What does ASR stand for? | FerrariChat
Discussion in 'Technical Q&A' started by grold, Sep 25, 2006.
  1. grold
    grold Karting
    Aug 23, 2006
    186
    Del Mar, CA
    Kevin Grold
    Is it Anti Skid Response? I will be the one to ask the stupid question.
    thanks, Kevin.
  2. code red
    code red Karting
    Nov 15, 2003
    91
    Acceleration Slip Regulation
  3. Ricard
    Ricard Formula Junior
    Jan 23, 2004
    867
    Donington Park
    Richard C
    Different manufacturers different meanings, Anti Slip Regulation is one (Audi). Its a form of traction control, rather than a full ESP system (Electronic Stability Program). Usually adjusting throttle to help on loose surfaces / leaving junctions etc reducing wheel spin. ESP adds the ability to brake individual wheels to correct understeer and oversteer before it happens (or as its happens, depends on system thresholds as interpreted by a yaw sensor).
    You can usually turn traction control off (ASR) as that helps in snow etc but ESP tends to be on all the time (in "normal cars" its switchable in Ferrari's using the Manetino).
    These systems are usually based on Bosche hardware and each manufacturer names the elements with different titles to create the impression that their system is unique.
  4. f355spider
    f355spider F1 World Champ
    18,026
    "Anti-Spin Regulation" Per article on the Ferrari of Houston website:
    http://www.ferrariofhouston.com/456GTA.htm
    "The ASR (Anti-Spin Regulation) system is integrated into the four channel ABS(Anti-Lock Braking System). "
    Google search is a great thing!! ;)
  5. 3omar
    3omar Formula Junior
    Dec 16, 2003
    326
    United States
    Omar
    Ferrari's ASR, as implemented on the 360, also has the ability to apply the brakes to the rear wheels individually. This is in addition to its ability to cut power when skidding is detected.
  6. Ricard
    Jan 23, 2004
    867
    Donington Park
    Richard C
    If it can brake the driven wheels then thats "EDL" (Electronic Differential Lock) - but nothing to stop Ferrari labelling it all "ASR" or any other name. The feature list is usually (Bosch titles):
    ABS - Antilock Braking System (ability to release brake pressure)
    ASR - Anti Slip Regulation (traction control, using the throttle)
    EDL - Electronic Diff Lock, able to apply brakes to driven wheels independantly
    EBD - Elecronic Brake Distribution, auto brake bias front/rear
    CBC - Corner Brake Control, auto brake bias side to side
    ESP - Electronic Stability Program, able to brake individual wheels
    Benefits are:
    ABS - Maintain steering control whilst emergency braking
    ASR - Reduce wheel spin when pulling off or accelerating
    EDL - Maximise driven wheel traction
    EBD - Maximum braking efficiency, shorter stopping distances
    CBC - Reduce chances of spinning if braking whilst turning
    ESP - Correct or reduce chances of oversteer or understeer
  7. AR!
    AR! Formula Junior
    Apr 8, 2004
    981
    Berlin, Germany
    It´s a German acronym:
    Anti-Schlupf-Regelung
    Direct translation would be anti skid system.
  8. grold
    grold Karting
    Aug 23, 2006
    186
    Del Mar, CA
    Kevin Grold
    Here is what I have so far:
    Anti-Schlupf-Regelung= anti skid system
    I guess it was not such a stupid question after all...but maybe we should start a poll and see which one gets the most votes. Does anyone know how to do that?
    K.
  9. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,676
    LA & OKC
    Kevin
    Another Stupid Restriction
  10. Ricard
    Jan 23, 2004
    867
    Donington Park
    Richard C
    AR! is right.
    Bosch invented these systems and hence the acronyms are German. But each importer creates their own names to match the German acronym but in their own language. That is why there are variations, personally I like MVP's best :)
  11. LightGuy
    LightGuy Four Time F1 World Champ
    44,487
    Texas
    David
    "A" Sports Racer; Where the old Can-Am cars went after that series was disbanded. And by the way ; Thanks once again for that Porsche ! NOT
  12. 3omar
    Dec 16, 2003
    326
    United States
    Omar
    As per the 360 manual, ASR = Anti Slip Regulation. No poll needed. End of story.
  13. grold
    grold Karting
    Aug 23, 2006
    186
    Del Mar, CA
    Kevin Grold
    Could you help out...what page is that on? (I could not find it.)
  14. 3omar
    Dec 16, 2003
    326
    United States
    Omar
    It's on page 5 of the manual at the very beginning under "Abbreviations".
    PS. Mine is the Euro manual. It could be different for US spec cars.
