What gear should you leave a Ferrari in when parked and the engine is off | FerrariChat
Discussion in '348/355' started by FerMaz, Dec 21, 2012.
  1. FerMaz
    FerMaz Formula Junior
    Feb 11, 2007
    355
    So Cal
    Mel
    Am 78 years old and have wanted a Ferrari since I can remember. Thought I had better get one while I still have the time and strength to enjoy it. Just purchased a 348 and am absolutely thrilled. Was reading some internet info on the car and it says that after the engine is turned off the gear should be shifted to lst and left in first gear while parked.
    Would appreciate any advice on this issue. Thanks in advance.
  2. drftfan
    drftfan Formula Junior
    Jan 12, 2011
    357
    Orange County
    Jamie
    That's what I have done on every single car I have ever owned.
  3. surfwolf
    surfwolf Formula 3
    1,698
    Bethany, OR
    Michael Wolfe
    If you use the Hill Engineering transmission lock then you need to place the car into reverse before engaging the locking mechanism. I guess you could reverse the locking plate by 180 degrees & place the car into 5th, but no reason to.
  4. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    Congrats on finally getting that F-car!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  5. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    32,515
    E ' ' '/ F
    Merritt Tockkrazy
    First, or reverse, depending on slope. As mentioned earlier, the Hill lock only allows reverse.
  6. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Inside, outside?
    In my garage the car is in neutral secured with a wheel block.
    Anywhere else in first gear.
    Kai
  7. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    If you don't know about it, think about joining the Ferrari Club of the country you're in.
    There are a lot of great events and people to meet.
    Cheers!
  8. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    If the various components of your handbrake are in good condition (cables, shoes, rear discs/drums) and adjusted properly, then the handbrake should be plenty adequate to hold the car in postition on flat surfaces and low to medium slopes. Personally, I never parked my 348 on major slopes, so I never left it in gear, just in neutral.
  9. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    I own a 355, 6 speed. I never leave it in gear, parking brake is just fine. If I were to park on a hill I would probably leave it in gear.
  10. chas-3
    chas-3 Formula 3
    1,279
    Colorado
    Chuck
    I always put mine in reverse. Maybe just habit from my muscle car days where you had to put the manual tranny in reverse to get the key out of the ignition.
  11. Turbo Ron
    Turbo Ron Formula Junior
    Nov 3, 2003
    262
    West Los Angeles, CA
    Ron Stavis
    First gear here. Thats what I have been told.
  12. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    The F1 owners manual says to leave it in 1st with the engine off. It will even alarm if you turn it off in neutral, but I always leave in in neutral with the handbrake. That's what I've always done with all my cars, except if I'm parking on a steep hill.
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    Leave mine in 1st.
  14. doug_porsche
    doug_porsche Karting
    Dec 6, 2009
    147
    Trying 2 find myself
    Doug
    +1
    If the car is pointing down hill, put it in first.
    If the car is pointing up hill, put it in reverse.
    It is best to always have the engine rotate in the "Normal" direction. Some motors, and I dont know if Ferrari is one but Cosworth motors are, dont like rotate backwards. Backwards makes cam chains/belts tensioner , cams ramp potentially bind/break.
    When in doubt, spin the motor in the correct direction.
  15. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
  16. ClydeM
    ClydeM F1 World Champ
    11,600
    Wayne, NJ
    Clyde E. McMurdy
    My parking brake let go on my sloped driveway. I've also had the car roll with it just it in gear. (Time for a new house )
    So it's always in 1st gear with the parking brake and if there's a curb, wheels turned into it.
    With an automatic, it's park & parking brake.
  17. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    this is what I do...... part of my brain says its a myth.....the other half says "hey no harm can be done, so go on with it"....... sounds a bit dubious but apparently in the 348, the synchros or something get aligned or improve or some "rubbish" like that if its left at 1st when parking and then......wait, the story gets better....... get it back to neutral when starting and then put it into 1st and straight into reverse in one motion.....let the car role back a little and then proceed with your journey........ we asians love superstitions, so hey, i'v been giving it a go for a bit.....not sure if it's really happening or if it's just psychological, but my 2nd gear shifts seems to be getting better!
  18. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    First gear. Why would you NOT do this? There is no wear or strain on anything.
  19. Turbo Ron
    Nov 3, 2003
    262
    Ron Stavis
    I was told whether you face uphill or downhill still use first gear. I use to use reverse if I was facing downhill in other cars. I really do not think it matters too much??
  20. apex97
    apex97 Formula Junior
    Nov 25, 2006
    593
    Stockbridge, GA
    Edward Zabinski
    This is correct with any car, first or reverse. The uphill downhill thing is ideal, but not terribly critical. Its better not to rely on the parking brake only.
  21. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,316
    Palos Verdes
    Vince V
    If I am on a flat surface, it stays in neutral,handbrake on. On any slope its in the gear that keeps it from rolling.
  22. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    Neutral, handbrake on ...
