WARNING - NEVER clean plastic with alcohol! | FerrariChat
Discussion in 'Detailing & Showroom' started by 67bmer, Jan 31, 2019.
  1. 67bmer
    67bmer F1 Rookie
    2,670
    MD
    I did not know this! We clean virtually everything with IPA (Iso Propyl Alcohol) in an ultrasonic cleaner prior to assembly for space instruments. Many of the new high tech SiO2 coatings suggest wiping the panel with IPA prior to applying the coating. Without thinking there could be a problem, I went to wipe down my taillight with IPA prior to applying Gyeon Can Coat. Almost immediately, I heard and saw cracks forming!
    My 30-year-old taillight
    wet sanded ready for polishing
    wiped with IPA and cracked
    Finished with Gyeon Can Coat
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Must be the material type. "Plastic" is very generic. We you it all the time on ABS and never had any issues.
    Rifledriver likes this.
  3. Einsteiger
    Einsteiger Karting
    Oct 9, 2014
    125
    Overland Park, KS US
    Kevin
    Wow. That is a new one. I've not seen alcohol do that.
  4. 67bmer
    67bmer F1 Rookie
    2,670
    MD
    yes - acrylic and polycarbonate. I believe that headlights are typically polycarbonate. Alcohol is often shipped in plastic bottles and the squeeze bottles are plastic. It never occurred to me this would be a problem. Google search quickly proved otherwise!
    ozziindaus likes this.
  5. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    Alcohol is safe, acetone is the killer
  6. 67bmer
    67bmer F1 Rookie
    2,670
    MD
    I heard the cracks the instant the cloth with alcohol touched it!
    https://www.mddionline.com/acrylic-polymers-clear-focus
    Isopropyl alcohol tends to promote crazing in acrylic, as it does in many transparent plastics. Some acrylic grades are more alcohol-resistant than others: resistance is typically a function of the molecular weight of the polymer, with higher molecular weight providing better alcohol resistance. Diluted solutions of isopropyl alcohol can be used to wipe down acrylic without adverse reaction.
    use at your own risk.
  7. P Zero
    P Zero Formula Junior
    Apr 19, 2006
    349
    I use Iso to clean polymer firearms and never thought that it might damage the plastic. I don't notice anything, but now it has me wondering.
  8. Edgar Diaz
    Edgar Diaz Karting
    Sep 13, 2014
    198
    Alabama
    Edgar Diaz
    I have cleaned plastics with denatured alcohol. Never had any issues
  9. sandreb
    sandreb Karting
    Feb 7, 2018
    52
    Sander B.
    Never thought that alcohol can cause damage like that.
  10. Christian.Fr
    Jun 9, 2005
    21,213
    Christian.Fr
    Before to start something with alcohol I prefer to try it in another masked plastic part, just to see what happens.
  11. Christian.Fr
    Jun 9, 2005
    21,213
    Christian.Fr
    I Think it s recuperable, not 100% but 60/70%.
    There s a méthode with sand paper extra fine, 1000 - 2000. Try to do only side with sand paper. Afther try to clean with a polishing compound, 3 tubes. (depend company).
    Sorry for my english, but check in youtube the result sometimes is spectacular.
    Good luck
  12. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I clean polycarbonate daily with 99% IP with absolutely zero issues.
  14. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Hmmm, used it once to clean a screen and it immediately went to hell.
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Some time this week if I remember I will make a video:)
    Mimmo Blue likes this.
  16. msdesignltd
    msdesignltd Two Time F1 World Champ
    20,046
    NYC. / E. Hampton
    Michael
    You should be able to bring back with marine clear curtain polish.
    2 stages of grit
