Weirdness after Antigravity Battery Install with CTEK lithium charger
Discussion in '360/430' started by CoreyNJ, Sep 6, 2024.
  1. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    Finally got the battery installed.
    Took the opportunity to tape the bar on top for safety with harness tape. Should have cleaned the bottom of the battery holder, but maybe next time. I was running out of daylight. I also removed an extra generic CTEK charger hook up that the previous owner must have had. The car is a 2009 so the factory has the charger with the special connector on the passenger side.
    Yes I know I need to vacuum my carpet...
    So I started the car after the install. I got the 60 Ah battery and wow the car starts up super fast. I have never heard a starter motor run so fast before and with such a sure kick to life for the engine.
    Drove the car around, I even added their battery telemetry thing that send battery health to my phone over bluetooth. Stopped and started up no problem...
    Then I parked the car in the garage and hooked up my new lithium battery tender from CTEK using the adapter for the OEM tender hookup. I obviously went to try the lock-out which on the factory "Ferrari Branded" CTEK charger put a battery symbol up in the cluster and won't let the car start. Well here is where the weirdness starts. The car won't start... Good. I don't get the battery signal, just a click in the back and then the F1 light comes on in the cluster. Won't go away even if I remove the tender connection. Once I start the car it goes away but then when I shut down and go to prepare to start the car it comes back until the car is actually started.
    Grabbed my thinkdiag and when to look what codes there might be...
    The CFC201 transmission recorded a code of P1755 Ignition Enabling Relay Driver.
    I guess the new CTEK even with the adapter doesn't correctly lock out the ignition in the same way as the factory one.
    Cleared the code and all is well.
    So moral to the story. If you have a CTEK, not factory tender, with the adapter for the OEM tender on the newer F430s, if you go to start the car with it still plugged in, you may get an F1 error and have to clear it with something like a thinkdiag.
  2. GogglesPisano
    GogglesPisano F1 Rookie
    2,983
    East Bay, California
    Joe
    Now go cut all those stickers off the end of that cord! :D
    I.T. Guy likes this.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    Corey
    I don't quite understand how anything should be different and it is concerning - the way it works is just sends 12v to the third lead to activate the relay ..
    Does old one work the same way .. you don't even need to plug into wall to see if it works .. it just shorts the 12v feed to the third connector
    Something to me doesn't make sense
  4. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    I know, it's weird. I didn't get the "battery" symbol in the cluster with the new adapter. The car just doesn't start and I get the F1 error. With the OEM tender plugged in, I get the battery symbol and it doesn't attempt to start. I bought the CTEK adapter about a year ago from someone selling them here, so it could be specific to the adapter I bought.
    Do you have the pinout of the factory connector?
  5. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    Was waiting to make sure everything worked before I cut them off. No return after that point.
    energy88 and GogglesPisano like this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    I would guess something is wrong with the adapter ..I would investigate that asap
    Here is a website how to make one and another where i helped someone short the proper wires - it will explain the wiring as well - don't have the wiring diagram handy
    https://www.kumari.net/cars/ferrari-battery-charger-cable/making-a-ctek-to-ferrari-battery-tender-adaptor-cable
    https://www.ferrarichat.com/forum/threads/splicing-factory-connector-to-modern-ctek-charger.691200/
  7. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    #7 CoreyNJ, Sep 6, 2024
    OK, poking around I found this image...
    I'll grab a multi meter after work and check the adapter.
    It also can be that the charger doesn't actually send +12 in a way that correctly triggers the ignition block. Not familiar with how lithium batteries charge, but if it's pulsed or something else it could be enough to block start but not trip all the different electronics needed to fully engage the "protection"
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    Yes - that image is from the website above .. he made that test equipment to test his adapters
  9. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    Yep it’s wired correctly. Checked it against the OEM one also.
    I’m guess it’s something related to how lithium chargers work vs the standard CTEK tender.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    If you just install adapter without connecting to charge
    .what happens
  11. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    Ok. Decided to do this as a more scientific test. So 2009 F430 with factory battery tender setup.
    Case 1: battery symbol displayed when starting car is attempted.
    - Optima Red top battery & Ferrari Branded battery tender not plugged into AC.
