What F1 Oil are you using? | FerrariChat
Discussion in '360/430' started by fstbiker, Jul 27, 2021.
  1. fstbiker
    fstbiker Formula Junior
    Jun 28, 2012
    508
    New Jersey
    My f1 oil is low and looking to add and bleed the line. What oil are you using? Is ATF oil safe of bad for the seals?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,664
    Central NJ
    Dominick
    Check what color is in there - sometimes PO change to a hydraulic fluid ( green)
    If red .. you can use Mobil 1 Syn ATF
  3. fernanjos!
    fernanjos! Rookie
    May 6, 2021
    26
    Jose Fernandez
    Ferrari uses Shell Donax in its F1 and you should use the same, but I think Shell replaced it with Shell Spirax S4 HDX. This fluid is similar to ATF but it's low in acidity so it doesn't chew the seals inside the actuator. Do not use ATF fluid if you want your actuator work properly for longer time. I've seen what ATF fluid does to seals and it's no good.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,910
    Isle of man- uk
    What level in the tank with system pressurised ? Dont overfill it
  5. AandSC
    AandSC Formula Junior
    916
    Jax, FL
    Allen
    I use the Tutela CS, available from Amazon. Have had no issues but I bleed all of it out every year. Probably overkill but it’s relatively inexpensive and helps me sleep better at night.
    Check your lower F1 fluid lines to see if you have a leak at one of the banjo fittings at the actuator. Mine was leaking.
  6. lkstaack
    lkstaack Formula Junior
    Dec 9, 2020
    252
    San Diego
    Lars
    flash32 likes this.
  7. Flyingbrick242
    Flyingbrick242 Formula Junior
    657
    Northern AZ.
    I was advised by a major contributor of this forum this is what is used in their authorized ferrrari retailer service department...I have been using this for the last four years with annual servicing of F1 system with zero issues. Image Unavailable, Please Login
  8. fstbiker
    Jun 28, 2012
    508
    New Jersey
    it is below the bottom
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,910
    Isle of man- uk
    It should have 18 mm or 3/4 inch when pressurised- use a joiners flexible measuring tape to dip it. If it gets too low you will get air in the system and then you do have problems
  10. fstbiker
    Jun 28, 2012
    508
    New Jersey
    I let it sit over night to check the level, when sticking my finger in only the tip got wet (don't laugh) . So I prob have air in the system. Ill add and bleed it with a Launch 431.
  11. Ray Smith
    Ray Smith Formula Junior
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    I flushed and bled my F1 system with Liqui Moly ... Why they specify ATF for a purely hydraulic system is beyond me ...
    Penzinger likes this.
  12. brogenville
    brogenville Formula 3
    2,214
    Robin
    ATF will have a bunch of stuff (anti-wear, anti foaming etc.) in it thats not needed in a hydraulic system, but whats important is the compatibility with the seals. Generic ATF is just cheap and easy to get hold of, hence why people use it rather than the specific products listed by ferrari.
  13. fstbiker
    Jun 28, 2012
    508
    New Jersey
    How much fluid does the f1 system hold?
  14. jayne simmons
    jayne simmons Rookie
    5
    we use Royal puple Power steering fluid for the F-1 sytem and their transmission fluid in the transmission and believe it shifts better . it has been in there for about a year . it was recomended by a petrolium engineer who said it has a superlative formula is well balanced , will NOT harm seals and has their proprietary additive "synerlec " ? It is a synthetic fluid .
    when we converted we had our indie tech flush out the system as he has the computer that can turn on and off the pump w/ out harming anything ! it was about an hour and a half labor $ well, spent i brought a lot of bottles of the PS fluid , he used most of them !
