What did you do to your Mondial today? | Page 8 | FerrariChat
Discussion in 'Mondial' started by ddenboer, Dec 26, 2016.
  1. matfo
    matfo Rookie
    Aug 1, 2013
    39
    Sweden
    18” Speedline magnesium from F355 Challenge, see my reply #156 above for dimension details.
  2. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Yea that’s what I thought but wasn’t sure if they were replicas or something. Looks amazing!
    Drewbdo, moysiuan and matfo like this.
  3. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    446
    Eastern Tennessee
    Howard Scott
    Spent the week going through the front suspension on my 87 Cab. All 8 control arm bushings and 4 shiny new ball joints. Also pulled the wheel bearings apart on both sides, cleaned all the ancient grease out and applied some new stuff. Probably just my head, but the steering seems a bit more responsive and lighter. The lower ball joints were pretty tired, so maybe this accounts for the change.
    matfo and JLF like this.
  4. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    WilyB, Freerange72, Roward7 and 4 others like this.
  5. Drewbdo
    Drewbdo Karting
    Apr 8, 2016
    189
    Atlanta, Georgia
    I know the Post Office has a bad reputation about slow service, but judging by the box, it looks like it took 30 years to deliver your radio! o_O:D lol
  6. BillyD
    BillyD Formula 3
    1,825
    Pacific Northwest
    Bill
    Fixed my Slooooooooooooow paseenger window. Could hardly tell it was moving at all. Now its up in 5 seconds. Motor was drawing 15 amps trying to move it. The tool Martin308GTB makes worked perfectly to keep the cable on the spool.
    Now which of the other dozens of problems should I work on next: heater core cleaning, radiator leak, front shocks, HVAC, oil cooler hose, etc etc
    MvT, djs308 and Drewbdo like this.
  7. BillyD
    BillyD Formula 3
    1,825
    Pacific Northwest
    Bill
    Well you guys should start working on your Mondials, I can't do it all.
    I replaced the Cats with some resonators as the car is going to be strictly a race car :rolleyes:
    So I took it out for a spin today hoping I'd no longer hear the wind noise from the mirrors or the rattle from the sunroof but I don't think its any louder, is that possible? It has some sort of stainless muffler on it so its not the stock box muffler.
    The other thing I noticed is now that the passenger window has been repaired, the drivers side which use to seem fast is now dead slow. So I guess I have to get that 36 year old epoxy grease out of the drivers side motor too.
  8. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,652
    Argent/Brasil
    Guido
    If that window worked better before you should check control the window guides first...out of line by some millimeters are enough to make them slow.Also the horizontal position should be checked.
    Guido
  9. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    85MondialQV, jjason981, WilyB and 7 others like this.
  10. BillyD
    BillyD Formula 3
    1,825
    Pacific Northwest
    Bill
    #185 BillyD, Jan 5, 2020
    My 83QV came to me from sunny and warm San Diego. First thing it did when arriving to the Northwest was drip coolant all over my garage. Either the vibrations on I5 for a 1000 miles in an enclosed trailer loosened most worm clamps holding in the coolant or the change from 80 degrees to 30 made everything shrink. Anyway I have solved that problem and started chasing a minor oil leak. Finally found an oil soaked hose under the rear distributor which I'm now trying to source. Its looking like buying the breather kit from SuperformanceUK is the cheapest way to get some 22mm Oil rated hose or I could buy a 50 foot roll from NAPA but seems like I'd be storing approx. 49.5 ft for years to come. While working on this little problem I may have solved a few others, I found the vacuum lines to the Ignition boxes and the HVAC controller both off. Hmmmm how and when could that have happened?
  11. theunissenguido
    Jan 21, 2004
    2,652
    Argent/Brasil
    Guido
    Cam shaft seal also is leaking.....
    Guido
  12. BillyD
    BillyD Formula 3
    1,825
    Pacific Northwest
    Bill
    Hey you point it out, you replace it!
    :) I know you do good work with fuse boards so a little seal should be easy. Stop by on your way back to the continent. :D
  13. theunissenguido
    Jan 21, 2004
    2,652
    Argent/Brasil
    Guido
    Billy, just remove the 3 bolts on that picture and that round plate with seal come of.No need for me to stop by....you can do this, easely. I strugled several times to stop that seal leak. The final touch whas sanding the shaft with very fine sandpaper before putting a new seal. That maked it work.o_O
    Guido
  14. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Great photo!
    paulchua likes this.
  15. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,445
    Menlo Park, CA
    Paul Chua
    Beautiful, amazing shot!!
    ronfrohock and AndruL like this.
  16. WilyB
    WilyB F1 Rookie
    4,272
    AZ
    FerrariJB, Jeka, MvT and 4 others like this.
  17. FerrariJB
    FerrariJB Karting
    Jun 8, 2019
    69
    Netherlands
    FerrariJB
    4 new Michelin TRX 240/55 VR 390 for my Mondial QV 1983. DOT code 39/19. New rubber. The old, hardened tyres are from 1989. It must be a great differance on the road. I have to wait till march because of the road taxes rules in the Netherlands with old vehicles. I can’t waith...
    Jeka likes this.
  18. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    2cam, Allen S. and FerrariJB like this.
  19. Allen S.
    Allen S. Formula Junior
    Mar 16, 2001
    512
    Morgan Hill, CA
    Allen / AKA tCoupe
  20. ronfrohock
    ronfrohock F1 Rookie
    4,153
    MA
    Ron Frohock
    Wish I could do this type of stuff during the off season. My car has to be stored away. Looks great!
  21. 2cam
    2cam Formula Junior
    Aug 28, 2014
    749
    Austin, Texas
    MikeS
  22. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    #198 JLF, Feb 28, 2020
    Pour some rice and windex inside then slosh them around, the rice will scrub the inside. Buffed the outside with my Griots small 3 inch orbital and some McGuire’s #3 cleaner/polish and black finishing pad. HUGE difference from before.
    Got the rear bumper polished last night as well. Now just have to do the rest of the car. [emoji30]
  23. FerrariJB
    FerrariJB Karting
    Jun 8, 2019
    69
    Netherlands
    FerrariJB
    JLF likes this.
