise to try to get in and out!
    st@ven likes this.
  18. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
    Love the timing belt door handle :)
    Du_Man and st@ven like this.
  19. dinoart
    dinoart Formula Junior
    756
    Westminster CA
    David
    aseweepay and miketuason like this.
  20. dinoart
    756
    Westminster CA
    David
  21. lm2504me
    lm2504me Formula 3
    1,088
    Nipomo, CA
    Richard
    I modified a S159B distributor to provide firing of the rear and forward bank ignition coils. The modification consisted of the installation of two new base plates, a long and short point set, and aluminum adapter plate under long set to position the long point set to be 135 degrees from short point set. (45 degree increment) I fixed the base plate to the aluminum plate. The whole aluminum assembly is moveable. Set up the distributor on my distributor tester and verified correct centrifugal advance curve.
    Another thing, I did several test drives with the modded S159B and it ran great, but when I returned home, my engine would not shut off after a drive and turning the ignition switch off. After three times of failing intermittently, I replaced the electrical contact block on the rear of the ignition switch with a new one.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Basal Skull, Rosey and maurice70 like this.
  22. classicalfas
    classicalfas Formula Junior
    280
    Gardiner, NY
    Peter D
    My newly purchased gt4 did not have its flimsy bulk head cover. I located one but it was discolored after so many years. I put a layer of fiberglass cloth and resin on its backside and shot the front with SEM color coat. Looks brand new and much sturdier too. Forgot the before photo.
  23. PT 328
    PT 328 F1 Rookie
    3,957
    Smog checked the 328 yesterday. Passed with flying colors.
  24. miketuason
    Feb 24, 2006
    15,541
    Cerritos, CA.
