what are signs of differential failure in a TR? | FerrariChat
Discussion in 'Boxers/TR/M' started by ross, Jun 28, 2021.
  1. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    36,234
    houston/geneva
    Ross
    having some issue come up recently, so just want to know what others have experienced.
    thx
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,912
    romano schwabel
    please read all the other diff threads. there is no typical signs before a diff will fail. first thing is leaking oil at the left diff cover because this is broken then.
    I remember a post from paul newman when he openend a gearbox an dthe diff was broken. he was driivng the car before and not noticed. same happened to me but then the teeth from the pinion has been broken. have been lucky that the side cover was not broken.
  3. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,504
    Tuscaloosa, AL
    Drew Altemara
    Mine gave no sign. Just a crunch making a RH turn from a stop sign at 10mph. Took out the differential and side cover. This was in a 512BB but suspect a TR is the same. Drew
  4. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Not trying to be a smart a$$, but it is true:
    The most common sign of a bad diff is seen when the side of your tranny blows out.
  5. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,378
    The Cold North
    Tom
    When driving at a constant speed say around 50-60 mph..you will sometimes get a vibration that comes and goes in the seat of your pants at a consistant rate. You will also hear a droning sound that fades in and out with the vibration you feel in the seat.
    flash32 likes this.
  6. jgmblair
    jgmblair Formula Junior
    719
    Winnipeg, MB Canada
    Jeff Blair
    After the diff takes out the side cover the VIBRATION in the seat of your pants gets even worse but this is caused by your Wallet trembling ;) My factory diff was fine but I decided to upgrade mine about 7 years ago with one of Paul's beautiful pieces.
    turbo-joe likes this.
