was there ever a fix for the 512TR hot starter issue? | FerrariChat
Discussion in 'Boxers/TR/M' started by silvergts1998, Aug 20, 2017.
  1. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,419
    ky
    Adam
    Once in a while, my starter won't turn over due to heat is what I am suspecting. Was there ever a fix for this? Turn the key to start when the engine is hot and I hear click, click but won't turn over. Wait a while when it cools down and it starts up fine. In a jam once since I suspected the starter getting hot, I put a facecloth on the starter and poured cold water on it. Waited a few minutes and it started. So is there a solution for this or a good thread somewhere?
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,931
    romano schwabel
    just replace the magnet switch
  3. silvergts1998
    Apr 10, 2005
    2,419
    ky
    Adam
    are talking about the solenoid?
  4. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    3 schools of thought... install a relay to the solenoid to force raw battery power to the solenoid and force it to engage, replace the solenoid, or clean the plug below the expansion tank. Lots have been written here about all three options. Feel free to search.
  5. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,155
    Canada
    Newman
    I don't recall the 512TR having the same plug in the LR corner like a testarossa has, not even the same starter. If your starter is acting up hot then rebuild it or replace it like you would any other car.
  6. silvergts1998
    Apr 10, 2005
    2,419
    ky
    Adam
    There was a post about honing out the solenoid someone did a write up on. seem like it made sense and was a good fix, any insight on that tactic?
  7. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Oh the 512TR didnt have that problem? My bad.
  8. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,116
    Mel
    There was a write-up indeed Adam (Glad you are back here :D)
    Try Search ...
    But Romano (and Paul) is right basically: get another solenoid :)
  9. tvu
    tvu Formula 3
    1,310
    Southern California
    Trieu
    I think there have been multiple solutions -
    1) Solenoid
    2) Honing the chamber to create a little more room - so the cylinder wouldn't get stuck. I think Steve(from Washington) did a write up on his website. I'll have to search for it. https://www.stevejenkins.com/blog/2015/07/diy-fix-a-ferrari-testarossa-512-tr-hot-start-problem/
    3) I think JIMBO installed a relay switch / button. http://www.ferrarichat.com/forum/boxers-tr-m/494699-how-i-installed-starter-button-512tr.html
    I've tried #1, and #2 - and still encountered the issue once in a while. Let us know if you ever find a definitive fix.
    Good to see you here again Adam.
  10. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    I remember Steve Jenkins doing the write up.
    I took apart my 308 starter this past week. After seeing how the solenoid works, it would make perfect sense that a light hone would solve a sticking problem. it is metal sliding on metal and corrosion and heat over time will slow the solenoid down.
    I am willing to bet you can also buy a new solenoid (I did for my 308) ....I think from maniac electric.
  11. Melvok
    Jul 25, 2008
    14,116
    Mel
    It's coming with the years Tim .... dust and dirt ... just remove that by honing is perfect solution imo ...
  12. martinp
    martinp Karting
    Jan 11, 2005
    69
    Nr Ludlow, Shrops UK
    Martin Phillips
  13. martinp
    martinp Karting
    Jan 11, 2005
    69
    Martin Phillips
    Hi
    A bit late replying but I had this infuriating issue and resolved it quite simply (in the end)
    In the first instance I thought the solenoid was sticking so I machined 10 thou off the piston ( a spare)
    Helped a bit but no luck. As a professional electro technical engineer this was a challenge now !
    In the end I discovered that the bendix drive was prone to collecting dust from the clutch.
    This made it stick on the shaft rather than slide freely
    The cure
    Drop the starter off - probably the easiest operation of any car.
    Open it up and wash the bendix drive through with a bit of petrol ( for instance) or solvent
    Lots of muck comes out.
    Run a tiny bit of light oil or moly slip type of product for lubrication of the shaft
    (Not too much as dust sticks to the excess)
    Move it up and down a few times to distribute the lubricant and reassemble.
    A 30 min job
    Repeat about every two years.
    Apologies to those dealers who had a career from this issue
    Martin
  14. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Does this issue occur on TR’s or just 512’s?
  15. tvu
    tvu Formula 3
    1,310
    Southern California
    Trieu
    Nice find and writeup Martin. My mechanic has just installed a new relay - and says it's a lot better. If it doesn't fix the issue - then I will go that route.
  16. pce01
    pce01 Karting
    125
    Rochester, NY/Tampa
    Peter
    I had this issue. Originally, the Shop where I take the car (Cantech in Syracuse, NY) rebuilt the starter and installed a new Bosch solenoid, but I still had two occurrences over a five month period in the Summer of 2018. So, I mentioned it to the Shop Owner when I left the car off for storage in the Fall of 2018. They performed the following work over the winter, at no charge, which has solved the problem:
  17. turbo-joe
    Apr 6, 2008
    8,931
    romano schwabel
    hope this all helps?
  18. silvergts1998
    Apr 10, 2005
    2,419
    ky
    Adam
    Just a follow up. I ended up buying a new started and it did the same thing. I there's something else going on with my car and suspect it's a relay issue. I jump started my started after driving when I couldn't get it to turn over. So I know it's not the started.
  19. silvergts1998
    Apr 10, 2005
    2,419
    ky
    Adam
    Sorry, damn spell checker. *starter
    turbo-joe likes this.
  20. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,900
    Troy, Michigan
    James
    I fixed mine by putting in the relay. I tried cleaning the starter a few times, even screwed around with the white wires on the fuse box. Since the relay I haven't had an issue with heat soak on the starter at all.
