What gearbox oil are you using in your 308/328? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Mike328, Jan 27, 2004.
  1. Royal Purple 75W-90
  2. Redline 75W-90 ** NS **
  3. Redline 75W-90
  4. Shell Spirax 75W-90
  5. Mobil 1 75W-90
  6. Castrol Hypoy/c 80W-90
  7. Castrol Syntrax 75W-90
  8. Swepco 201 80W-90
  9. Agip Rotra LSX 75W-90
  10. Valvoline Synthetic 75W-90
  11. Chevron Supreme LS 80W-90
  12. Other (specify below...)
Multiple votes are allowed.
Results are only viewable after voting.
  1. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,652
    The fabulous PNW
    Han Solo
    I use the Redline now and like the way my transmission shifts. Much better, especially cold.
    If I couldn't get Redline in my area I would go with the Royal Purple which is available at my local NAPA store (of all places) and for less than the Redline.
    DJ
  2. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    For the folks who use the Agip Rotra LSX 75W-90, could you chime in with your reasons? Yes, Ferrari was aligned with Agip back in the day. Yes, Lamborhini calls for it in the Diablo. Yes, it seems to be designed for limited slip differential applications. And of course, the weights are right.
    I'm pretty sure the Redline stuff saw a usage spike because a few people tried it, it worked well, and they publicized it in previous threads.
    As for the AGIP stuff, does it have other technical merit? Any shifting problems?
    I'd be interested in hearing other arguments regarding Royal Purple. I'm worried that it, too, has seen a usage spike because it is a big sponsor of the other Ferrari discussion forum website.
    I'm interested in a "consensus" on a gear oil only if it's based on technical merit and direct, shared experiences, as opposed to evagelism!
  3. tele013
    tele013 Formula Junior
    Nov 19, 2003
    761
    Malaga, Spain
    jesus
    Both of them.
    Jesus.
  4. ChrisfromRI
    ChrisfromRI Karting
    Jan 28, 2003
    230
    Foster, RI
    Chris F
    I thought both preference and availability were great too!
    As far as the AGIP goes, I have nothing unusual to report. No chatter, no grinding, only a little stiff into second gear when it's cold out and the car is not warmed up yet.
    Kind Regards, Chris
  5. Glassman
    Glassman F1 World Champ
    I've got Valvoline Synthetic in my car because it was the only thing available here. It shifts better than ever, however I was distressed when I finally got an E-mail back from Valvoline,stating that they do not make any lubricants that are recomended for a Ferrari!
  6. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    As much as the Redline product is lauded, I really didn't notice any improvement in shifting between the Redline and what I had before (Chevron Supreme LS, if you can believe it). I did, however, definitely notice the limited slip differential chatter. It always occurs under brisk acceleration from a stop while making a 90 degree turn, especially right-hand turns.
    This is worrisome, and I've decided to make the switch to a gear oil designed for limited slip applications.
    Of course, it seems that the ideal properties for differentials (slippery) vs. syncros (not slippery!) seem to be in conflict, where any given gear oil represents a compromise of the two.
  7. Steve Magnusson
    26,516
    Mike P. -- no need to do a switch (although it's only 4 qts in your case) -- just add 4% of the Redline Friction Modifier to convert the Redline 75W-90NS into Redline 75W-90 (I'm still at 2%, which helped reduce the chatter a bunch, but will be going back to 4% too).
  8. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    Next time you change fluid, it's easier to mix roughly 1 qt non-"NS" with 3 qts "NS" rather than fuss with additive. Or whatever proportion suits your car.
    As a side note, someone posted some viscosity measurements here a while back. The "NS" is slightly thinner than the non-"NS". This would, in theory, help shifting.
  9. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    So, at fifty votes exactly (a very large sample size!), Redline NS, AGIP, and Mobil 1 by far are the majority gear oils being used.
    I'd be curious to see what people were using before they were using Redline, which in my opinion became commonplace as a result of several FerrariChat threads a year ago or so.
    I had no idea the AGIP was as popular as it apparently is... Since I've got a 3rd gear syncro issue, I'm tempted to try ONE more gear oil before I throw in the towel and pull the transmission. I'm thinking it's going to be the AGIP stuff.
  10. Dave Bendl
    Dave Bendl Formula Junior
    Dec 7, 2003
    804
    Chicagoland
    Dave Bendl
    I just made the switch to Red Line 75w-90NS. Won't know until spring if diff. chatter will be an issue.
    An interesting alternate recommended by my local F-car dealer, is to use a GM packaged product formulated for Corvette posi rear ends. It's also used in other specific GM applications. Their shop uses it without adding additives, and indicates it helps with hard shifting in 308/328's.
    The GM P/N is 1052271 and is packaged in 23 oz containers. GM dealers want $7.39/container. GM dealers that I called had it in stock. The package shows it meets GL-4, not GL-5 specs.
    None the less, I wanted to try the Red Line NS anyway. I have a lift, so if chatter becomes an issue I can easily add the LS additive an oz at a time if need be.
  11. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Doing a Google search on p/n "1052271" as Dave notes, I came up with the product.
