What did you do to your Mondial today? | Page 7 | FerrariChat
Discussion in 'Mondial' started by ddenboer, Dec 26, 2016.
  1. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Do you know if you have to remove the bumper to get those lights out? I’m going to try and polish mine.
  2. Jeka
    Jeka Formula 3
    1,181
    Rotterdam
    Johan
    That looks very nice! What foil did you use?
  3. Dino2400
    Dino2400 Formula 3
    Feb 21, 2009
    1,297
    To apply the foil it is not necessary to remove the units. If you wish to remove them the bumper doesn't need to come of. Just remove the upper part (indicator) of your unit and you will find the screws which has to be removed.
    3M, my experience is that is quite easy to apply. With a hairdryer you can wrap the foil around the corners very well. A pro could do it even better i think but for now i'm satisfied with the result. Replacement foglight/units are very hard (read: almost impossible...) to find. Especially the EU ones. We should take some extra care for them.
    Jeka likes this.
  4. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    #154 JLF, Jul 11, 2019
    Thanks for reply Dino. I did remove the screws from the plastic turn signal on top but it wouldn’t move so I thought it is more difficult than just removing the screws.
  5. Mechanical Dad
    Mechanical Dad Formula Junior
    Aug 30, 2016
    381
    East Aurora NY
    Josh
  6. matfo
    matfo Rookie
    Aug 1, 2013
    39
    Sweden
    Finally got to mount the 18” 355 Challenge rims. The front tyres is 225/45 and rear is 255/40. I just took a short test drive and it seems to work fine although it’s really tight on the inside in the front. Could maybe add a thin spacer there to get a little more clearance. Rear seems fine but there is already a 15 mm spacer added there.
    Next I will need to find suitable centre caps for a resonable price. I would like them to have black instead of yellow bakgrund color but haven’t found any yet in the right size. Any suggestions of where I can find caps is appreciated.
    Skickat från min iPhone med FerrariChat
    MvT, BillyD, Mechanical Dad and 2 others like this.
  7. matfo
    matfo Rookie
    Aug 1, 2013
    39
    Sweden
    MvT likes this.
  8. moysiuan
    moysiuan F1 Rookie
    4,164
    Canada
    Getting a bit chilly in the evenings, so I put the roof up for the first time since April. Original roof, still in great condition!
    Car stays on the road until the salt hits the roads, so probably still a few weeks to go for the Toronto driving season.
  9. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    445
    Eastern Tennessee
    Howard Scott
    Drained the transfer case/gearbox and refilled with Redline MTL. It is amazing how this basically cures the balky-when-cold second gear issue.
    Il Steeg likes this.
  10. Il Steeg
    Il Steeg Formula Junior
    359
    PNW-In a van, down by the river.....
    Dave
    JLF, Drewbdo and Allen S. like this.
  11. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Besides the fact that they are a weight saver they are very sweet! I like magnesium wheels, especially the 348 challenge ones!
    Tutte originale center caps Part 75834 or Part #70001379 if you want carbon:
    https://shop.munsterhuissportscars.nl/nl/product/75834/ferrari-black-center-caps-ferrari-genuine
    https://www.ebay.com/itm/Genuine-Ferrari-Carbon-Fibre-Centre-Wheel-Caps-Set-70001379-/362446311889
    They should fit every Ferrari, but have a cross check by calling your local dealer I would say.
  12. matfo
    matfo Rookie
    Aug 1, 2013
    39
    Sweden
    Thanks for the links, however I was looking for something a bit cheaper. [emoji4] I found used, yellow/black, ones at eurospares for a very reasonable price so I will try them and see how it looks.
  13. greatscott73
    Sep 1, 2017
    445
    Eastern Tennessee
    Howard Scott
    Window in driver door was getting pretty slow, so decided to open everything up, take everything apart, clean and regrease everything and reassemble. A couple hours of work yielded great results as window almost acts like a normal, non Ferrari window now!:D
    I am grateful my 87 has the more modern mechanism similar to the quarter window set-ups instead of the earlier cable design. Not sure I would have been as anxious to attack that contraption.
    Drewbdo likes this.
  14. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    We want to see as well :):) Eurospares is a good place to hunt for parts!
    matfo likes this.
  15. cianfichi
    cianfichi Rookie
    Oct 21, 2013
    49
    Thanks Rob! So just the one screw at the rear and the front rakes use double sided adhesive tape? On my 3.2 someone actually used a small screw on the outside to hold the top rake -- drivers side. And my pass side rakes are loose. Def needs some attention and reapplication.
    Vince
  16. WilyB
    WilyB F1 Rookie
    4,272
    AZ
    #166 WilyB, Oct 23, 2019
    alexion, djs308, JLF and 2 others like this.
  17. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    Darn, it's a pity you posted this picture just now, I would have included it on my Mondial 2020 calendar for sure! Fantastic picture with the mountains in the background!
    WilyB and Drewbdo like this.
  18. greatscott73
    Sep 1, 2017
    445
    Eastern Tennessee
    Howard Scott
    moysiuan, WilyB, matfo and 1 other person like this.
  19. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    What product Scott
  20. greatscott73
    Sep 1, 2017
    445
    Eastern Tennessee
    Howard Scott
  21. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
  22. matfo
    matfo Rookie
    Aug 1, 2013
    39
    Sweden
    It turned out that they only had one used cap so I ordered four new ones from them. I think it turned out pretty ok actually.
    Took a short ride today before washing and rolling into the garage and putting in hibernation over the winter.
    Allen S. likes this.
  23. BillyD
    BillyD Formula 3
    1,823
    Pacific Northwest
    Bill
    I waited for the mailman for my Belgium Fuse Board. It took a lazy week long cruise across the Atlantic before finally flying across USA to my waiting hands. Dam Porch Pirates didn’t get they’re human scum hands on this mail.
    stekkefun4 and MvT like this.
  24. JLF
    JLF Formula 3
    Sep 8, 2009
    1,704
    Great wheels, what are they?
