Vitaloni mirror guts - Euro 36753/54 | FerrariChat
Discussion in '308/328' started by Cirorsi, Oct 9, 2020.
  1. Cirorsi
    Cirorsi Formula Junior
    790
    Louisiana / Lac du Saint Sacrement, NY
    Steven
    Does anyone have another perspective photo of how this Euro style, 308 mirror bracket (steel) is attached to the motor? Maybe a pic of the bottom or rear. This pic came from a 2006 thread titled, "308 QV side mirror - problem solved" but the thread starter left FChat back in 2011.
    I'm trying to make my Vitaloni mirrors electric and have found the common electric motor but not the mounting bracket. In my search I see that the Lambo Countach and Jalpa mount the same way but perhaps in Lancias or Maseratis?
    Thanks,
    Steven
  2. conan
    conan Formula Junior
    Nov 13, 2011
    389
    Hi, I know I had to remove the screws and carefully pull out the two pins on the white bar from the housing. I was afraid to break something but it was ok. Then the assembly can be taken apart, but be careful with the positions of all the pieces which no longer are held together.
  3. Cirorsi
    790
    Steven
    Conan, would you have a picture of how your black motor housing secures to the mirror housing? Yeah, that plastic sleeve is kinda thin but thankfully flexes just enough. I found the BMW E34 and Alfa Romeo GTV-6 use the common motor with the Alfa pivot sleeve closely resembling the 308 piece.
  4. Cirorsi
    790
    Steven
    steved033 likes this.
  5. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    9,494
    Atlanta, GA
    Steve D.
    Thanks! It was great to help you get your project sorted out!
    sjd
  6. irkubr
    irkubr Rookie
    Sep 9, 2021
    2
    Gabriel Dos Santos
    @Cirorsi , not sure if you are still around but my 308 has vitaloni baby turbo and I'm interested in making them electric, just like you did. Do you have any post or tips you can share regarding how to make this conversion? Thanks!
  7. Cirorsi
    790
    Steven
    Hi Gabriel, I'll send you a PM