    - Optima Red top battery & Aftermarket CTEK adapter (No tender attached)
    Case 2: No battery symbol displayed when starting car is attempted but F1 error light appears till cleared.
    - Antigravity Lithium Battery & Ferrari Branded battery tender not plugged into AC.
    - Antigravity Lithium Battery & Aftermarket CTEK adapter (No tender attached)
    - Antigravity Lithium Battery & Aftermarket CTEK adapter (lithium tender attached, but not plugged into AC)
    So it appears to be something to do with the 12V supplied by the lithium battery doesn’t play well with the start lockout since the lockout is triggered by shorting the 12v to the correct pin on the oem tender connector on the car.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    That is so strange and almost makes no sense as EE( what am i missing) ..no other variables..change of wiring connectors etc
  13. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    I generally agree as an EE also if a lithium battery worked like a standard battery, but the lockout may be a multi-function magnetic relay and the BMS may be doing something funky like kicking into a low power mode which prevents the magnetic relay from working 100% correctly and completely blocking the startup.
  14. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    I don't believe the f430 has a BMS system .. are u referring to the lit battery module ?
  15. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    Yes, the one in the Antigravity Lithium battery. That seems to be the only thing it could be since it works fine with a standard AGM battery.
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    #16 flash32, Sep 7, 2024
    Corey ,
    I think you are as OCD as me .. and I have to tell you .. that bothers me ..bothers me enough not to every put that type battery in any of my cars unless I truly understood it better
    Just my thoughts
    I will try to look and wiring schematics tonight and try to make sense of it
  17. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    Can you measure pin 1 of connector , and does psr4 click when you connect plug ( even without tender)
    The reason I ask is that there is ( according to Scud wiring diagrams) a direct path from pin 2 which is shorted form pin 1 to the dashboard
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    Pin 1 should be voltage from PSF10 .. so if easier measure there if possible
  19. Qavion
    Qavion F1 World Champ
    13,867
    Ian Riddell
    He's not getting start, so PSR4 must be working.
  20. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    #20 flash32, Sep 7, 2024
    I think he is getting no start from F1 instead ..not in front of diagram ..psr6?
    The path to dashboard light is same positive circuit as psr4
  21. Qavion
    13,867
    Ian Riddell
    TBH, I really don't understand the signal processing for the F430. According to my notes, the starter button sends sends a signal to the F1 TCU (pin 24/plug B) to "open the clutch". i.e. start button signal goes via PSR7. I can't see how this process would be affected by PSR4 (B/C inhibit) or PSR6 (starter) or the B/C. The F1 would only not give approval to start if it didn't have its usual inputs from the brake pedal, etc.
    I've added the B/C charger circuits to my F1 diagram..
    https://www.dropbox.com/t/eSf00AssHG19tlyx
    What do you suspect is broken? PS4?
  22. sfcarguy
    sfcarguy Formula Junior
    524
    Earth
    As someone who makes and sells these adapters everyday...this is a certified head scratcher.
    Qavion likes this.
  23. CoreyNJ
    CoreyNJ Formula 3
    2,370
    New Jersey Shore
    Yes my OCD wants me to figure this out ;-)
    It may have to wait till during the week as my son is driving the car to the “Hoboken Italian Festival” today with the Italian Cars & Cannoli group, but I’ll put an oscilloscope on the the connector when I can. I think that will tell us what is really going on. The weird part is lots of people have Antigravity batteries and I might be the 1st person to test the setup for lockout. I also realized I have the Antigravity “battery” monitor that is attached to the battery and is not in place when I use the AGM so there could be encoded signals in the 12v power to the lithium battery. The oscilloscope should help figure that out and it could be what is the route of the problem. Once I have an idea what is really going on I will discuss it with antigravity.
    flash32 likes this.
  24. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,677
    Central NJ
    Dominick
    I think a few of my friends from.cars and cannoli will be there
    It is such a simple circuit ..at least on the wiring diagrams ..12 v coming from the fuse I mentioned above then to pin 1 of connector ...cross over when connected and then to dash light and relay psr4 sensing side
    Looking forward to understanding this better
    Enjoy the day
  25. Qavion
    13,867
    Ian Riddell
    Does the Scud have a lithium battery? I'm just wondering why the Scud diagrams show an additional diode in the start/start inhibit circuit (and an extra (?) wire going to the instrument panel)
