What did you do to your 365 GT4 2+2/400/412 today? | Page 7 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by OttoB, May 29, 2015.
  1. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    It's only on the second blower that I understood how to disassemble the unit without removing the squirrel cage (which is a real pain). During the previous bodywork they used tons of black protective paint, the blowers were heavy coated. I had to let the part soak overnight in break fluid in order to soften that mess.
    As the spray gun was out I also painted the horn pipes. As I am locked in the house I am short of supply so just took whichever paint I had but I like it better than the factory blueish metallic red.
    Ak Jim, Jasonberkeley and Schumi like this.
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,436
    Canada
    Newman
    Haven't yet but going to. I have this 81 Boxer / 308 wheel Im going to replace the stock 400 wheel with. We'll see how much it changes steering effort but I suspect not much considering its not that much smaller than the original. I just prefer the look of the smaller one, the 400 wheel can go on the wall in my office.
    Jasonberkeley and OttoB like this.
  3. samsaprunoff
    samsaprunoff F1 Rookie
    4,449
    Edmonton, AB Canada
    Sam Saprunoff
  4. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    Just fixing the wiper timer. See (and ear) the spark at 2'. Two much sparks on this old relay causes some hysteresis and the wiper would not work under load.
    The regular (metal casing) Bosch relays are easy to disassemble, this one is more tricky. Once the case is removed, cleaning the contacts is quite easy.
  5. Ak Jim
    Ak Jim F1 Veteran
    9,554
    North Pole AK
    Image Unavailable, Please Login Removed the column switch and sent it off to
    http://www.unobtaniumsupply.com
    For a rebuild. It was working ok except the headlights sometimes worked and sometimes didn't work. Looking at the switch I think I probably could have fixed it myself but figured it would be best to have someone who had done the job multiple times do the job.
    raemin and Jasonberkeley like this.
  6. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    I've also contacted Verell who is rally helpfull. I am wondering how to tackle with the steering nut without the proper spanner (no access to my mechanic till may 11th...). Anyone managed to remove the wheel without the RNT-38 ring nut tool ?
  7. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    In a pinch years ago I used two pairs of needle nose vise-grips. One to get into two of the slots and the other to grip the pliers that were holding the nut so I had leverage to turn it. It worked and didn't mark the nut.
    raemin likes this.
  8. samsaprunoff
    4,449
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Raemin,
    As I was awaiting the proper tools, I made a quick and dirty ring nut tool so I could continue my progress. Here I bought an inexpensive (less than $5) 30mm socket and spent about 10 minutes with my die-grinder to expose four pins that would mate to the ring nut (see picture). It is not pretty, but did allow me to remove the steering wheel .. and it did not damage the ring nut.
    Cheers,
    Sam
    raemin likes this.
  9. Ak Jim
    Ak Jim F1 Veteran
    9,554
    North Pole AK
    At some point someone used a poor substitute on the special nut. It is all hacked up as a result. I had to use a hammer to seet the special socket on to the nut. Also the inside part of the steering wheel is also messed up. I'd strongly advise you wait for the proper tool or at least make one like the above picture.
    raemin likes this.
  10. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    Thanks guys. I've tried to play with the needle nose pliers to no avail, so will hit the bullet and give superformance a try. £49 seems a reasonable deal (as long as they can ship...).
  11. Newman
    Dec 26, 2001
    14,436
    Canada
    Newman
    Did the steering wheel swap this morning then ran my work related errands in it. The smaller wheel gives more feedback in a good way, I like it and low speed effort doesn't feel different to me. Also more room for my legs. Image Unavailable, Please Login
    bjwhite, samsaprunoff, Ak Jim and 2 others like this.
  12. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    499
    Tim
    Today, among other interior trims, I had my dash covered by Jim K. He's done an unreal job and I'm extremely happy with how it's come out! It's certainly not 5 minutes work to do. Massive thanks to Jim for his hard work and time spent doing it. Now I just need to get things in order so it can be installed. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    Sent from my SM-G935F using FerrariChat.com mobile app
  13. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    Well not exactly "done on my 400i today", but at least my wiring diagram is now planed and documented...
    I cannot display the full diagram, as my project is based on P. Bennet diagram (which is not free), but here are my own planned modifications (highlighted in purple).
    Upgraded fuse & relay box
    I've order two 16 blade fuseboxes from UK; expensive given what this is, but these are the only boxes that fit properly in the glovebox.
    Low beam and fogs are operated through relays. I am also installing an auxiliary cooling pump (third relay). There are 4 unused relay holder in my car (3 for dual AC which I do not have, one for start valve time, which was removed on the later 400i gen1), that's were I am planing to install these 3 new ones.
    Last, the clock and the mirror do have their own fuse now, which allows me 1) to disconnect the battery without disconnecting the clock, and 2) get rid of the stupid mirror fuse that is buried under the centre console!
    Switch Pitch module
    Here is the only reason I really have to update the diagram, my new gearbox relies on an additional solenoid that is controlled by a module that captures the brake signal, kick-down and engine manifold vacuum. I'd prefer to record the modification for future maintenance.
  14. samsaprunoff
    4,449
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Raemin,
    Please post some pics when you are done.
