What did you do to your Mondial today? | Page 12 | FerrariChat
Discussion in 'Mondial' started by ddenboer, Dec 26, 2016.
  1. OpenAirFan
    OpenAirFan Karting
    Aug 10, 2008
    63
    Krefeld, Germany
    All my spare parts are from eurospares.co.uk also the NOS pillars
  2. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    409
    Eastern Tennessee
    Howard Scott
    Replaced my cooked fuse box with the replacement from GT Car Parts. Since the troublesome white plastic connector had been pretty well toasted, it was necessary to remove all the wires and attaching clips and transfer to the new white clip, which was a bit of a pain, but worth it in the long run, I'm sure. Everything works as designed. All relays and fuses replaced with new units as well. Hopefully good for another 33 years, lol!
    MvT and JLF like this.
  3. ronfrohock
    ronfrohock F1 Rookie
    3,918
    MA
    Ron Frohock
  4. MvT
    MvT F1 Rookie
    May 25, 2013
    4,248
    The Netherlands - NH
    Tijn
    It's genuine I see. I got one in the same package for 30 USD/EUR at the time (4yrs back) The Dealer should still be able to get it for you :)
    DocBasilone likes this.
  5. BillyD
    BillyD Formula 3
    1,774
    Pacific Northwest
    Bill
    I finished the QA1 front suspension rebuild, renewed the front brakes, changed the engine oil and filter. Only putting 500 miles on $100 worth of oil and filter in 15 months just seems wrong. I’ll try and drive more this year. The suspension and brakes are a huge success. So much better ride and the brakes really grab hard.
    350HPMondial, MvT, paulchua and 3 others like this.
  6. matfo
    matfo Rookie
    Aug 1, 2013
    39
    Sweden
    Looking great! Was it an easy fit?
    I have such a pedal kit in the garage but haven’t taken the time to mount it yet. Will probably be a task during the coming winter.
    Are there any mounting tips and trix that you can share!? :)
    BillyD likes this.
  7. OpenAirFan
    OpenAirFan Karting
    Aug 10, 2008
    63
    Krefeld, Germany
    Yes, it was an easy fit, took me one hour for all. Just remove the sticked rubber covers and position the aluminum parts with a screw clamp in place. Then drill two holes each using the aluminum parts as a template. The driving pedals are fixed with metric screws and nuts, just drill 1/10 mm larger. The dead pedal is fixed by self tapping screws, I used three and drilled this holes smaller than the outer diameter of the screw. Place the edge of the carpet under the dead pedal for a perfect result.
    matfo likes this.
  8. matfo
    matfo Rookie
    Aug 1, 2013
    39
    Sweden
    Great, thanks!
    Skickat från min iPhone med FerrariChat
  9. MvT
    MvT F1 Rookie
    May 25, 2013
    4,248
    Tijn
    I see you have (owned) an Alfa 156 TS :cool: A 1.8 or 2.0? Did you build in the compressor yourself?
  10. matfo
    matfo Rookie
    Aug 1, 2013
    39
    Sweden
    Yes, I have had some Alfas thru the years. It was a 2.0 but I didn’t build the supercharger conversion myself. When it worked it was really nice but I had quite a few issues... Here are an incar video from a test lap with that car:
    MvT, paulchua and OpenAirFan like this.
  11. BillyD
    BillyD Formula 3
    1,774
    Pacific Northwest
    Bill
  12. lince
    lince Karting
    Sep 26, 2006
    142
    I took it to its short trip, after almost 3 weeks. I normally is every 2 weeks , it's hard to enjoy it so little to keep the mileage down. Now I have done 528 miles in 6 years
    paulchua and JLF like this.
  13. JLF
    JLF Formula 3
    1,634
    paulchua likes this.
  14. Allen S.
    Allen S. Formula Junior
    Mar 16, 2001
    512
    Morgan Hill, CA
    Allen / AKA tCoupe
  15. JLF
    JLF Formula 3
    1,634
    It runs perfect, at least so far. I was losing a bank of cylinders intermittently when the engine was cold. Don’t know how old my plug wires are but did not replace those.
    The crank sensors literally crumbled in my hand when I removed them.
    Are you asking where that part (ignition control module) is in the car or where I got them?
    They came from FCP euro, Bosch 0227100200
    The ignition coils came from rock auto. I think 48 bucks for each or something.
  16. Allen S.
    Mar 16, 2001
    512
    Morgan Hill, CA
    Allen / AKA tCoupe
    I wasn't sure what parts those were for but I was guessing the ignition coil modules. The coils plug into those correct. My coils are fresh but those modules are Original. Thinking of swapping mine out.
  17. JLF
    JLF Formula 3
    1,634
    They have a separate plug. You have to buy some sort of thermal paste as well to put on the back of them.
  18. Allen S.
    Mar 16, 2001
    512
    Morgan Hill, CA
    Allen / AKA tCoupe
    Thanks again. I'll be doing some maintenance this weekend and taking a look at mine. FCP site has them in stock so maybe ordering them next. How did you confirm the cross reference to the Bosch part above and did it come with the paste?
  19. JLF
    JLF Formula 3
    1,634
    Allen S. likes this.
  20. Stef65
    Stef65 Karting
    Apr 28, 2015
    194
    reg Antwerp Belgium
    Stef
    MvT and DocBasilone like this.
  21. BillyD
    BillyD Formula 3
    1,774
    Pacific Northwest
    Bill
    I rarely clean mine as I think it looks faster dirty. ;)
  22. 350HPMondial
    350HPMondial F1 Veteran
    5,187
    Edwardo
    Thanks for asking. ,,,,,
    Apparently,, my piston to liner clearance,,, was too tight.
    and,,
    I got a slug of air ,, from my brake booster valve failure.
    thus,, we are looking at everything.,, in the motor.