    I found a few references to this product:
    "SAE-80W-90 GL-5 gear lubricant (GM Part No. 1052271)"
    "SAE 80W-90 Axle Lubricant GM P/N 1052271 (Canadian P/N 10950849) or equivalent"
    "Fluid type — GM#1052271 petroleum based or GM#12346190 synthetic"
    "My owner's manual states that you should use GM p/n 1052271 gear oil, with NO additional friction modifier fluid."
    My research indicates this is a non-synthetic oil. So far, the consensus seems to be to use synthetic oils...
  12. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    For folks who got their oil replaced at a Ferrari dealer shop or some other Ferrari authorized shop, can you chime in which gear oil you use?
    My suspiscion is that any 308/328 that meanders into any Ferrari authorized (FNA-sponsored or whatever) mechanic is going to get the AGIP treatment?
  13. MARQ
    MARQ Formula 3
    Feb 9, 2002
    1,924
    East Coast US
    Marq
    Mike- Just had this done a couple o' weeks ago by Ferrari of Washington....they use Shell, according to the invoice at least('88 328).
  14. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Thanks for the info... Shell Spirax 75W-90, I suppose?
    Of course, that's their F1 sponsor, right?
  15. f355spider
    f355spider F1 World Champ
    18,028
    Mike, we had a neat "tech session" sponsored by Ferrari of Seattle last spring (2003). In it, they explained that Ferrari is very careful to make sure that the lubricants they use are in almost all cases (rare exceptions) will be backwards compatible with older Ferraris. So this means that you can use the current Shell lubricants at least back to the 308 series with no problems (according to them).
  16. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Yes, I'm resurrecting this thread :).
    I thought I would post info regarding ordering the AGIP Rotra LSX 75w-90 gear oil.
    I ordered from American AGIP [(800) 992-9243]. Total cost for a case of 12 individual liters came to $80.48 with UPS ground shipping.
    I'm putting this oil in this weekend, will post back how it goes.
    --Mike
  17. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    CORRECTION:
    That number for American AGIP should be (800) 922-9243.
  18. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,634
    NJ
    Peter
    Mike - let us know how it works out. I have AGIP LSX that replaced Mobil 1. Shifting is much better -- don't know if it is a better oil or because the Mobil 1 was old (about 5k miles). Second gear is better, but still need to be careful when cold. Chatter is reduced from Mobil 1, but I have had it happen with the LSX. I went with Agip because of the factory recommendation and the debate over chatter issues with NS (I bought the NS and it is still sitting on my shelf).
  19. f355spider
    18,028
    Well, I added enough Redline "friction modifier" to my Redline 75w-90NS to now make it 2% slip additive (regular Redline 75w-90NS is 4%, and too much for the synchros, according to Redline; which may be debatible, btw).
    The results are that I cannot induce any chatter when starting out from a stop and making a 90 degree turn. As Steve Magnusson surmised, I wonder if the standard Redline 75w-90 with the 4% friction modifier would be fine, and that Redline is being overly cautious with this synchro concern of theirs?
    Also, now that I have 3,000 miles on this gear oil, I am noticing the "cold 2nd gear" syndrome return. I just skip and shift to 3rd for a couple miles, just like before. :)
    Dave
  20. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    Dave,
    Seeing your post reminded me that I wanted to share some information .
    Having driven 20M miles in the last year , my Mondial is a kind of rolling laboratory for real-life verification of various concepts. Prior to having a major service done last February @ 60M miles I had been using Redline 75W90 (based upon Redline's recommendation 2.5 years earlier when I purchased the car) I'm assuming that at the dealership they went by the book and put in Shell gearbox oil. Then after the discussions on this board , and a NEW recommendation from Redline, I started using Redline 75W90 NS and have been using it for the last 6M miles.
    I'm sorry, but I haven't noticed ANY change in my gearbox. The cold-second-gear-issue remains unchanged and i've never noticed any "chatter" from the limited slip. Conclusions ? Since i've got 1/2 case of the Redline 75W90 left, i'll be mixing it 50/50 with the Redline 75W90 NS until used up. After that-----? It depends on what is being discussed here at thet point. :)
    Tom
  21. f355spider
    18,028
    Tom,
    Try this: With the car fully warmed up, come up to a stop light/sign, and signal for a right turn. When clear, accellerate briskly, sufficient to almost induce rear wheel spin, and see if you get the "chatter" or vibration from the diff. You may....that is the only time those of us that have experienced this. You will not notice it in normal driving.
    Or, as you say, all may be well. :)
    I'll be changing my gear oil this summer and will use one of the following:
    Shell
    Agip
    Royal Purple
    Redline 50/50 blend...
    These seem to be proven products with a bunch of satisfied users.
  22. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,860
    MO
    Omar
    Redline NS, I dont hear any chatters..yet.
  23. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Must be the only guy using Amsoil here :(
    Have no problems either :)
    Enjoy(ing) the Drive,
    Steven R. Rochlin
  24. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Back up to the top, just for old times sake. The more data points, the better!
  25. f355spider
    18,028
    Good timing. I had Redline 75w-90 NS with 2% slip additive, eliminated the chatter from the diff, but my synchros started crunching....so I dumped it out, and refilled with NS, but this time only 1%. Seems the best compromise...just tiny bit of chatter, but no crunching from the synchros...cold shifting is fine again.
    I believe my car may just be extra sensitive to the synchro thing...(maybe they are worn?)
    Dave
