Warning info, car ramps | FerrariChat
Discussion in '348/355' started by zoowho2, Apr 24, 2013.
  1. zoowho2
    zoowho2 Formula Junior
    Oct 29, 2012
    269
    Arizona, USA
    Tom
    #1 zoowho2, Apr 24, 2013
    A word of "CAUTION" on car ramp usage.
    When using these ramps, especially the plastic compound type, be sure to place them on a non slip surface or non slip device between floor and ramp. A painted or tiled garage floor is a hazard waiting to happen, so be safe rather than sorry....sigh...
    I attempted to back up onto the ramps with my 348 ts, made contact with the ramp lips and gave a little throttle to back onto the top and "BOOM" or Blammo or just plain "AW SHI........The one ramp shot under the car like a cannon and the other half suspended on the tire and frame, and there I sat saying bad words and beating my head. The slick epoxy painted floor was like snot with plastic ramps and as soon as the wheel began to rotate, it shot/thrust the ramps under the car. Fortune shined on me and little damage was done other than a couple bent flanged edges on floor panel. I was lucky the other side did not fling completely under the car as well. It did take considerable time to "ground" the car without causing damage when removing the ramps.
    Use a non skid surface and use approach pads over the lip of the ramps..or better yet, lift the car and slide the ramps under it so you can drive off. That is why I made the lift device shown on another post. Music please......DUMB DUMB de DUMB
  2. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    I learned the exact same lesson with my brand new 1988 Honda CRX Si many moons ago... Shot the ramp like a bullet across the floor - would have seriously injured anyone in its path. All the best.
  3. Volair
    Volair Karting
    Apr 11, 2013
    241
    Carmel, Indiana
    Bart
    What a timely post! I was going to do my oil change and tranny fluid tonite using the black plastic ramps. I have an expoxy floor and also was going to back my brand new (to me) 348 onto them.
    What I like to do is firmly shove the lip of the ramp under the tire to make sure it is wedged well under the tire before I start driving onto ramps.
    Another thing worries me is the height of the ramp vs the clearance on the nose of the car. I did some basic geometry and noticed that when the car would sit on ramps with rear wheels, the front of nose will be less than 1 inch from ground (too close for comfort). Hence I was thinking to put the ramps at the edge of the garage where I have about 1 inch drop between the driveway and garage floor. That should help twofold: The ramps will be pushed againt the lip formed by garage floor when backing onto them and also will give me more clearance on the front end.
  4. drftfan
    drftfan Formula Junior
    Jan 12, 2011
    357
    Orange County
    Jamie
    Just use a standard jack and jack stands. Way easier
  5. zoowho2
    Oct 29, 2012
    269
    Arizona, USA
    Tom
    The issue here is the ramps being shot out/under the car because the floor is not sufficient to hold the ramps...A good example is a baseball pitching machine......grip.
    The tire has grip, much more so than the floor and wheel spin will spit out the ramp like a melon seed. Best bet is to raise car then set the ramps under the wheel...at least you can drive off when done. Other than that, as suggested, use a jack and stands.
    The possibility of severe damage to the Red is to costly to save a minute of labor by driving on.
  6. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Echo this..............particularly when there is a hot head behind the wheel who drives OFF the ramps with a blip of the throttle - even on a non-slip surface. Make sure that nobody is in the line of fire.
  7. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    get a couple of strips of carpet, slightly thinner than the ramp. Fold it in half around the entry point of the ramp. As you reverse, the wheels go over the carpet, and the weight of the car stops the ramps slipping so easily...
  8. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Good stuff that. I wish I had known it 45 years ago!
  9. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    I am having trouble visualizing ......you have any pics?
  10. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    #10 hank sound, Apr 29, 2013
    Q - When does ramp looks like a melon seed?
    A - When its launched from beneath a Ferrari.
    :):):), Hank
  11. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,316
    Palos Verdes
    Vince V
    I have ramps and I jack the car up onto them. :)
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,379
    San Carlos, CA
    Mitchell Le
    For garages where real work is done, an epoxy or paint is not a good thing. For garages where bling is king, then a painted floor or tiles are fine.
  13. mlambert890
    mlambert890 Formula Junior
    Apr 2, 2002
    389
    CA
    #13 mlambert890, Apr 29, 2013
    Just sayin' :D
  14. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    Let's see if I can describe as I understood it................
    Eddie's tip is to use a strip of old carpet in a loop to anchor the ramp as you start to climb up. The strip is narrower than the width of the ramp and maybe six foot in length. Loop the strip around the bottom rung of the ramp and double it over the three feet length that is already on the floor. When the car tyres approach the ramp, they are already bearing down on the "sandwich" of carpet and this stops the ramp from moving away; same happens when you descend - the carpet stops the ramp from shooting out. Great idea.
  15. radlu
    Jun 6, 2005
    424
    #15 radlu, Apr 30, 2013
    Thank you. But my head is spinning even more now.
    I just do it this way....much safer then ramps.
  16. radlu
    Jun 6, 2005
    424
    #16 radlu, Apr 30, 2013
  17. Subarubrat
    Subarubrat Formula 3
    Apr 1, 2009
    2,072
    VA
    Scott
    My standard procedure for coming off the ramps with the Lotus is to tap the gas an clutch at the same time and eject the ramps.
  18. vegas1
    vegas1 F1 Rookie
    Jul 28, 2004
    4,202
    Australia
    I did the same thing a few years ago when I attempted to back my concours winning Jaguar up onto some steel ramps in my garage. Same story, the ramps just slipped on the concrete floor and damaged both rear sills on my car. Not a happy situation.
  19. ronrob
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    #19 ronrob, May 1, 2013
    As you will see, I spent hours preparing a sophisticated illustration of the technique.....