    I am going to create a modern fuse block replacement for my 365 similar to what I did on my BB. However, the original 365/400 fuse blocks assembly is a bit more difficult to create a modern fuse replacement that maintains the original fuse block covers. The reason is because of how the wiring is connected to the fuse block ( rear terminals) and that the fuse face is sloped. Both can be addressed, but it is not overly straightforward and so I suspect the final solution will be a bit iterative.
    Anyway, it will be interesting to see what you come up with.
    Cheers,
    Sam
  15. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    Came to the same conclusion,
    1) torpedo fuses do require more complex terminals than blade terminals, keeping these makes your project more complex.
    2) the down facing connectors are another issue.
    So will get rid of the rear connectors and will use "blade fuses". I've bought a "fuse bloc" with loose terminals (could not find a torpedo bloc with loose connectors), and will crimp the wires directly on the fuse-bloc. That's a lot of work, but there is no other way to cram so many fuses in this tight space.
    Obviously I cannot re-use the stock cover, but my car does not have its original fuse-blocs. For the sake of originality you could contemplate a 3D printed plastic bloc with provisions for blade fuse terminals. Then use this prototype to build a silicon mould and cast your own blocs as Verrel does.
  16. bjwhite
    bjwhite F1 Rookie
    4,805
    Seattle, WA
    Brian White
    Started it, let it come up to operating temperature. Drove it up the block and back. Tested lights and turn signals and the like.
    Still stalled on my exhaust install. Five years this month is when I removed the old one. Unacceptable actually, ugh. It's been a busy five years though.
    Now I've recommitted to finally getting what I need and reassembling it. Watching the auction on BaT for 42185 inspired me to get off my ass.
  17. samsaprunoff
    4,449
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Raemin,
    Understood. What I am thinking of doing is what I did on the 308/Boxer fuses blocks where I use a printed circuit board for the electrical items and a milled base with features to allow for the original cover retention. 3D printing a design and then molding of bases is possible, but unless one needs to make a lot of these I find it easier to CNC mill out the base. Even so the original Covers are somewhat shallow and so there will be some design efforts needed in order to allow the original covers to be used with the blade/ATC fuses. I could go fully electronic and design my own electronic breakers... and then one would never have to replace a fuse ever again. Although this sounds like a great idea, the reality is electronics have other issues and so although I typically like to use high tech solutions, I also balance these urges with keeping things as simple as possible (the "KISS" principle). In fact I think it was Einstein who said "“Everything should be made as simple as possible, but no simpler.” ... and I agree.
    Cheers,
    Sam
    raemin likes this.
  18. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    #168 raemin, Apr 27, 2020
    These do look really nice and would indeed look good in our cars as long as you solve the Down facing issue (otherwise the wiring harness would be clutter the glovebox). The most simple adjustment I could think of would be to design the box with "solder posts". You could then provide the box either bare (for the few of us that would rather directly solder the harness) or with loose wires properly colour coded and terminated with male 6.3mm connectors (plug and play).
    Room for additional fuses would be a plus...
    Schumi likes this.
  19. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,204
    Gold Coast, Aust.
    Patrick
    Could not get a new ignition switch to seat properly in the casting of the lock. After breaking keys, and then breaking the switch from twisting it with a scalpel handle (very delicate bakerlite keyway), every time I tried to mount the new switch, the key would be impossible to turn, it was so tight. Finally had to take to whole steering lock off to see how it went together on the bench. It turned out the male key on the lock was deformed and burred - I just bet some bush mechanic or DPO tried to remove the lock tumbler by hitting it with a hammer. Anyway, it wasn't seating properly. So I had to properly remove the lock by drilling out a little pin (thanks Al Campbell for you post) and carefully pressing it out, so I could get to the internal key and file it to shape. I was going to thread the casting so I could replace the locking pin with a grub screw, but I found a little screw that jammed in OK (it's all hidden). I also machined a groove into the security screw so I could tighten it properly (and remove it later). Sorry, I only took one pic, but there are pics on FChat (which helped me).
    Al Campbell likes this.
  20. Ferraridoc
    Jun 20, 2012
    17,204
    Gold Coast, Aust.
    Patrick
    Il Tifoso likes this.
  21. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    Paid a visit to my mechanic so as to speed-up the rebuild.
    Just captured the engine, before they shoe-horned it in the engine bay. New bearings, balanced crankshaft, rebuilt heads, new valve, new valve seats, new guides, new chain, new tensioners, rebuilt water pump, new oversized pistons, 4° more overlap on the camshafts.
    Not sure about the cam-cover paint, but whatever the livery let's finish it and crank the engine once again (after 7 years...).
    roger21, Tojo and Il Tifoso like this.
  22. RicSinger
    RicSinger Formula Junior
    359
    Rancho Santa Fe
  23. raemin
    raemin Formula 3
    Jan 16, 2007
    2,323
    Lyon (FR)
    R. Emin
    Not period correct obviously but would look much better with wrinkle paint.
  24. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
    Unbelievable!
    RicSinger likes this.
  25. RicSinger
    359
    Rancho Santa Fe
    For sure, we will paint it and if it doesn't look good, I will replace it for an original when I find it at a fair cost.
