Washer Fluid Level Sensor Cross Reference Found | FerrariChat
Discussion in 'Mondial' started by dmarti02, Oct 19, 2020.
  1. dmarti02
    dmarti02 Karting
    Jun 22, 2014
    52
    Haverford, Pennsylvania
    Doug
  2. wsendelback
    wsendelback Rookie
    May 12, 2016
    26
    Dallas, TX
    William Sendelback
    Since cabriolets have a more shallow reservoir and hence a different/shorter sensor, how did you locate this sensor so that I can attempt to find one to fit the cabriolet reservoir?
  3. dmarti02
    dmarti02 Karting
    Jun 22, 2014
    52
    Doug
    This one was on ebay. I've been doing google image searches for various parts for other italian makes of the era. That's how I determined the Alfa Spider seat belt cover for our cars as well in a different thread. This is for the washer fluid tank that's under the hood/bonnet.
  4. dmarti02
    dmarti02 Karting
    Jun 22, 2014
    52
    Doug
    Also, after seeing how a fully functional sensor actually looks and operates, It appears that this one can be modified to work in a more shallow tank although that is speculation. It looks like you could cut a section of the metal rod out and reattach either with a weld or epoxy. That just connects the body of the sensor to the float.
  5. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,371
    Argent/Brasil
    Guido
    For the short models : That part with rod you can remove from your original and click it on the new sensor.
    dmarti02 likes this.
